Question about Sub-Zero 632 / S
Refrigerator not cooling top shelf
I have a 10 year old Sub-Zero side by side refrigerator - freezer. About two months ago, the top shelf (top 1/3) of the refrigerator became warm compared with the bottom. The lower shelves remain cool but even when the thermostat is turned to the coldest setting, the top shelf remains relatively warm. There is also some new ice build up in the refrigerator section on the back wall, about at the level of the vegetable drawers. The freezer appears to be working fine.
  • 175 Answers
It sounds as though you have a fridge that is low on freon. If the ice is appearing mostly to the left, then thats surely your problem. if it goes all the way across, you may have a bad evaporater fan motor, fan motor switch, bad cold control, or just a door that isn't closing or sealing properly. If its the ice mostly to the left side, it probably means your evaporater is leaking the freon. I am assuming you have a model that has a cold control on the back wall, not the electronic display by your description. If your unit is less than 12 years old by the installation date, the part will still be under warranty (sub zero has an unmatched 12 year sealed system parts warranty) but the labor and freon will not be. The repalcement of that evaporater in my area usually runs about $450 with labor, freon and trip all together. It is a repair you cannot do unless you have an acetlyn torch and some silver-soldering/ brazing ability. If your model is in fact the newer style with the electronic temp display, call sub zero up (the # is on the model/serial tag in the door jamb) and tell them wahts going on. If it is in fact an evaporater leaking on this style, they will most likely pay the bill for you even if its well out of the 5 year full warranty. If you want to know for sure, remove all the shelves, then remove the cover over the lights. Then if its electronic remove the 3 screws holding the top of the back panel and tilt the panel out to you and pull it up and out: if its a dial type, remove the 2 screws holding the fan cover and then tilt the back wall out to you and lift it up and outwards, but not too far as it wil pull the wires of that control knob (cold Control) Look at the coils back there and see if the coils are frosty. If they are only frosty on the upper left of the coil, its low on freon and needs an evaporater. if its frosty all the way across, top to bottom, you need a cold control, or possibly a fan or fan switch. Hopefuly you can wade through all this. Just post back if you have any questions. Good Luck!
Posted on Aug 16, 2007
How to replace defrost timer
a bad defrost timer can be checked with a multi meter
Sep 08, 2014 | Whirlpool Refrigerators
Is it normal for warm air to blow out of the fan at the top of a side by side sub zero. Its over 20 years old and we recently had the compressor replaced on the freezer side.
warm air will blow out from the condenser fan which is in the same area as the compressor.
There should be no warm air inside the freezer of fridge.
Jul 22, 2011 | Sub-Zero 650 / O Bottom Freezer...
I have a 20 year old side by side sub zero. For the last few months i have had problems keeping the temp even in the refrigerator side, either freezes or gets too warm. Now it wont get colder than 45 or...
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
Check out these tips...they can help you figure out whats going wrong with your refrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator Defrost Timer Problem
Water Running in refrigerator from Freezer
heatman101
Sep 09, 2010 | Sub-Zero Refrigerators
Freezer does not work
Most model numbers are located in places like the photo shows below. It may be the thermostat itself causing the problem with freezer, yet I don't believe I have seen a refrigerator running without using the freezer to cool the refrigerator section. I guess anythings possible. Let me know, Thanks, Sea Breeze
Apr 21, 2009 | Sub-Zero Bottom Freezer Refrigerator
Top shelf of old sub-zero refigerator 60 degrees, bottom shelf OK
u may have a defrost problem it would be worth paying for the service call if something simple like defrost or a fan would still be more than 200 but worth it
Mar 18, 2009 | Sub-Zero Bottom Freezer Refrigerator
Sub-Zero 532 (About 18 years old)
First do the simple things like cleaning the condensor coils and turning the defrost timer a few times, also check the evaporator motor or just listen to the fan by opening the freezer door. Also check the light switch, make sure it turns the light off every time you close the door.
Jun 26, 2008 | Sub-Zero 632 / S
Sub-Zero 511 Freon Leak
replacing leaking evaporator on Sub Zero R134A
Jun 22, 2008 | Sub-Zero 30.1 cu. ft. Cabinet Depth...
Sub zero 650 fidge holding at 53 degrees
That depends on if your model has a five or ten year warranty on the compressor. Your problem may not be warranty related. Check and see if the condenser is clean, check for a frozen cooling coil.
Jun 02, 2008 | Sub-Zero 650 / O Bottom Freezer...
Older subzero side by side not cooling
At sixteen years old it is almost through its life span. A change in ambient temperatures will change internal system pressures. Make sure the condenser is cleaned well. Use a vacuum cleaner to clean off the condenser, then blow it out with compressed air. Even though a condenser looks clean on its surface fins there may be dust down in between the fins.
May 05, 2008 | Sub-Zero 690 Side by Side Refrigerator
Sub-Zero 632 / S Logo
706 people viewed this question
Top Sub-Zero Refrigerators Experts
Charles T Nevin
Charles T Nevin
Sal De
John Tripp
John Tripp
Are you a Sub-Zero Refrigerator Expert? Answer questions, earn points and help others
