Question about NEC USB 2.0 ( ) Laptop PCMCIA CardBus PC Card Adapter (USBP2D20) Serial Adapter
Windows doesn't detect the adapter
The card works better with windows' own drivers. I have tried with both drivers. The problem is: the adapter worked fine for weeks but now windows just decides that the adapter is no longer connected. I can't see it in the device manager any more. This happens totally randomly. When I try to unplug & plug it again, windows doesn't detect it. Not even if I do "Scan for hardware changes". I managed to get it detected by removing PCMCIA devices from device manager and then scanning for hardware changes. Still, after a few hours the adapter isn't there. I have HP Compaq nx9005 laptop with XP Home SP2.
    Problem Solver:
  • 9 Answers
May there is realy a defect on that card. just try use another card and see the result.
Posted on Aug 14, 2007
SOURCE:
My computer doesn't detect my speakers, I do have windows 8
Do you have the AC adapter plugged into a live outlet and have you turned on the speakers? Make sure that the speaker signal cable is plugged into the correct port on your computer (the lime green port on a desktop). Check that the correct audio driver is installed for your computer. (With Windows 8, use the Device Manager to check. From the Start Screen, type in Device Manager. Click on Settings and then select Device Manager. Alternatively, Windows key+C on the desktop. Select Settings and then Control Panel. You can find the Device Manager under System and Security or Hardware and Sound.) Scroll down to the Audio devices. Expand the section and look for a red triangle with an X or a yellow triangle with an exclamation point. Try updating the driver (check with the manufacturer of your computer for the latest driver). Even if you don't see the error triangle, try reinstalling the latest driver.
Next check if the speakers work on another computer. If they don't work, the audio cable may be damaged. Try a different set of computer speakers on your computer.
If other known good speakers do not work and the correct audio drivers have been installed, check the audio output devices. Go to the Control Panel > Hardware and Sound page (as described above). Choose Manage Audio Devices. Check if the HDMI port is set as the default audio device. Disable it for a bit (right click on the device) . Sometimes when a new video card is installed, the audio device defaults to this port. This messes up the drivers for the regular audio.) Reboot the computer and then try reinstalling the audio driver. Reboot again.
If it still fails, there is probably something wrong with the audio device hardware. If you are using an add-on sound card, try disabling it and using the motherboard audio device. (A number of add-on sound cards didn't work well with Win7 or Win8. The on-board audio drivers worked better.) If you are using the motherboard audio on a desktop, try an add-on sound card. (Check for Windows 8 compatibility (drivers) before selecting any card.)
I hope this helps.
May 29, 2013 | Kinyo PA-1158 2.0 Amplified Speaker System
My flash dive is not work pc is not recognize it
Windows XP, Vista , or Windows 7 should be able to automatically detect and install it. Try using it on another computer that has either Windows XP, Vista , or Windows 7 on it. If it doesn't automatically detect and install it on that one then the flashdrive is dead.
If you have an older operating system then go here to download the driver:
http://www.sandisk.com/sandisk-support/driver-download-wizard
May 15, 2012 | SanDisk Cruzer Micro 8GB USB 2.0 Flash...
My flash dive is not work.it can't do anything
But if you have an older operating system then go here to download the driver:
I bought a TP-LINK TLWN7200ND adapter, but it doesn't detect any 802.11b/g router, even with the latest version fo the driver for Windows XP. How can I fix it? Does only work with TP-LINK 802.11n...
i have used a similar adapter on windows 7 as well as on ubuntu 10.04 (linux), and it detects it upon restart without any external drivers.
try on a system with any of these to confirm that the adapter is good. this could be a hardware fault.
also, try changing the card slot as there could be a problem with the slot.
if it works fine on these, then make sure you are using the correct drivers (the ones exactly for this device and not for another similar device)
Jun 08, 2011 | TP-LINK TPLink Tp link Tl wn7200nd 150mbps...
I have a WUSB54GC ver. 3 wireless card, that my windows XP system will not detect. I see the card listed in the Device Mgr. with a ?, but I have tried several drivers & none seem to work. I also set...
The driver is listed as available at:
http://homesupport.cisco.com/en-us/wireless/lbc/WUSB54GC/download
It is at the bottom of the list.
Good luck, I hope this works for you.
Mar 08, 2011 | Linksys (WMP54GS) 802.11g/b Wireless...
Hi all, I'm trying to install a cable card for internet access in my Compaq Presario 1210 Laptop (Pentium 150 MHz, 64 Mb Ram, etc). So far I have tried several ones but without success. The laptop won't...
When you purchased the network-adapter, did it include a CD-ROM with device-drivers for Windows 98? Did you install those drivers?
Many "new" network-adapters include software that *ONLY* supports newer versions of Windows (XP/Vista/7) and no longer include support for Windows 98/98SE/NT/2000.
Look on eBay for another 3COM adapter, since that adapter worked for you.
Sep 01, 2010 | HP Compaq Presario 1210, 1210CA, 1210EA,...
Is Hi-speed USB 2.0 5-port PCI card compatible with Windows 7 and is there a driver available
According to belkins wweb site there is no Windows 7 driver or support for this card. From what I could find on else where it should just work with Windows 7. If you have the card installed and it is not being detected by Windows 7 I would remove the card with the system powered off. Turn it on so it "notices" that its no longer there, then power off and put the card back in, in another slot if you have one. turn it back on and it should detect it.
Mar 21, 2010 | Belkin Hi-speed USB 2.0 5-Port PCI Card [...
PC Windows xp wont detect networks: PCI 802.11 WN5301A
hi, try to press the register/discover button on your router so as to make your computer able to detect the network or get the latest driver update for your wifi dongle/card
Jan 13, 2010 | Computers & Internet
My speed stream wireless pci adapter does not work. any time it is enabled it restarts the computer
Hi, you need to follow these steps:
Remove Adapter and Reboot.Download the correct software for your Adapter. For example, there are two versions of the SS1024 driver and they will not work with the wrong adapter.Install the network adapter and reboot.When windows 98se asks you for the location of the driver, browse to the directory in C:\ and select it.From then on, use windows 98se to manage your connection.I hope, it will work for you.
Cheers
John
Ask for any tech Query: +1 (844) 355-5111 (toll-free)
Apr 17, 2017 | Siemens Efficient Networks SpeedStream...
My vga card is recognized but no working
if you have the disc with the drivers for your video card i would go to device manager click on the + sign next to display adapter ,right click on the video card and remove or uninstall it ,then reboot pc,when windows auto detects new hardware , sellect have disc, and insert driver disc,.....(if this is what you have done already with no luck ) then when windows detects new hardware ,close it and run the driver software from the disc,if you can't run the driver disc, windows will load the generic driver, . if you are not able to load windows normally, start windows in safe mode (press f8 when booting up and when you get a menue sellect safe mode) to remove display adapter, this has helped me in the past
good luck
Feb 20, 2008 | Computers & Internet
NEC USB 2.0 ( ) Laptop PCMCIA CardBus PC Card Adapter (USBP2D20) Serial Adapter Logo
424 people viewed this question
Top NEC Computers & Internet Experts
Ekse
Steven Wander
Steven Wander
Thomas F. Schneider
Are you a NEC Computer and Internet Expert? Answer questions, earn points and help others
