Question about Maytag MZD2768G Side by Side Refrigerator
Frige problem freezer works, frige not cooling(no air (cold) blowing inside frige) all lights and other functions - OK.
  • buddyf Dec 31, 2007
    We defrosted the freezer. When we plugged the unit back in, it will not start up.
    Novelist:
  • 87 Answers
This is almost a word for word common problem. On frost free fridge freezers of this type all cooling is generated through the freezer side and is merely forced into the fridge side through airflow. Therefore if you have a problem with the fridge you have a problem with the freezer section. The most likely cause is that the coil is frozen up. We would always suggest defrosting unit overnight in case it was simply a door left ajar being the cause of the fault. If the unit then pulls the fridge temp down and it was not the door ajar then you probably have a defrost problem (heater or defrost thermostat, or defrost timer). If it fails to pull the fridge temp down on restarting then it could be the fan or part of the defrost circuit or even possible the cooling circuit. The normal outcome after defrosting is that the temp will drop in the fridge due to air circulation improved, which will probably remain cool for 2-3 weeks until the coil becomes frozen again. On either result I would contact an engineer on the 2nd failure occurrs so that the engineer can establish the exact cause. Hope this helps.
Posted on Aug 28, 2007
SOURCE:
Amana frige freezer only cool not cold what could be the problem
check ur settings on the air flow control knob and the cold control knob? are they both set to high? are the door seals working ok no air leaks. is the fan running? l;astly check the thermistors?
Mar 09, 2015 | Amana Refrigerators
My frige & freezer do not cool,light & freezer fan run,compressor & coil fan do not run,air is blowing out of air vent in freezer,no cooling at all
If the compressor isn't running, the refrigerator or freezer won't cool - period. Hopefully, by now, you've had a repair technician come and troubleshoot the problem.
Aug 06, 2014 | Frigidaire Gallery GLHS66EJSB Stainless...
Fridge is not getting cold even though the thermostat is at 5
Most friges take cool air from the freezer with a fan to cool the rest of the unit. I am not familar with your model but there should be a fan somewere in the back of your freezer. Also make sure you have space in back and to the sides of the fridge for air flow.
Jul 24, 2013 | Tecnik Built Under Larder Compact...
Frige freezer works fine but frige does not. 6 yr old kenmore 596.75509400 model
Check out these tips...they can help you figure out what is going wrong withyour refrigerator and why it is not cooling
Refrigeratornot Cooling or Fridge not Cooling
How to Defrost Refrigerator DefrostTimer Problem
WaterRunning in refrigerator from Freezer
Refrigeratoror Freezer not Cooling or Getting Cold
heatman101
Apr 25, 2011 | Refrigerators
Frig not cooling , you can hear it running but not getting cold, freezer works.
SOUNDS LIKE THE FAN MOTOR IN FREEZER IS NOT WORKING . THAT WHAT BLOWS THE COLD AIR INTO THE FRIGE
Sep 21, 2009 | Refrigerators
Freezer and frige not that cold
The fridge gets its cold air from the freezer through a vent(damper) between the freezer and fridge.The fan in the freezer blows air through it. There is a flap you adjust with the fridge temp. control. Make sure it's opening and closing when you adjust the fridge temp ..
If the evaporator coils behind the back panel of the freezer are icing up because of auto defrost failure that will stop the circulation of cold air and eventually affect the freezer too.
check defrost timer, defrost heater, defrost thermostat. In most newer models the timer has been replaced by an electronic control board. If the heater and thermostat are ok it’ll be the control.
You can turn the defrost timer till it clicks and everything shuts down. The heater should now come on. If it does, replace the timer. If it doesn't, check the heater and defrost thermostat. Turn the timer again till everything starts back up to end the defrost cycle.
How to check everything
http://www.acmehowto.com/howto/appliance/refrigerator/refrigerator.php
Aug 30, 2009 | Neff K3965XO Side by Side Refrigerator
Refrigerator compartment cools correctly for a few days then no longer receives cold air from freezer. The freezer continues to operate and gets much colder than it should.
does your fan blow? freezers have a fan that pushes cold air to the fridge side if fan is bad freezer will run extremely cold and fridge won't cool down and since frige won't cool down thermostat in fridge doesn't tell compressor to stop
Feb 26, 2009 | Refrigerators
Ive got a beko frost free frige freezer,the fridge is at the right temp but the freezer has all of a sudden started to warm up? the fan is going round and blowing out cool air but not cold enough to...
all working fine now, i took everything out of the freezer and turnerd it off for an hour then i cleaned it out and hoovered round the back and swiched it back on and straight away it was blowing freezing cold air, its still going now so i think its ok! thanks.
Jul 05, 2008 | Refrigerators
KENMORE SIDE BY SIDE NOT COOLING
You should hear a fan running inside the freezer. It also blows cold air into the refrigerator side.
Jun 09, 2008 | Kenmore 50522 / 50524 Side by Side...
Bottom Freezer working but not side!
Typically the freezer air is circulated into the frige area to provide cooling. If the circ. fan is not working or the air ducts/channels/dampers are blocked with ice, food, etc. then no cool air will get from the freezer to the frige area. Check all the air channels and to see if the dampers are open along with the circulation fan running. The diagrams at the following link should help you see inside better. If your lower circulation fan is running then you likely have an air return/supply channel blocked with ice and will require an old style defrost (unplug unit and leave doors open for 24 hours to melt ice, etc.). If the fan isn't running then that needs to be replaced. Air channels can freeze up if a door is left open slightly overnight or other moisture enters the freezer/frige. http://www.partselect.com/MultiModels.aspx?ModelNum=ER6AHKXPQ&searchTerm=&RefineSearch=0
Nov 20, 2006 | Whirlpool ER6AHKXPQ Top Freezer...
Open Questions:
Maytag MZD2768G Side by Side Refrigerator Logo
367 people viewed this question
Top Maytag Refrigerators Experts
Bailey's...
Bailey's...
Marvin
Marvin
Carlos Alvarez
Level 1 Expert
Are you a Maytag Refrigerator Expert? Answer questions, earn points and help others
