Hoover U5753-900 WindTunnel Bagless Upright Vacuum Logo
Posted on Mar 18, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
While vacuuming, debris spits out the back.
While vacuuming, little pieces of dust, dirt, litter spits out the back of the vacuum and hits my feet.
Anonymous
Level 2:
  • Expert 76 Answers
  • Posted on Apr 19, 2009
Anonymous
Expert
Level 2:
Answers
76
Questions
15
Helped
33416
Points
114
That's normal. try lowering the heght adjustment
  • Marissa
    Marissa May 27, 2014
    my height is as low as it goes, now what?
Why is it not picking up dust and dirt from carpet. pipes clear. Can you help
How to Fix a Vacuum That Lost Suction - Quick and Dirty Tips
www.quickanddirtytips.com/.../how-to-fix-a-vacuum-that-lost-suction
Oct 3, 2013 - It's true, a vacuum that doesn't have suction is not very useful ... The first and most basic reason a vacuum isn't picking things up off the floor is if the ...The lower your carpet, the closer the dial or lever should be to the bare floor setting. ....it off and shaking the dust off put the power right back in my vacuum!
Common Vacuum Issues - and what you can do to solve them
blog.mchardyvac.com/.../common-vacuum-complaints-what-you-can-do...
Oct 4, 2013 - Your vacuum's job is to pick up dirt, dust and debris - so when it stopsdoing ... Often when your machine is not picking up it is due to loss of suction. If yourvacuum cleaner turns on but won't pick up on carpet or bare floors, ...
Is your vacuum cleaner not picking up dirt and debris ...
https://www.mrright.in/.../is-your-vacuum-cleaner-not-picking-up-dirt-a...
Jan 7, 2015 - But many times it does not pick up or suck the dust as effectively as it is supposed to do. ... If the vacuum cleaner fails to pick up dirt and debris and has no ... Deep clean your expensive carpets to restore their original look.
Jan 24, 2016 • Vacuums
1helpful
Vacuum picks up some dirt and debris but not all, and spits some back out?
Some blockage at the pickup or in the hose if it uses one---dirt etc being kicked back out is a clear sign of this----if it has a tube check that first, and if a head with turning brush do not miss looking for a blockage there.
3helpful
What causes a vacuum to make lots of dust and throw back out what it vacuumed
It sounds like the airducts that lead to your dirt chamber are clogged. The dirt can't get through to the dirt cup so it spits it back out and blows dust everywhere.
1helpful
My vacuum is spitting dirt as my feet and legs. Even when the filters and canister are clean and empty.
if you are using it on any surface that isnt carpet put the height setting knob to the lowest setting it should no longer spit dirt at your legs and feet
2helpful
Vacuum is spitting dirt and debris out the back--what can I do?
the first thing you should do is clean out the container then check the filter if it looks dirty with a lot of dust it probably needs replacing.
check the hoes for dirt that might stick up.if the problem continues it needs a service.
My hoover vacuum spits out dirt particles as I vacuum!
the vacuum is clogged somewhere the brush roller is just kicking stuff around, as it cant get into the suction port
2answers
Spitting Out Debris
the hose from brush go to the bag need to check for blockage you have to open there hose to clean
Top Hoover Vacuums Experts
Mike Cairns
Mike Cairns
ZJ Limited
ZJ Limited
Are you a Hoover Vacuum Expert? Answer questions, earn points and help others
