Ipod disabled My I pod is disabled
  • 27,725 Answers
Like all electronic devices, iPods sometimes freeze and become unresponsive.
Sometimes iPods lock up when they're dropped on the ground or come in contact with water, but less destructive accidents may also cause them to stop working.
All versions of the iPod have a way to reset their hardware should they stop playing music or refuse to turn off.
Check the "Hold" switch on the top case of your iPod to be sure it isn't activated.
An iPod will appear frozen and unresponsive if this feature is activated.
A lock symbol will appear on your iPod's screen if it is in Hold mode.
Switch the "Hold" button on and off once. Place one finger on the "Menu" button and another on the center button.
Press both buttons at the same time and hold them for up to 8 seconds.
Release the "Menu" and center buttons once the Apple logo appears on your iPod's screen.
Try releasing the buttons and pressing and holding them a second time if the logo does not appear, as it can sometimes take several tries to reset a severely frozen iPod.
Press and hold the top button and the center "Home" button on a frozen and unresponsive iPod touch to reset it.
Hold the buttons for at least 10 seconds and wait for the Apple logo to appear on the screen, then release the buttons.
Connect your iPod to its powerblock or a computer if it is still frozen.
Wait 5 minutes and then try to reset it.
Sometimes an iPod can appear frozen when its battery runs out and just needs a few minutes of power to start working again.
Posted on May 15, 2013
SOURCE:
I pod disabled due to wrong password forgot it
If you have the original computer it was synced to, you can plug it in and it should allow you more chances to try password. If not known, you will have to restore it using that computer. Shut down iPod, with iTunes on and cable plugged into computer, WHILE HOLDING THE HOME BUTTON DOWN, plug in cable into your iPod .... it will turn on, keep holding the home button for 10 seconds and then it will take you to the restore screen. iCloud password will be required if iCloud was loaded.
Feb 05, 2014 | Apple iPod Audio Players & Recorders
I pod touch disabled
if you had all you info saved on icloud you can get it back from there.
when you connect to iTunes you will be able to sort the iPod out but you will loose all your data.that's where icloud comes in. it happened to me and I lost info but got ipod back
Mar 06, 2013 | Audio Players & Recorders
My i pod is disable how to repair my i pod
hi there,
first of all connect your ipod to your pc/mac and start itunes. if your ipod has a software problem, itunes will state this and you can restore your ipod to factory settings. this will update its firmware to the newest version and all your data, apps etc. will be lost.
hope this will help you!
greets, b
Mar 01, 2011 | Apple iPod touch
My i pod is showing i pod is disabled and connect to itunes so now how can i fix it ?
Step 1: Connect your iPod to your computer and start up iTunes. Step 2: On the left side, select your iPod. Step 3: On the right side, scroll down to "Restore"
These steps will unlock your iPod, but it will also re-sync everything you have in your iTunes library on there. It is the only working method.
Feb 26, 2011 | Apple iPod touch
How to erase or reset my i-pod touch. my i-pod
  1. Plug the iPod Touch into your computer.
  2. Step 3 Power on the iPod Touch.
  3. Step 4 Press the "Home" and "Sleep/Wake" buttons together for 5 seconds until the Apple logo appears.
  4. Step 5 Release the "Sleep/Wake" button but continue holding down the "Home" button. The iPod Touch should reboot, and iTunes will notice the iPod Touch in recovery mode.
  5. Select "Restore" and follow the instructions to finish restoring your iPod Touch.
May 25, 2010 | Apple Earphone Headphone for i Pod iPhone...
My daughter was playing with my i pod touch.i cant get it open.i do have a passcode.but is says.i pod is disable.how can i get it unlocked
The iPod touch was disabled because the wrong password was entered too many times.
Connect the iPod to the computer you normally sync it with. After that you will be able to unlock it.
Nov 14, 2009 | Apple iPod touch
Pod is disabled
Use the Five Rs to restore the iPod. You will lose the data that is currently on it if you restore but you can always re-sync the data to the iPod. http://www.apple.com/support/ipod/five_rs/
-=/ Daft Tech /=-
Oct 23, 2009 | Apple iPod touch
I pod is disable , unable to unlock using password
  1. Power off the device (Press and hold the Sleep/Wake button for a few seconds until the red slider appears, then slide the slider. Wait for the the iPod touch to turn off.
  2. Press and hold the Home button while reconnecting the USB cable to iPod. When you reconnect the USB to iPod, the device should then power on.
  3. Continue holding the Home button while iPod starts up. While starting up, you will see the Apple logo.
  4. When you see "Connect to iTunes" on the screen, you can release the Home button and iTunes will display the recovery mode message:
  5. Restore and it'll download ~240mb firmware and you're done
Warning: you will lose all your data
Sep 22, 2009 | Apple iPod touch
447 people viewed this question
 Grubhead
Grubhead
Marvin
Marvin
