My Zanussi washer machine has stopped working. The power light is on but it will not run any cycles. I have been told the computer is broken but I don't know what the part is to order a replacement. Could anybody advise?
if computer is broken that is your timer dial not worth fixing sometimes as much as a new washer but it could be your interlock you can test this by closing door set machine to a programme hit the front of your washer to the right of the door as you look at it if not take lid of make sure power is off look down inside the front of your machine were your door seal is attached to the outer drum were u hit the washer on the inside will be your interlock switch replace that before paying out for a timer m8 more than likely that is the problem
I have a Zanussi 1200 washer dryer (WJD 1257 W) The cottons cycle gets stuck on 20 minutes and gives...
(More)
I have a Zanussi 1200 washer dryer (WJD 1257 W) The cottons cycle gets stuck on 20 minutes and gives an error message of e20. This is during the rinse cycle and the machine does not take in any water or the conditioner. When it is switched to say the delicates cycle it completes the rinse cycle. Any thoughts on how to get the cottons cycle working again?
the cycle stopped half ay through ive drained it and cleaned the filter but there is still no action...
(More)
the cycle stopped half ay through ive drained it and cleaned the filter but there is still no action the power light works but nothing else
when i turn the washing machine on, i can select the program i need, but when i press the start...
(More)
when i turn the washing machine on, i can select the program i need, but when i press the start button nothing happens, everything works on the display and i can select all the programs for washing and drying, there are no error codes coming up, just when i press the start button it beeps but does nothing, any ideas?
Add the things you own to your My Products collection and get product information, solutions to problems, manuals & guides, tips and how-to's, reviews & ratings and local repair service - all in one easy place.
