Question about Samsung Yepp YP-F1X MP3 Player
Screen Stuck! My screen is stuck on "Charging" even when disconnected from headphones or the charging cord. Any ideas?
Mine did the same thing, but I fixed easily. Wait till it turns its self off then plug it back into the computer. If all is good it should say that it is charging. Then unplug it to see if it turns back on. Hope it starts!
Posted on Sep 03, 2007
Iphone 4s screen and battery replacement now only powers on thru cord and base
Your new battery might has some issues. Put your old battery back on and try your charging cord and base. If it starts charging your old battery; it means new battery has a problem. If old battery doesn't charge too; i suggest you to try a working charger. If it still doesn't response; most probably during replacement process; you damaged pins of your phone's charging port connector.
If broken pin is at above red circuled area; you are lucky because it has price around $5. But if broken pin is at motherboard side, it may cost you around $50 or more due to motherboard repair.
Nov 19, 2014 | Cell Phones
Asus tablet
buy a new phone
May 19, 2013 | Cell Phones
Sony readers PRS 600 stuck on a page in the middle of a book and will not go forward or back, when I tried to reset it, it did not work and the screen got messed up.
This happened to me. Reset would not work, nor would the on/off switch. Although the reader appeared to be 50% charge, I tried to charge it for hours and even overnight, but the charge indicator did not move. In the end, I disconnected the charger and abandoned the reader. The next day I looked at it and the charge indicator indicated 100% charge and I was able to switch off the reader and then use it normally. So it might be worth charging the reader even if you can't tell it is charging, then leaving it for a day and coming back to it. Worked for me.
Jan 31, 2011 | Sony Reader Touch PRS-600
No matter what we do its stuck on the main screen! its not being registered on the computer when hooked up with usb cord.
do not hook the mp3 player to the computer until you are in your windows media player or equal program. disconnect it if it has been charging, re connect when media player is active.
Jan 03, 2011 | Mach Speed Eclipse 180 MP3 Player
Samsung yp-9j stuck on charging
its frozen. look online and see how to unfreeze it
Sep 04, 2009 | Samsung YPT9 Digital Media Player
Ipod screen says connected eject before disconnecting shows picture of charger but won,t do anything the time is stuck the battery isn,t charging help
I had a temp problem like this too! I found that by purchasing the plug adaptor, it got around to charging the battery on the iPod eventually. Check that the points of the USB cord at either ends haven't been bent or are at least clean.
Apr 05, 2009 | Apple iPod nano
Problem with screen
When things freeze up like this, usually a Firmware reload is the thing to attempt. You should have a disc with the player - follow the instructions carefully.
Aug 27, 2007 | Sony NW-A1000 MP3 Player
YPF1 512 mb
problems with the flash memory, memory got corrupted somehow while downloading the files, there is not much you can do, try to connect back to PC and format the player, if it will show there, but it probably won't
Aug 18, 2007 | Samsung Yepp YP-F1X MP3 Player
Yp-f1x
Reset first, then Try this: disconnect the player from the computer, turn it off, hold in the volume + button, and reconnect the player to the computer while holding the volume + button in. Keep holding the volume + button for an additional 5-50 seconds. Windows should eventually go into recovery mode and revive the player- it will pop up a window that says Found New Hardware Wizard.
If the msg persists, go ahead and call Samsung for instructions on repairing the player. I do not see a repair or recovery tool for that model on their website.
Samsung Yepp YP-F1X  MP3 Player Logo
81 people viewed this question
Top Samsung Audio Players & Recorders Experts
Marvin
Marvin
Are you a Samsung Audio Player and Recorder Expert? Answer questions, earn points and help others
