Home | HP | iPAQ hx2410 Pocket PC | Screen allignment hp ipa...
HP iPAQ hx2410 Pocket PC
Problem for HP iPAQ hx2410 Pocket PC
Screen allignment hp ipaq hx2410 pocket pc
By jackhardy on Mar 18, 2009
My screen seems to not line up. It is functional but you have to touch it away from the target area and hope you get it right. And it seems to have a vertical dead zone (top to bottom) about 3/8th of an inch wide right through the middle of the screen. Theres no discoloration to any part of the screen and outside the dead zone the screen will respond other than being off target.
Jack
Comments:
Mar 21, 2009
- I did appreciate the input, but this seems to be a bigger problem. I had already did the screen alignment task. But do thank you for your help!
Jack
Solution #1
posted on Mar 20, 2009
Somewhat Helpful)
ctau
Rank: Guru
Rating: 85%, 60 votes
Try Realigning the Touch Screen
1. Tap Start > Settings > System tab > Screen.
2. Tap Align Screen and follow the instructions.
Was this helpful?
Yes
No
Solution #2
posted on Apr 21, 2009
Not Rated)
permana_20
Rank: Apprentice
Rating: 0%, 0 votes
I do have quite same problem before.
I want to share an experience, It could happen sometimes after charging the battery, well that's I think its because changing voltage immediately from your wall socket adapter thru' your Ipaq. I do re-align many times since I found that the charger is supplying abnormal voltage (it's higer than 9V from it's recommended voltage 5.5V). So change the battery charger, it may help.
Was this helpful?
Yes
No
Popular Solutions for HP iPAQ hx2410 Pocket PC
Questions and Unsolved Problems for HP iPAQ hx2410 Pocket PC
Do you recommend HP iPAQ hx2410 Pocket PC?
Answer
Answer
unit becomes warm with it switched off. batt also discharges.Its a 2400 series
Answer
the wifi is not working. have the message (uknown card in socket2)
Answer
hx 2410 will not start up. its been discharge for a while tried a hard reset but still does not... (More)
Answer
i have iPAQ hx2410 pocket pc and when i close it the instrumen tell me that i should re-enter new... (More)
Answer
I have IpaQ hx-2410 purchased 2nd hand last month, still looking for the wi-fi problem, it's keep... (More)
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Browse popular Problems
More Common Problems
Most Common Problems for:
For HP iPAQ hx2410 Pocket PC:
Top PDA Experts
Rank: Guru Guru
Solutions: 554
Experience: Experienced a lot in computer troubleshooting. Knowledgeable about cellular phones.
Ask Me
Find more PDA Experts
Top Computer & Laptop Repair
(513) 874-3306
We fix and repair laptop motherboard no video, no...
LaptopOnCall Inc.
(877) 934-6198
Send your laptop to us and we will diagnose the...
A+ Rated Oceanside Computer Sales & Service, LLC
Chat Now
X
Continue
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
