Question about Electrolux 23 in. ESI6104 Built-in Dishwasher
It seems to start, then stops after a few minutes..
The dishwasher (Electrolux ESI6104 built-in) starts, then stops after a few minutes, when I open the door there has been no water in the unit. It does this on every setting. I did notice that the washing tablet had popped out and burst (it's one with a liquid bit in it). Not sure that would be the cause. The water supply is not cut off from the mains as far as I can work out Thanks Jon
  • 641 Answers
Jon, check that the inlet water valve works(it is an electromagnet valve, located at the pipe's entrance to the machine)). If it doesn't work, test that it get power. In case it get power and doesn't work - You can easily open the valve and clean it (from scale or other dirt). Be aware you should disconnect the power cable from machine before doing it !!!! Check as well for valve's coil resistance. In case you have no resistance measurement - you should replace it for a new one. Good luck
Posted on Aug 13, 2007
Dishwasher wont fill up with water
When you start the dishwasher you have probably noticed that it first drains water and is very important to hear that drain pump running all the time or stops after a while? Why?
If the drain pump runs constantly then the fault is in the phase of "drain water" or is activated anti-flood system. Reset point of pressostat is not reached after max. 120secs. Programme stop and can be continued after error remedy by pressing the programme key.
If the pump is running for a while and then stops, then the fault is in phase "fill up water". Switchpoint of pressostat is not reached
after max. 60 secs.
Usually built-in dishwashers has anti-flood system that responds in the event of water in the bottom of the dishwasher. Such a case, find and repair water leaks.
Dado
Aug 06, 2014 | Electrolux 23 in. ESI6104 Built-in...
Elctrolux dishwasher won't start, display won't light. Any suggestions?
Good Morning Friend,
I understand your Electrolux dishwasher, model# EWDW6505GS, seems like it is not receiving power to the control panel. I suggest resetting your appliance, by either unplugging your appliance or shutting the power off at your home's circuit breaker, for 20-30 minutes. Restore power and try any cycle. If you are still not receiving any lights, I suggest contacting your local authorized technician for further assistance. They will be able to diagnose your appliance and determine what is causing your control panel to not have power.. Hope this is helpful.
-Best Regards-
WP
Jul 04, 2014 | Electrolux EWDW6505GS Fully Integrated...
My electrolux dishwasher will not start and no lights on panel
I understand that your Electrolux dishwasher, model# EDW5505ESS, will not start and the control panel seems to be dead. I suggest resetting your appliance, by either unplugging it or shutting the power off at your homes circuit breaker, for 20-30 minutes. Once power is restored, if the panel is still not lighting up, I suggest contacting your local authorized technician. I do not suggest trying to repair it yourself. There could be something other than the panel, which is causing the dishwasher to seem dead. The technicians will be able to diagnose your appliance and determine what is causing the panel to not light up. Hope this is helpful.
-Best Regards-
WP
May 16, 2014 | Electrolux EDW5505ESS Built-in Dishwasher
Start button won't work, but delay does
have you accidently turned on a safety feature stopping the machine from starting? or is the door latches closed fully, if opened slightly could be preventing the machine from starting. or maybe its just a faulty start button.
Jul 16, 2012 | Electrolux Frigidaire Professional Series...
My electrolux dishwasher will not start. lights on the panel are on but will not start
What to Do When the Dishwasher Won't Start - YouTube
? 5:43
https://www.youtube.com/watch?v=L-bMqVb9kX0
Aug 15, 2013 - Uploaded by doityourselfstan
I was stressing out because we could not afford a newdishwasher .... The power come on and the unit fills with water, but then does nothing.
Electrolux® Dishwashers - ElectroluxAppliances.com‎
Adwww.electroluxappliances.com/‎rating for electroluxappliances.com
Luxurious by Design, and Featuring the 30 minute Fast-Wash Cycle!
Dec 04, 2011 | Electrolux EDW5505ESS Built-in Dishwasher
Our dishwasher does not drain completely and leaves a bit of water covering the bottom at the end of the cycle. We tried running the disposal during the cycle to see if that clears a drain, but it did not...
this might help, i had same problem, right where the dishwasher hose connects to the disposal, it was partially blocked with grease, loosen the hoseclamp, pull off, and scrape it out.
Oct 13, 2010 | Electrolux 23 in. ESI6104 Built-in...
The rotary switch stops mid cycle. I then have to nudge it to finish the cycle, but with no hot water. Has the heating element gone?
cut the power and remove bottom toe panel there under tub there is a tstat this is proberly bad check with ohm meter
Nov 05, 2009 | Electrolux 23 in. ESI6104 Built-in...
Dishwasher will not start
Go to your electrical panel and turn off the circuit that feeds your dishwasher. It will also turn off the clean light. Wait three minutes and then turn the circuit back on. That should reset your machine.
Apr 07, 2009 | Electrolux Frigidaire Professional Series...
Dishwasher leaves taste on glasses
hi there sounds like your rince aid level is set to high, the adjustment for this is located under the rince aid filler cap, try setting to position 2
Dec 13, 2007 | Electrolux 23 in. ESI6104 Built-in...
Electrolux 23 in. ESI6104 Built-in Dishwasher Logo
436 people viewed this question
Top Electrolux Dishwashers Experts
Mike
tglynn
Level 1 Expert
Are you an Electrolux Dishwasher Expert? Answer questions, earn points and help others
