Question about RCA 27F534T TV
RCA Tue Flat 27 inch
When I turn on my tv the power light is blue and the television comes on and then shuts off and keeps doing this. I have it set up to the satelite and can see the picture. Then shuts off and turns itself back on. Some times the picture lasts for a minute or two then goes through the process again. HELP!!!!
  • 1 more comment
  • Anonymous Jan 10, 2008
    I'm looking for Horizontal Transistor D3402
  • Anonymous Aug 11, 2008
    Mine too is going off and on by itself. I have to unplug it. I have only had it about a year.
  • Anonymous Nov 15, 2008
    my RCA 27v514T is on and off itself please I need help
    Problem Solver:
  • 6 Answers
Here is something that I found that might help?
http://www.netnoise.com/boycott_rca/rcabook2007-8.html
Posted on Dec 19, 2007
DEAR FRIEND YOU CAN REPLACE D3402 WITH 2SD1880 THAT IS AN EASY REPLACEMENT IN NTE,
Posted on Mar 23, 2009
Well people dont be afraid all you have to do is to change a Horizontal out put transistor D3402 and that all is common problem I am a tv technician a already know that this kind of problem is normal good luck [email protected]
Posted on Mar 05, 2009
This is an extremely common problem with this model of RCA tv. I am currently having the exact same problem, as are a large number of other RCA suckers, I mean buyers. My suggestion, shitcan it, don't waste money on a repair, and go out and buy a Sony.
Posted on Jul 12, 2008
It is the front panel on the tv (button panel). I took my freinds tv apart and unplugged the button panel from the circuit board before it turned it's self off and the tv worked fine. It didn't turn off and on or change channels on it's own. The problem that I found is that this part is hard to find, online anyway. It can be fixxed by a repair shop, but they will want to charge you 100.00+ dollars to it. It's simple to take apart and simple to install. The Tv is already messed up anyway, why not give it a shot if you think you can.
Posted on Feb 26, 2008
SOURCE:
Rca tv wont stay on turns on then blue light accross the screen then goes off in seconds
it is listed here as a 27 inch set--can you confirm the brand and model number for me ???
Mar 24, 2012 | RCA F27450 27" TV
I bought a new 27 inch proscan in 1991. It was
This is probably a tv with the "ctc-169" chassis. The BEST modern chassis RCA built. I own 2 of them that I USE, one is a 32" CONSOLE, a lot like your 27" set the other is a projo. I would keep BOTH of them ANY day--over ANY of the cheap, unreliable, fragile flat--panel sets today!!
FIX your set!! If the picture was good--it still will be--these sets had GREAT tubes in them. Most likely--a power supply isue with a couple of caps in the power supply, perhaps the controller chip for the chopper transistor, nothing likely serious. Probably about 150 repair--or less.
Oct 10, 2009 | Proscan Televison & Video
I have a RCA 27" flat SDTV purchase in
Ur power inverter board is dead.
U need new one.
Aug 20, 2009 | RCA TruFlat 27F520T 27" TV
RCA tv when plugged in comes on and right back off
IF THE PICTURE IS TALLER THEN THE NORMAL SIZE IT MAY BE THE VOLTAGE REGULATOR. LETTING THE 130V POWER SUPPLY GO TOO HIGH.
Mar 20, 2009 | RCA 27V514T 27" TV
RCA 27' tru flat sdtv- power light comes on- no display,no sound.
How do you unlock your TV from Protective Mode? There is a certain code that you need in order to unlock the Television. The technicians are saying that it went into Protective Mode, when it umplugged all by itself. I need the code so I can watch my TV again.
Nov 23, 2008 | RCA TruFlat 27F520T 27" TV
KEEPS CLICKING ON/OFF
i would check the main board for loose connections on the horizontal ckt
[email protected]
Sep 07, 2008 | RCA 27V530T 27" TV
Insignia 27 inch lcd tv gets no video or audio
the most common item that fails with all LCDs is the power invertor or power supply, and that sounds like what your set is needing is the capacitors have possibly failed on the Invertor
Jun 28, 2008 | Televison & Video
52 inch RCA - green light turns on & off, BUT no picture
CP150 is a capacitor in the power supply circuit....feel top to
see if flat....change if "pooched" or swollen..................T.
Apr 15, 2008 | RCA D52W20 52" Rear Projection HDTV-Ready...
13 inch rca true flat tv
if it is a straight thin line from left to right you have a vertical problem time to call service tech
Nov 29, 2007 | RCA TruFlat 27F520T 27" TV
RCA 27F534T TV Logo
862 people viewed this question
Top RCA Televison & Video Experts
Steve Allison
Steve Allison
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
