Question about HTC S710 Smartphone
Backing up data from PDA with damanged screen.
I Have the new HTC 720 PDA, I am able to exchange it because the screen has been damaged I cannot see. Before taking it in I need to back up my data onto my PC using sync program. Can this be cone blindly since I cannot see on my PDA?
  • 490 Answers
U can sync ur data with pc using active sync. everything link contacts, schedule etc can be transferred to pc
Posted on Oct 23, 2007
SOURCE:
Problem formate htc
If u are talking about soft reset without wiping the data u just want to restart the PDA just press the standby power button up side for like 5 seconds it will switch it off then press again for the 5 seconds it will come on and boot and if u are taking about hard reset it will format all data take out ur memory card if u want to save it press the both call and end key together and then press the power button on the up side of PDA for like 5 seconds then screen will come up asking u to confirm just press the centre button of the 4 way joystick and go.
Thanks for rating Good luck
Feb 08, 2011 | HTC Touch P3450 Smartphone
It tells me that I don't have enough memory and should delete data files App 8004 and App 8002. I don't know what I can remove without damaging the performance. What can I move to the extra card I have
Hi.
To start you can delete safely any music or video file.
If that is not enough to fix the problem, then the best thing to do is resetting the PDA to factory settings after backing up all your personal data.
After backing up your data with HotSync, perform a hard reset, this will erase all applications and returns your device to its factory default settings.
To perform a hard reset:
1. Hold down the power button on the front panel of the PDA.
2. While holding down the power button, use a paper clip to press the reset button.
3. Release the power button.
4. You will get a message warning that you are about to erase all the data stored on the PDA, do the following:
Press the top scroll button on the front panel
to complete the hard reset and display the startup screen.
If you press any other button you will do a soft reset, that will not fix the problem. In that case restart the procedure.
5. After doing hard reset the unit will return to the initial factory state. All third party installed applications will be deleted, and setting will be reported to factor default.
Regards.
Mar 02, 2010 | Handspring Visor Deluxe Handheld
Touchflo of HTC Touch 3G won't launch
Hi. TouchFlo is the special today plugin for the HTC devices, and as you realized, you can still use all functions of your PDA without. I think there is an error in the installation of TouchFlo (There can be a bunch of reasons, we have to know everything you did with your PDA in order to guess them), but there is a safe solution for that problem, you can backup all your personal data and software to your PC, then you can hard reset your PDA to its factory default settings. That way both your phone and the TouchFlo will work. In order to hard reset your PDA (after the backup of your personal data), you can follow the steps in this link: (http://www.hardreset.eu/htc_touch_diamond_hard_reset_soft_reset_en.html). Hope this helps.
May 27, 2009 | HTC Touch Diamond Smartphone
I have external GPS button in my HTC touch p3452 pda . . how to get get gps data from this ??
u need an external gps device bought separately and then trhu bluetooth u can communicate with this software in ur HTC , u have external bluetooth device or not
nowdays GPS is coming builtin so there is no need to purchase separate reciever but in ur PDA it is not built in
pls rate me WELL for info !
May 20, 2009 | HTC Touch P3452 Smartphone
How can do reset my htc touch p3450?
soft reset no data wiped off press the power button upside of pda for 5 seconds it will turn off then press it again to switch on
hard rest factory default settings = when ur set is switched off press both buttons call and end key and then press power button on upside of pda for like 5 sec screen will appear asking to format all data take out ur card if u dont want to format that now confirm by pressing the centre action button in 4 side joystick and go
Feb 19, 2009 | HTC Touch P3450 Smartphone
Ho can do reset my htc touch p3450?
if u are talking about soft reset without wiping the data u just want to restart the PDA just press the standby power button up side for like 5 seconds it will switch it off then press again for the 5 seconds it will come on and boot and if u are taking about hard reset it will format all data take out ur memory card if u want to save it press the both call and end key together and then press the power button on the up side of PDA for like 5 seconds then screen will come up asking u to confirm just press the centre button of the 4 way joystick and go
During a call,phone will switch automatically to hold or...
try resetting the device
otherwise go and update ur pda software with latest at www.htc.com i mean ROM and see if it helps
Jan 31, 2009 | HTC Touch P3450 Smartphone
HTC P4350 Back up contacts
Use the Sprite Backup program, if available, to back up device data to a storage card or a designated folder in your device. Check your device user manual to know whether Sprite Backup is included in the Application Disc that came with your device. It is also recommended that you frequently synchronize your PDA phone with your computer, so you can quickly restore data when your PDA phone gets lost or damaged
Jan 22, 2009 | HTC P4350 Smartphone
HTC S710 Smartphone Logo
146 people viewed this question
Top HTC Computers & Internet Experts
robert roberts
Tom Chichester
Are you a HTC Computer and Internet Expert? Answer questions, earn points and help others
