Question about Danby 3.6 cu. ft. / 102 liter Chest Freezer Millenium DCF401W
Quick Question I have a Danby Compact Freezer, and my Dad recently moved it into another room and the cord was to short to reach to the outlet and he had to use a Heavy Duty drop cord.. Is that safe?? My freezer is now making a sound and it wasn't before... Well having it on a drop cord cause it to tear up??
    Novelist:
  • 87 Answers
Not sure what a drop cord is but a compressor will either run or not as the case may be. Power supply variations can cause failure but not tear it up. If the compressor is running noisey then unfortunately it will continue to do so until it stops. However it could be that it is a vibration of the pipes due to the move causing the additional noise. I would suggest having a look at the back of the cabinet and seeing if you can pinpoint a bit more precisely the source of the noise. Hope this helps.
Posted on Aug 18, 2007
What kind of extension cord is safe to use with this freezer?
Freezer manufacturers do not recommend use of extension cords.
Jan 05, 2016 | Woods Freezers
Danby freezer
If it stopped working after being moved, check all the electrical connections. Also check no pipes were broken in the move. Is there any noise from the compressor?
Mar 23, 2014 | Freezers
We have just moved a freezer and pluged it in but it doesnt turn on. it is pluged into an outlet with power i tested that
The Danby freezer(DUF808WE) doesn't work from yesterday, even proper plugged in?
I already check electrical outlet. How can I fix it?
Jul 08, 2011 | Danby Freezers
Freezer not working
  • Make sure the freezer is plugged in
  • Check for a blown fuse or tripped circuit breaker
  • Test the power outlet for voltage
  • Inspect the electrical cord for damage
  • Eliminate use of an extension cord, if any is being used
  • Check the outage votageIf power is reaching the electrical outlet, trace the freezer wiring and test components as you go. Either there is a short, which must be located and repaired, or the freezer has sustained electrical damage.
Thanks.
Jun 26, 2010 | Kenmore Freezer 20.3 cu. ft. Frost Free...
I moved my freezer and now will only stay cold for a short time, why?
You jard the liquids. Did you just move it a little or move like to another house because if you move a frig or freezer somewhere or lay on it's side you shouldn't plug in for an hour or more so it all settles or it won't work. Hope this helped
Apr 29, 2010 | Danby 5.5 cu. ft. / 156 liter Chest...
My brand new Danby compact chest freezer is very noisy.What is the problem?
It could be an area where the tubing is vibrating against the cabinet or it's touching other tubing. While it's running you can run your hand along the tubing and when you get to the vibrating area it should stop. You can then slightly move the tubing away from where it's vibrating. Do not bend or kink the tubing.
It could also be a noisy compressor which would be under warranty.
Aug 26, 2009 | Danby 3.6 cu. ft. / 102 liter Chest...
Freezer
Unplug it and manually defrost it. making sure that the inside of freezer has reached room temprature thenplug it back in and see if that helps.
Aug 03, 2008 | Haier Freezers
Danby 3.6 cu. ft. / 102 liter Chest Freezer Millenium DCF401W Logo
137 people viewed this question
Top Danby Freezers Experts
Dennis Boxerman
kfinlay1969
Level 1 Expert
AJMAL KHAN
Are you a Danby Freezer Expert? Answer questions, earn points and help others
