Question about Sony Grand WEGA KF-50WE620 Television
Sony KF-50WE620 Is it possible to change the lamp on this unit without a technician Also I can't seem to find any manuals on line for assistance with this
    President:
  • 3,130 Answers
Go here for the owners manual for this TV set. http://esupport.sony.com/US/perl/model-documents.pl?mdl=KF50WE620&LOC=3 Look on page 15 of this manual, it shows and tells you exactly what to do. Good Luck
Posted on Aug 14, 2007
SOURCE:
How do I reset the Lamp Timer on a Sony Wega KF-50WE620 TV?
Hello.
if you want to reset lamp timer on sony grand wega 50WE620...press menu on remote control then go to the setting you will find the setup button then press setup you will see the lamp replacement-start----yes and menu...
Thanks for using fixya
Caseytech
Jun 29, 2011 | Sony Grand WEGA KF-50WE620 Television
My Sony Kf-50we620 TV seems to have lost its brightness. is this something that can be fixed?
Needs a new lamp or an optical block rebuild. May aslo have dust on the parts inside making the picture darker than normal
Feb 01, 2010 | Sony Grand WEGA KF-50WE620 Television
I have a Sony kf-50we620, It started having problems this week. Sometimes, not always, I turn it on, the green light flashes and the TV will eventually start but it takes over 2 minutes to start. I will...
Its symptoms of weak lamp that need to be replaced.
How old is this TV and did you replaced its lamp recently?
lamp replacement is easy and would be written in user manual. Please buy Sony original lamp for TV safety.
Thanks.
Jan 15, 2010 | Sony Grand WEGA KF-50WE620 Television
KF-50WE620 Green light blinks (no image) lamp light blinks red
Your owner's manual for the television will contain a troubleshooting section that will describe the blinking codes for the various lights, and what they mean.
However, in your case, it probably means the light is burned out.
The bulb on my TV tends to burn out about every 16 months (I watch TV for many hours per day, so your experience may be different). If your TV is still under warranty, I would suggest you contact the store where it was purchased, or contact the manufacturer.
Jun 20, 2009 | Sony Grand WEGA KF50WE620 Television
Sony KF-50WE620 - 5 Flashes
5 blinks code shows problem with Lamp Drive circuit (ballast supply) and / or Lamp itself.
How old is this TV and have you replaced lamp before?
May 31, 2009 | Sony Grand WEGA KF-50WE620 Television
5 flashes indicates ballast malfunction. 4 flashes indicates fan not working. I would replace the big fan in the back because it is a common failure for this model. But befor this check to see if the lamp door is warped from overheating. If it is the wiring on the balast good be burnt and the light engine could be damaged.
Feb 02, 2009 | Sony Grand WEGA KF-50WE620 Television
SONY KF-50WE620 LAMP
A-1606-034-B is correct. Make sure you are buying a Sony Original replacement though. A lot of knock-offs are not correct.
Sony KF50WE620 Replacement Lamp
Jan 31, 2009 | Sony Grand WEGA KF-50WE620 Television
Need to change lamp
I need to change lamp for sony KF-50we610 TV. Just got the new lamp and ready to change.
Thanks.
Aug 09, 2008 | Sony Grand WEGA KF-50WE620 Television
Sony KF-50WE620
DEPENDS ON THE # OF FLASHES IF ITS 3 THEN YOUR LAMP HAS BLOWN IF ITS 6 THEN YOUR THERMAL FUSE IS BLOWN THIS IS 2 OF THE MOST COMMENT PROBLEMS
Jul 31, 2008 | Sony Grand WEGA KF-50WE620 Television
Televison & Video Logo
258 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Steve Allison
Steve Allison
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
