Question about SanDisk Sansa e250 MP3 Player
I accidentaly sinc music to my sansa e250 from windows media player and it wont come off!!!
When i hooked my sansa e250 to my friends computer and accidently sinced music to it and i can't find it in my music file to delete. WHAT DO I DO!?!?!?!?!
Mp3 files can be loaded using either WMP or Windows file manager (Explorer) but a different USB setting is required by each. WMP uses the MTP setting while Explorer uses MSC. If you used the wrong setting this may have caused your problem. Also for some reason MP3 files loaded using a file manager will not appear when trying to view them using WMP. To solve the issue I used the MSC setting to view all of my MP3's using file manager. I then deleted the ones I had recently added, changed the setting back to MTP and reloaded them using WMP. Worked like a charm. Hope that helps.
Posted on Aug 13, 2007
SOURCE:
I can't download music to my San Disk 1GB MP3 player that I got for Christmas. I did not get a manual with it.
To put music on your Sansa e250 you will do this:
Download Windows Media Player 9 or 10 to your computer. I would use Media Player 10 as it is the newer player. After you download Media Player 9 or 10 open it up on your computer, and then hook up your mp3 player, it should be recognized by Media Player and then you can transfer the songs to it. You need to put the music cd in your computer cd player and download the songs to Media Player using Windows Media Player 9 or 10. I have also included a website where you can download the user manual, it will say e200, but the instructions are also for the e250. Good Luck, I hope this helps. Please rate me, Thank You.
http://mp3support.sandisk.com/downloads/um/sansa-m200-um.pdf
Dec 30, 2009 | SanDisk Sansa Clip MP3 Player
HOW CAN I DOWNLOAD MUSIC FROM CDS ON MY SANSA MP3 PLAYER? LISA
To put music on your Sansa e250 you will do this: Download Windows Media Player 9 or 10 to your computer. I would use Media Player 10 as it is the newer player. After you download Media Player 9 or 10 open it up on your computer, and then hook up your mp3 player, it should be recognized by Media Player and then you can transfer the songs to it. You need to put the music cd in your computer cd player and download the songs to Media Playeer using Windows Media Player 9 or 10. I have also included a website where you can download the user manual, it will say e200, but the instructions are also for the e250. Good Luck, I hope this helps. Please rate me, Thank You. http://mp3support.sandisk.com/downloads/um/sansa-m200-um.pdf
Dec 12, 2009 | SanDisk Sansa e250 MP3 Player
How do I delete single songs from a sandisk sansa e250 without deleting all songs on the mp3 player?
If you have a computer or know a friend with one then you can connect to a computer. If you are using the Windows operating system open Windows Media Player. In the library you should see your MP3 player and can click on it and it will show all of your music that you can edit any way you want.
If you are using a USB connection you canjust click on the Sync tab and the edit your music.
Mar 08, 2009 | SanDisk Sansa e250 MP3 Player
Frozen while connected to the computer?
try going on to sandisk website, then download the new software
for your player, update then hook up the player to the computer!
May 11, 2008 | SanDisk Sansa e250 MP3 Player
Sansa e250
Make a copy of one of the files, and try changing the extension to .mp3.
Apr 18, 2008 | SanDisk Sansa e250 MP3 Player
Wont open music folder
The folder option won't work particularly well - use Windows Media Player instead. If you continue to have problems:
Go ahead and do this, in case the DB is corrupted:
Format - Erases Everything: Connect your Sansa player to the computer and open Windows Media Player. Click on the Sync tab. Pull down the drop down menu underneath the Sync tab by moving your cursor over the Sync tab and left clicking on the little black arrow underneath the Sync tab. Highlight "Sansa 1GB" (wording may vary slightly), and then select "Format." - this should erase everything.
Firmware Upgrade- Erases Everything: Get the latest firmware upgrade from Sansa - it updates the firmware and erases every song in the player all at once. Note: this method doesn't work if already have the latest firmware. Go to this website and click "Firmware Updater" to find out: http://www.sandisk.com/Retail/DriverDownloads.aspx
Feb 29, 2008 | SanDisk Sansa e250 MP3 Player
Adding music to my sansa e250
you must use windows media player 10 or 11 to sync songs into the sansa. Make sure you sync it this way or else your songs will not go in properly.
Jan 21, 2008 | SanDisk Sansa e250 MP3 Player
Connections
Open My Computer, Sansa E250,
and drag your media into the right folders found in the Sansa E250 folder.
so,
-Song.mp3- > drag to > Music
Alot of people are havign difficulties with this mp3 player
well, hope this helps
Dec 25, 2007 | SanDisk Sansa e250 MP3 Player
Music Videos
I'm not an expert, but I do have a Sansa e250, too. Sounds like you need to download a Sansa Media Converter.
Here's the link: http://www.sandisk.com/driverdownload/download.asp?driverId=184
Once that is downloaded and installed, open it, plug your Sansa into the computer by USB cable, click "Add media". Then you should see a window that says "Add media" Select the media you want to put on your Sansa. Once the media is added, then click "Convert". After it is finished converting, it should be on your Sansa. Hope that helps!
Nov 15, 2007 | SanDisk Sansa e250 MP3 Player
SanDisk Sansa e250 MP3 Player Logo
97 people viewed this question
Top SanDisk Audio Players & Recorders Experts
Joe Negus
Joe Negus
Ekse
 Ben
Ben
Level 1 Expert
Are you a SanDisk Audio Player and Recorder Expert? Answer questions, earn points and help others
