Question about Microtek SCANMAKER I900 Flatbed Scanner
No picture, scans coming out white
Hi, So i preview the scan bed and it just comes up white. The scanner was working perfectly a few days ago so I'm at a loss....also its making all the right noises and the lamp is on but it only moves 80% across the glass than stops and comes back. please help!!
  • 35 Answers
First reinstall drivers , If problem not solved go to ur provider to repair your scanner . Thank You.
Posted on Aug 14, 2007
SOURCE:
When scanning a color picture it comes through in black and white what am i doing wrong?
Change the Options on your HP Scanning Software to Scan in Colour or Else:
In this case u have to scan and Preview the scanned images using Windows Photo Gallery.....
Click on File and Click on Import from scanner or Camera...........
Then again click on Import...........It will scan and preview the Applications to u....
Thanku.......
Good Luck!@@!
Sep 23, 2011 | HP Deskjet F4140 All-In-One InkJet Printer
HOW TO SCAN A DOCUMENTS BY USING CANON PIXMA MP145?
Hi
Scan the document using Canon PIXMA its very simple follow the mention below instruction to scan to document, picture & email.
  • Turn on the computer and thescanner.
  • Open the lid of the scanner andplace the photograph face down on the glass scanner bed. Close the scanner lid.
  • Click "Start" on the computer.Click "Programs." Double-click "ArcSoft Photostudio 5.5."
  • Click "File" after Arcsoft programopens. Click "Select Source." Click on the scanner model.
  • Click "File." Click "Acquire." Thescanner will begin to scan the photograph.
  • Click "Select Source." Click"Preview." A preview of the photograph will appear on the screen.
  • Drag the selection box to select theentire photo to scan or a portion of the photo. To crop the picture, click anddrag one corner of the selection box. Adjust the position of the photograph onthe scanner bed if the photo is on an angle.
  • Click "Scan" to begin the finalscan. The scanned photo will open in PhotoStudio editing window.
  • Click "File." Click "Save." A "Save Picture"dialog box will open. Type the name of the picture in the "File Name" field.Click on the arrow located on the "Save as Type" pull-down menu to choose theformat of photograph (JPEG or GIF are the usual formats for internet use).Click "Save." The photograph is now saved on your computer.
Sep 01, 2011 | Canon PIXMA MP150 All-In-One InkJet...
Preview results in random croppings, rotations, and added pics
Hi I'm having a similar problem and haven't managed to fix it. Have you solved it? Thanks Martin
Mar 07, 2010 | Epson Perfection 4990 Flatbed Scanner
I have a Dell All-In-One PictBridge Photo 924. I
Open Dell All-in-one center, keep the picture on the Scanner bed and click on scan and choose a location to save the picture once the scan is completed and the preview is visible. Alternatively, a simpler way to do this is to Open MSPaint, click on File and click on Import from Camera or Scanner. Choose the kind of picture you want to scan and confirm scan. Try experimenting with options to experience scanning effects and image quality.
Good Luck!
-Abhishek
Nov 03, 2009 | Dell 924 All-in-One InkJet Printer
My scanner will not scan negatives
Most scanners aren't designed to scan negatives. (Of course the manufactures would never want to tell you their product CANT do something).
Flatbed scanners typically have a light on one side.
To scan negatives properly, you need to have a scanner that has a backlight, or a second light in the bed's lid that you fold down.
Canon USA, Inc. make a few flatbed scanners that have backlights. They range from $60 to $180, depending on the features and resolution you want to pay for.
Please see the below link. This is a more expensive one, but is shown just so you get the idea. In the pictures, note specifically in the picture that shows the lid open, how the white backing on the lid can be removed from a clip at the top. Underneath, is the backlight and clips designed to hold negatives in with the included frames.
http://www.newegg.com/Product/Product.aspx?Item=N82E16838111015
May 04, 2009 | Epson Perfection V200 Flatbed Scanner
Problem with my A3 flatbed scanner
The preview, if it is thumbnail picture, it is difficult ti decipher. Dont worry about that. Pencil drawings are very light and needs higher contrast. Try a few options and you can select the best one. If you scan a pencil drawing in grey, it may appear light and also file size will be bigger.
S. Mohan
Jan 05, 2009 | Mustek A3 USB Flatbed Scanner
After preview with correct colour, print comes up pale colours.
Have you confirmed that the scan you are trying to print is good?
Dec 13, 2008 | Canon CanoScan N640P Flatbed Scanner
The scanner copies three photos as one
Assuming you're using the Epson Scan software, select Home or Professional mode and click Preview. When the preview image appears, draw a marquee around each of the three photos. (Note that as you draw each marquee the number beneath the little image of a marquee - the white square with the dotted line around it - increases.) After drawing your marquees, click the All button, then click Scan. The scanner should make three separate passes in succession, producing three separate images.
Nov 24, 2008 | Epson Perfection V200 Flatbed Scanner
Epson Perfection V100 Photo flatbed scanner
I would not think Norton is the problem but one can never be sure - Uninstall Norton to prove one way or the other Then come back
Aug 25, 2007 | Epson Perfection V100 Flatbed Scanner
Microtek SCANMAKER I900 Flatbed Scanner Logo
162 people viewed this question
Top Microtek Office Equipment & Supplies Experts
Alun Cox
Thomas F. Schneider
Are you a Microtek Office Equipment and Supply Expert? Answer questions, earn points and help others
