Question about Nokia 1600 Cellular Phone
Phone wont turn on or charge
My nokia 1600 does not charge when i plug it in and it wont turn on. Help me! PLEASE! i cant get a hold of my friends or anything or my parents when they have to pick me up from golf
    Sergeant:
  • 452 Answers
Try another battery in ur handset or ur handsets battery in other handset u will find where the exact problem is ? for more support contact nearest service centre
Posted on Oct 22, 2007
How can short directly charge line to batry
Posted on Jan 08, 2012
    Problem Solver:
  • 6 Answers
Either your battery is loose or battery connection is worn.try a different battery if you can.I have heard of a trick but have never tried it.i have heard that if you put a completely flat battery into a freezer bag and put it into the freezer overnight,then charge it up totally the next day,that it should work.no harm in trying i guess! :))
Posted on Sep 07, 2007
SOURCE:
How to fix my nokia 110 ? it only flash white in the screen and suddenly off. . please help
Dear friend,
Your possible causes are:-
1. Its happening because your battery is not geting charge properly, and it gets discharge as soon as you switch on your mobile. So, make sure your battery is getting charge properly.
2. Make sure your battery is properly touching the pins of your mobile, clean the pins of your mobile with cotton and terminals of your battery also, then connect it properly.
3. Since your mobile is old, it has grown problem in internal I.C., to rectify this go to some mobile reparing shop or nokia service centre. They will fix your problem!
Regards,
Priyank Abhineet.
Oct 29, 2012 | Nokia 1100 1600 2310
How to unfreeze my nokia lumia 900
Mine just done the same thing all you need to do is hold down the off/lock button for at least 15-20 seconds then the screen should turn black which means you can turn t back on again and It should work.
Jul 27, 2012 | Cell Phones
Dear sir my nokia 1600 not charging
there are few options by which this problem may rise .
* Old battery will not charge if its bulged. so get new 1 * Check if the charging plug in side th mobile has not broken. * There mite be a short connection with the pin which will not charge the battery. * take battery out keep it in sun for 5 mins and use it.or rub in 1 direction. mite work. * If there is a problem with the board , check below not-charging-1-300x203.jpg
1600 Not Charging Problem
1600 Not Charging Problem 1
1600 Not Charging Problem 2
1600 Not Charging Problem 3
Thanks for the ratting Good luck
Dec 22, 2010 | Nokia 1600 Cellular Phone
Nokia phone
First Option:Please change The Phone Bettery and charger and check The check The Phone charging
IF Charging Problem will Not Solved So
Secend Option:Your Phone charging IC Fault SO Please change charging IC And charging Problem will SOlved
Jul 08, 2010 | Nokia 1600 Cellular Phone
Nokia 1600 not charging please tel me this solusion
Check your charger. try to plug this charger in other compatible phone.if it charges the other phone, then the ping in your phone has gone bad. if it doesnt charges the other phone, then your charger has gone bad.
Nov 23, 2009 | Nokia 1600 Cellular Phone
Forgoten security code
I want know that nokia 1600 charging problem.
Jan 30, 2009 | Nokia 1600 Cellular Phone
My phone wont turn on
maybe your sim is block if you have a sim card you can see the label of sim card p,u,k pin code try to type a p,u,k pin code thats all....
Nov 17, 2008 | Nokia 1600 Cellular Phone
Nokia 1600 charging problem
the fuse is burned go to a cell phone service and have them replaced .
May 26, 2008 | Nokia 1600 Cellular Phone
Nokia 1600 Cellular Phone Logo
140 people viewed this question
Top Nokia Cell Phones Experts
jonathan mariano
jonathan mariano
Ekse
