Question about Everex Stepnote Nm3500w 15.4" Laptop Intel Motherboard Us Seller Tested Priority
Modem msi m3490 - Everex Stepnote Nm3500w 15.4" Laptop Intel Motherboard Us Seller Tested Priority
How do i set up my router msi
Is that a standalone router or a modem/router combination ? If it is a standalone router, in order to set up a home network to access the Internet, you need a modem (cable modem or DSL modem) which must be given to you by your Internet provider when you subscribe for Internet service. Your Internet provider has to provide instructions on how to set up your modem. A modem acts as a router too and has a WLAN port and a number of LAN ports (between 1 and 4). The WLAN port is where you hook up your modem to the Internet using an Ethernet cable. One end of the Ethernet cable goes into WLAN port of the modem/router and the other end goes either into a cable outlet (if your Internet provider is a cable company such as Comcast) or a phone jack if your Internet provider is a phone company such as AT&T or Verizon). To connect your desktop computer to the Internet, you plug it in any of the LAN ports on the modem/router. Contact your Internet provider for set up instructions for your specific brand and type of modem.
Hope this helps.
Dec 13, 2014 | MSI Computers & Internet
Modem msi m3490 ip
Do you want to find the modem IP address?
If it yes,visit the site IP-Details.com here you can get it with details like Internet Service Provider[ISP],IP Location,Country,Latitude, Longitude,IPv4 Dotted Binary,Octal,Decimal,Hexadecimal Notation.
Nov 06, 2013 | Arris 2246N-VGX Router
Modem msi m3490
It is not my modem configuration. Lights blinking DSL and can not be fixed., What should I do?
Aug 22, 2013 | Linksys E3000 Wireless Router
I need MSI 56K USM Modem Driver... Where can i find the driver online ?
You should be able to get MSI drivers here...
http://msi.com/index.php?func=downloadindex
click on the address above to go to the MSI website
in box 1. you can let MSI search your computer to see what needs updating in box 2. you choose the type & etc till you get where you're going in box 3. you type in your query
Hope you find this helpful
Brian/Sammyone
Oct 21, 2010 | MSI Computers & Internet
Connect MSI RG54G2 to speadstream 4200
so that means if you connect the computer to the modem, it works but not with the router.
it seems that the router and the modem are not communicating with each other.
When you connect the computer to the modem , check the IP address through the modem. If ti is private IP address then you will need to change the settigns on the router.
Click Here for more info about networking
Oct 14, 2009 | MSI RG54G2 Router (MS-6848-002)
My msi wind say limited or no connectivity. what do i do?
if this is on your home network
turn off the modem and then the router,
then turn your modem back on wait about 1 min
then turn on your wireless router and try to connect again
your getting this because of an ip conflict on the network
Dec 12, 2008 | MSI Wind UmNotebook
Hey, i'm having trouble setting my MSI wireless router
Make sure the physical connection is correct.
- Cable/DSL Modem > connected to Internet Port of the router.
- Computer connected to port 1 on the router
First, try to reset the router. Press the reset button at the back of the router for 20 seconds, then unplug the power to the router and the modem. Wait for 30 seconds, power on modem first, wait for the lights to go solid, then power on router.
That should be all set. If not, please run the Setup CD that came with your router.
Dec 03, 2008 | MSI (MS6848) Wireless Router
Modem
You need to go into Bios to disable your modem ( never damage the motherboard )
Jul 03, 2008 | MSI PM8M-V Motherboard
Msi rg54g3 wireless router
Cable modem or DSL? If cable modem without phone service, modem power has to be unplugged 2 minutes before the router is connected in order to release the mac address from memory. If cable modem with phone service, same thing applies, but battery backup must also be disconnected.
DSL modem may require PPPoE setup into router.
Mar 09, 2008 | MSI Wireless-G RG54G3 Router
Everex Stepnote Nm3500w 15.4" Laptop Intel Motherboard Us Seller Tested Priority Logo
112 people viewed this question
Top Everex Computers & Internet Experts
Jerry Umali
IT Solution
IT Solution
Are you an Everex Computer and Internet Expert? Answer questions, earn points and help others
