The laptop is not even a year and a half old. it mostly sits in one spot and hasn't been thrown around or dropped. the screen will flicker then sometimes go dark. if its light enough in the house, i can see the screen hasn't gone black, it just seems like the light went out, as i can still see the desktop (or whatever window i was using). the flickering until you try to stop it. sometimes almost closing it shut stops it, but it can start up again when opening it back up. closing it completely shut sometimes helps as well.
Sounds like you back light or LCD inverter is going out, If you don't hear a whine then it is just the LCD screen, if you hear that whine then it is the inverter. An inverter will run 40-60 dolloars as opposed to and LCD screen which usually start around 100 and go up...
Hope this helps, if so please rate my solution accordingly.
Since it seems as though you dont move it very much you might be able to hook an external monitor up to it and using the Fn+F5 button swap it to use the external monitor untill you can get it repaired.
thank you!!! i wouldn't say there is a whine, but it does seem like the fan (or something that has a vent) has become extra loud lately. i'll seek out a repair guy with your advice.
CA. northern, between Sac and SF.
