I have a kenmore oasis elite it beeps all the time and flashes F2
I have a kenmore oasis elite it beeps all the time will not start some times and flashes the code F 2
Code F2 means a stuck button. I removed the interface and lightly sprayed each with contact cleaner. So far this is working. The interface costs about $160 and contact cleaner, $10. Good luck.
Posted on Mar 18, 2009
SOURCE:
How do I unclog the long drain Kenmore elite oasis?
Honestly, we got rid of the machine and bought a Maytag Neptune. I was over trying to figure out all the codes the Oasis was flashing. We gave up on the first one that started having problems when a friend gave us one identical to ours and it has done a lot of the same things.
Apr 03, 2014 | Kenmore Elite Oasis 27052 Top Load Washer
My Kenmore Elite washer model 110.27062600 stopped working. All the front panel lights are flashing on and off for 7 times then pauses and starts blinking again. The machine will not do anything. No...
if this is an oasis model. Try pushing other buttons you should get a touch tone (beep) as a good response. if no sound you seem to have a interface problem. not a main ctrl.
Sep 19, 2017 | Kenmore Elite Oasis 27052 Top Load Washer
In mid wash the Kenmore Elite Oasis HE flashes F51 and
check if basket turns freely. if it does replace the main board
Jan 28, 2010 | Kenmore Elite Oasis 27052 Top Load Washer
I hadn't washed any laundry for a couple days and then my Kenmore Elite Oasis starting beeping in the middle of the night. My husband had to unplug it because it wouldn't stop. The next morning I did some...
According to the Whirlpool Cabrio (Sears Oasis) manual, this code indicates a "stuck key"
Keypad/User Interface Failure
F then 2 flashes when in:
• Diagnostics Test mode if a stuck key is detected.
• Standby mode if there is a user interface mismatch.
Following is the PDF of the manual.
https://secured.whirlpool.com/Service/SrvTechAdm.nsf/2cd44500d572193285256a45004fd9d6/409753510a90c8be852571e90073421b/$FILE/8178583.pdf
Sep 22, 2009 | Kenmore Elite Oasis 27052 Top Load Washer
Kenmore Elite Oasis HE. I keep getting a F2 error and a beeping sound. Will happen at anytime, not just when using the machine. Washer had been unused for 2 days and all of a sudden the error code just...
“F02” is a Long Drain error. If the drain time exceeds 8 minutes this error code will be displayed. In addition, a “SUDS” error may also be generated as a secondary error. This is an indication of a drain pump problem and/or clog in the drain line. You will need to check the following:
1. Check the drain hose to make sure it is not kinked or clogged.
2. Check the electrical connections to the pump and ensure the pump is running.
3. Remove the drain pump filter and check for foreign objects and/or debris.
To check the drain pump, click on the following link for step-by-step instructions.
http://www.fixya.com/support/r385844-checking_drain_pump_kenmore_elite_front
If the above procedures do not correct the problem, it is recommended by the manufacturer to replace the drain pump
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Aug 21, 2009 | Kenmore Elite Oasis 27052 Top Load Washer
My kenmore elite he4 dryer wont start
kenore elite oasis dryer won't start, when start button is held down it flashes F, book says call service center
Jun 30, 2009 | Kenmore Dryers
Kenmore Oasis Elite Top Loading Washer with an F2 error
The F02 error code indicates keypad/user interface failure. Most of the time, this is caused by a problem in the keypad/user interface. It can sometimes be caused by a failed control board.You could have an intermittent problem such as a stuck key or contact. As long as the F02 is not displayed, the washer should work normally. You can continue to use it when the F02 is not displayed. It is still safe to use the washer.
Sometimes this problem is caused by a loose wiring harness connection between the keypad/user interface control board and the machine control board.
The F2 error code on this washer indicates a stuck button on the user interface control board. The procedure for accessing the control boards on this washer is shown in the image below. I recommend unplugging the washerand checking the wire harness connection from the user interface control board to the machine control board. Try unplugging the connections and then plugging them back in a few times. Make sure that they are plugged in correctly and then reassemble and test the washer. If the F2 is still displayed, then the user interface control board will need to be replaced.
CLICK ON THIS LINK TO GET THE INSTRUCTIONS HOW TO REMOVE CONTROL BOARD:--
http://media.fotki.com/1_p,wfbgkftgqtgssggxgtqsskgwtqkq,vi/gdqwksfbdxggskbksbb/1/1303472/5961857/image8028img-or.gif
You can order a new user interface control board from the Sears PartsDirect website or from----------
www.repairclinic.com
Thanks. Keep updated for any more query. You can rate this solution and show your appreciation.
Jan 12, 2009 | Kenmore Oasis HE 27082 Top Load Washer
F2 and beeping
The F2 error is the user control board gone south on you, a new board will fix the machine, as always do you own your home and does the insurance cover appliances?
Sep 05, 2008 | Kenmore Oasis HE 27082 Top Load Washer
Kenmore Oasis Elite---110-27086601
This error only shows in diagnostic mode, with power off choose any buttons except stop and power, press in intervals 5 seconds on and 5 seconds off until 88 appears and all light light up. If the user panel is faulted F 2 will flash in the display, press the same button you used to start diagnostics to jump to the next error code and once through 88 will flash and diagnostics will start. Sometimes once F2 flashes and the machine has not been repaired it will stick at that mode.
Aug 07, 2008 | Kenmore Oasis HE 27082 Top Load Washer
Washing Machines Logo
624 people viewed this question
Top Washing Machines Experts
Gerry Harvey
Gerry Harvey
Marvin
Marvin
