Question about Samsung CLX 3160fn All-In-One Printer
Transfer belt error
Loud noise then "tranfer belt error" on the screen. How do I fix this? Manual instructions said to turn off for 10 seconds & then turn back on; & if there is sitll a problem, to call repair. Can I fix this myself?
  • 4 more comments
  • Anonymous Nov 25, 2007
    Brand-new
    Brand-new Samsung CLX-2160. At first time start-up, first a lot of noise followed by a "Transfer belt error". Stays persistent.
    What is it?
    Thanks a lot
  • Anonymous Dec 18, 2007
    After initial paper jam the printer says transfer belt error. Turned printer off - no difference - still says the same. Have already checked for any paper which may be stuck - please help
  • Anonymous Jul 22, 2008
    Exact same problem! No luck so far.
  • sheri209 Sep 12, 2008
    less than a month old, one paper jam and now this error. Any other suggestions. I have tried everything here.
  • bestsolution Sep 16, 2008
    Purchased my CLX back in May or June... Just opened the box less than 30 days ago. Had previous copy problem 15 days ago, now my LCD reads "Transfer Belt Error" (and of course the red light...) What the?
    I'm going to try to do what May 17 suggestion comment is. Thanks.
I called Samsung because my printer did the same thing. Try a hard reset, if that doesn't work you have to replace the transfer belt. hit Menu then # then 193 Black Start....you have to do this all in about 3 seconds. It will come up and say Select Country (USA) hit OK and then it is suppose to reset it. If it doesn't work the transfer belt has to be replaced. If you are under warranty they will send you this for FREE.....
I am out of warranty and have to pay $150 to get one.
Good Luck
Posted on Oct 31, 2008
  • 9 Answers
Enter tech mode by pressing menu>idcopy>left>right>menu>back>menu ,then in data setup clear all memory and clear count
Posted on Jul 28, 2010
    Genius:
  • 1,153 Answers
You may have foriegn object stuck in unit. Check to see if paper torn off got lodge in unit. Should be able to open up and look in.
Posted on Aug 13, 2007
You need to install a new JC96-03611C.
Expensive and quite hard to do by your self.
Sorry
Posted on Sep 28, 2010
Just bought a refurbished unit and had the same problem"paper jam" "transfer belt error" what I did was take out the imaging unit the big one and the smaller one in the back and just gave them a minor dust cleaning of the toner ink that accumalates on the Imaging unit (there was no paper found to have been jammed) I also took out the toners and put them back in ,just in case they were not in properly.I put everything back turned on the printer and it's running great.
Posted on May 17, 2008
  • Alireza Azd Sep 21, 2011
    I bought a stock one first I heard that loud noise and after that transfer belt error, when I opened it and took out the drum unit i saw that drum was fixed vise versa, it's gears was on the left I opened it and turned it over and placed it back again ( it's gear must be on the right where all the gears are) and it works good
C2770 error code
The C2770 error is a transfer belt shift error. On the new Alphard series, the transfer belt has a mechanism to center the transfer belt, in case it starts to walk off one side of the pulleys. And it works great until you install the AK-730 bridge unit.
On instruction 19. they tell you to install the front left stay with the 20mm long black screws. If you follow that instruction the bottom screw will press against the transfer belt cleaning unit, preventing it from self-adjusting, and forcing the belt gradually off one side. The fix is laughably simple. Install 12mm long screws for the front left stay.
This was discovered in class. You know how after 10 or 20 disassemblies the test machines end up with all the wrong screws in the wrong places? The 30mm long screws for the latching bracket caused an immediate code C2770. With the 20mm long screws it takes about 15K prints to walk off it's pulleys, but same affect.
Sep 15, 2014 | Kyocera Office Equipment & Supplies
Transfere belt error
TRANSFER BELT CHIP COUNT IS END REPLACE TRANSFER BELT
Mar 18, 2014 | Samsung Office Equipment & Supplies
CE40 ERROR IN TOSHIBA COPIERS
CE40:Image quality control test pattern abnormality: The test pattern.
Switch off at the right hand side of the machine, wait 10 seconds, then turn it on back again. I should clear.
