Question about Sony Playstation 3 (PS3) Console
What do i need to got sound out of my hdtv?im using a hdmi to dvi cable.
My hdtv is quite old and therefore doesnt support hdmi.Its a 32'Acer hdtv.I know that dvi doesnt support a sound signal,but im not sure what i would need to buy in order to get sound.im not bothered about amazing sound quality or surround sound,i would just like a good picture through the hdmi to dvi cables and sound with it.please help
    President:
  • 2,961 Answers
If you have no optional external speaker on the ps3 you may have an earphone socket which can be connected to your tv's pc sound input via a 3.5mm or 6.5mm jack plugs.
Posted on Aug 13, 2007
  • andrew pester
    andrew pester Aug 22, 2007
    if your ps3 has a digital out and the tv has a digital in, then you can connect using a digital toslink ended cable
SOURCE:
Using with a laptop
Connection the monitor depends on the connections you have out of your Toshiba laptop.
The monitor has both VGA and DVI.
If the Toshiba has a VGA out, all you need is a VGA cable available online, computer or electronics store.
If the Toshiba has an HDMI out, you can connect it to the DVI on the monitor with an HDMI cable and an HDMI to DVI Adapter.
You can also use USB out with either a VGA converter or a DVI converter (go with DVI for the better picture). Converters can be found online at Amazon, you may also need a standard male to male DVI cable to use with the converter.
Amazon com uxcell Black Blue VGA 15 Pin Male to Male Plug Computer Monitor...
Amazon com 5m High Speed HDMI Cable Ultra HD 4k 2k HDMI Cable HDMI to HDMI...
Amazon com Rankie Gold Plated DVI to HDMI HDTV Male to Female Adapter...
Amazon com StarTech com USB to DVI External Video Card Multi Monitor...
Apr 05, 2014 | HP Pavilion F1903 19" Flat Panel LCD...
Acer Aspire 5630 hook up to television
Your Acer laptop has a 15-pin VGA port on the rear. It may also have a S-Video and/or a DVI-D port. Any of these can be used to connect to a television monitor. None of these connections, however, supports the sound portion of the signal. You will therefore require two cables, one for the video, and one for the sound. The sound will be a regular 1/8" stereo jack on the PC side. You will need to look at the TV to see what types of connections it accepts. There may be HDMI, DVI-D, S-Video, or RCA connections. Select a cable which matches the connections for each end for both the audio and video.
Dec 11, 2013 | Acer Aspire 5600 Series 5630-6951 Laptop
Link my acer aspire 592o laptop to my panasonic plasma
1. S-Video – This is probably the most commonmethod out there currently because an S-Video cable is cheap as heckand just about every TV under the sun has a S-Video port. You’ll haveto make sure you laptop is equipped with this port. Remember, there aretwo types of S-Video cables: 4-pin and 7-pin. Mostlaptops and PC’s are equipped with a 7-pin port, so if your TV only hasa 4-pin S-Video port, then this method will not work.
2. VGA – If you have a HDTV, then you will bebetter off connecting using a VGA cable. It gives much better qualitythan S-Video and as with S-Video, the cable is very cheap. You usuallywon’t find a VGA port on regular TV’s though, so this option is if youhave an HDTV.
3. DVI - DVI stands for Digital Visual Interfacewith “digital” being the key word there. The digital signal will give ahigher quality picture than either S-Video or VGA. Of course, yourcomputer will need to have a DVI connection and your TV will need to bean HDTV. This cord is definitely not cheap, it ranges anywhere from $40to $80.
4. HDMI – Using HDMI will give you the best qualityby far. No computers that I know of yet have HDMI ports, but you canget a DVI to HDMI cable to connect it to your HDTV. HDMI is compatiblewith DVI.
5. Scan Converter Box – This is the last methodthat I could think of and it involves using a scan converter box, whichtakes a VGA signal and converts it into S-Video or component video.
Here’s a graphic I created with some pictures of the various cables:
Hope this helps someone! If you have any other ideas or suggestions, please feel
Jan 26, 2010 | Acer Aspire 5920-6335 Laptop
What do I need to hook it up to an hdtv...what type of cables..DVI-D to HDMI?
Your laptop will need a HDMI output or a DVI output for HD video. If your laptop only has a VGA out the your tv will need a VGA or DVI input. You could use a vga to dvi adapter if your tv does not have a vga connector. They do have a DVI to HDMI adapter but there are a couple of problems with that. One you will not get the sound and the TV will only obtain sound from HDMI cable when connected that way and Two the TV will have problems processing the signal from the computer due to the HDMI will only process the HD signals at certain formats and the computer video can send out many different signals. I tried and I could not get my tv to process the signal so I got a video card that has a HDMI out and my blu-ray player works great.
Sep 24, 2009 | Acer Aspire 3680 Laptop
My Acer P205H shows up for 1-3 seconds before showing a black screen. Connected DVI Cable but is there a need to connect vga too?
Depending upon the video port/s you have on the graphics card, you need to connector one video cable, either the DVI or the 15pin DSub to the monitor.
Sep 12, 2009 | Acer AL1916W 19" LCD Monitor
Acer H213H No sound
Dude, the hdmi is just for the video signal, you'll have to use a separate audio cable to get sound from the integrated speakers.
Jan 02, 2009 | Computers & Internet
Lcd to pc
YOU MUST GO INTO YOUR COMPUTER CONTROL PANEL TO SET THE DISPLAY SETTINGS FOR YOUR LCD.
Sep 28, 2008 | Sharp Aquos LC-46D62U 46 in. LCD HDTV
Hdmi and audio
It may be the top of set box.. Most times the sound and picture are auto detected by the set when HDMI is used. Both sound and video are carried in a HDMI cable but not with a S video cable. Try another HDMI cable *** dont buy the expensive one the tv don't care if they cost $125 or $25.
May 23, 2008 | Insignia 37" LCD Flat-Panel HDTV
Philips 32' lcd hdtv
are you using a DVI to HDMI converter? Radeon cards older than x1*** series or roundabout didnt support hdcp on dvi which is required to run Hi-Def rez thru an HDMI cable on most TVs. A video card with hdmi prebuilt in or HDCP compliance listed on the box should be able to handle it. And you should find a resolution both your normal monitor and HDTV can handle to set the coimputer to before you switch it over to the HDTV to be sure it will still show you picture. If you arent using 1080P you might as well use a component input which doesnt require HDCP.
Oct 12, 2006 | Philips 32PF9966 32 in. HD-Ready LCD...
Sony Playstation 3 (PS3) Console Logo
173 people viewed this question
Top Sony Video Game Consoles & Games Experts
Ekse
shevantha perera
Damen Wong
Damen Wong
Are you a Sony Video Game Console and Game Expert? Answer questions, earn points and help others