I think it is caused by condensation, it can also be transfer belt failure, or paper rubbing against the transfer belt
Jul 06, 2011 | Office Equipment & Supplies
"981 Service Switch Error"
981 service switch error refers to BUD(belt up/down) clutch if the error essage is hard. it could be possible that someone could have playes with white CAM below the tranfer belt(behind the waste toner box) if you suspect that the cam was manually rotated, then you are in a big FIX. if not then it could be just a problem with the cam being worn out. in this scenario you cannot remove or reset the transfer belt as you normally do it. there is a special procedure to remove the transfer belt. try the following.
remove the waste toner box., fool the front door of the printer so that you can watch the transfer belt moving up/down. while you have the fron door open,
Turn off the printer, press and hold the go and return buttons on the printer , keep watching the shaft that show the position of the belt, once it moves, be fast enough to turn off the printer. If you were successful in this procedure , you can remove the belt from the printer without any problem. Make sure not to touch the white cam shaft. visually examine the internal mechanism of the shaft, if it is wornout replace it.
IF the white cam was turned manually then you might have to replace the BUD clutch.. which is the most difficult process in this machine....Wish you all the best.
Nov 12, 2010 | Lexmark C912 Led Printer
My new balance 1500 treadmill works great but the last couple days its starting to make a clickinng noise around the belt. It sounds like its tranfering from the motor area. The belt has never been...
It sounds like you have a bearing failing, either in the front roller or the motor. If it is the front roller it will be a dull "Clicking" noise, if its the drive motor it will be a growl noise. The growl will be so loud at top speed you wont be able to even talk over the noise. Remove the motor hood and this will help you determine the culprit.
Nov 04, 2010 | New Balance Balance 1500 Treadmill
What is meant by error code SC 403
From the service manual:
SC403: Transfer belt position sensor error
-Definition-
The transfer belt position sensor does not activate even if the transfer belt clutch has rotated once.
- Possible causes -
• Main motor/drive malfunction
• Transfer belt position sensor defective
• Poor transfer belt position sensor connection
According to the manual, provided there isn't a major problem with the machine, you can reset the service code by turning off the MAIN POWER switch for a 10-seconds and then turning it back on. This should reset the code provided the problem doesn't reoccur. NOTE: The main power switch is a rocker switch on the front or left side of the machine, not a push-button switch up on the control panel.
Probably not a big help, but hopefully at least a little. I can't offer you much better advice, as I don't work on machines of this age, sorry.
Jan 20, 2010 | Ricoh Aficio 450 Copier
VERY LOUD NOISE WHEN PRINTING WITH MY SAMSUNG CLP-300
You all say that the toner cartridge is okay, so it could be the hole OPC Image Drum or the ITB which is the tranfer Belt.
The Tranfer Belt is behind the Image Unit.
Dec 19, 2008 | Samsung CLP 300 Laser Printer
How can i fix this problem ??
Turn the transfer belt by hand to check for any binding or noises. It could also be the fuser rollers causing the noise due to bad bearings since it sits above the transfer belt when it it closed into the machine.
Do you know how to remove the transfer belt to check?
Aug 19, 2008 | Ricoh Aficio 1035 Copier
Samsung printer, transfer belt error message
Check on you drim uint the gears damaged.
Aug 06, 2008 | Samsung CLP-500 Laser Printer
Transfer belt errors
I saw this posted somewhere on the internet and it worked for me.
Take out the transfer unit and look at the bottom. One side has visible wires. Open the side panel on that side. Follow the 3 wires to a C shaped sensor held in with a screw. Remove the sensor and blow canned air in the slots on the inside of the C. Put it all back together and hope for the best.
Sep 30, 2007 | Samsung CLP-500 Laser Printer
Samsung CLX 3160fn All-In-One Printer Logo
6,176 people viewed this question
Top Samsung Office Equipment & Supplies Experts
mukhtar21 shaikh
mukhtar21 shaikh
HEMANT GROVER
Victorman
Victorman
Are you a Samsung Office Equipment and Supply Expert? Answer questions, earn points and help others
