Question about i-mate K-jam Smartphone
Wont charge my battery went dead this weekend and when i came to charge it nothing is happeneing there is no sign of the phone charging what could this mean how could i fix this
I usually remove the battery from the phone for about 12 Hrs and when I put it back it accepts charging again. But do not leave the battery without charging until it dries off copmletely.
Posted on Sep 29, 2007
SOURCE:
Dead phone
I know this sometimes happens with these smart phones; one day they just up and quit.
You could try a fresh battery, and check your charging source.
Mine did something similar a couple days ago - I thought it was charging all night long, and in the morning when I went to turn it on... nothing. It ended up being my charging cable, it wasn't putting any juice to the phone.
Apr 01, 2014 | HTC EVO 4G Smartphone
1999 vw passat turbo wont crank or turn lights on
- Switch on the head lamps for 5 minutes.
- Keeping the head lamps ON, start the engine.
If the lights die,
- Check the battery terminals.
- Check battery state of charge.
- Charging system.
If the lights still glow sharply,
- Check fuses and relays in under the hood fuse and relay box junction.
- Battery to starter motor cable.
- Battery to engine ground and chassis ground cable.
- Solenoid on starter motor.
- Starter motor.
- Wiring.
-Ignition switch.
Mar 02, 2014 | 1999 Volkswagen Passat
My battery just went dead and phone wont charge. I took the battery out overnight and it came on till the battery went dead again. I have removed and inserted battery several times but nothing happens.
It is better change the battery first,know if the phone runs in good condition as well as it charged after a low battery level, when the phone still got the same problem,your phone might be shorted were the value of resistance is double using a multi tester. To test if your phone is grounded,you need a multi tester and range the selector to Rx1 * tap the positive pin in the positive battery terminal of the board as well as the negative pin into the negative battery terminal too,the meter should raise up. * now tap the negative pin of the tester into the positive battery terminal and the positive pin into the negative battery terminal,if the rate is 0 it means the phone is good,but if raises high,it means the phone is grounded and had a power supply problem.in this case,bring the phone to a mobile service center for a complete diagnosis and troubleshooting.
Jul 27, 2011 | RIM BlackBerry Curve 8310 Smartphone
MY CELL WENT BLACK AND i CHARGED IT OVER NIGHT. THIS MORNING IT SAID " FULLY CHARGED" WHEN i UNPLUGGED THE CHARGING UNIT i GOT NOTHING. i WENT TO CHARGE IT AGAIN AND IT WENT INTO THE CHARGING MODE... NOW...
Sounds like the battery's dead. Goto your cell phone provider and ask for a battery to check and see if it works in your phone. If it does, then buy a new battery.
Hope this helps,
BReady
Mar 30, 2010 | Cell Phones
Phone went dead. charged it. charge complete. wont
try taking battery out for 30 seconds,then put back in!?
Oct 18, 2009 | Cell Phones
Phone won't charge or turn on
Try removing the battery and clean the contact's, then reinsert the battery and let it charge, if it do'es not begin to charge your adapter may need to be replaced, or your battery.
Apr 06, 2009 | Lands Phones
Battery keeps going dead. Especially if car not driven for day or two. KIA ran checks of electrical system but found nothing. Am on sixth battery. Newest one only 3 weeks old and went dead over weekend.
it may maybe that the alternator doesnt give out the specific amount of electricity to properly charge your battery. you may have to run some tests on the alternator itself to see if it is giving out the proper current to charge.
Aug 06, 2008 | Kia Optima Cars & Trucks
W850i red light prob
When it is red light of death, it either means the bootloader of the phone is faulty (after uploading dodgy firmware updates), or the battery is too empty to start-up, let alone display charging progress. In your case you need to leave the phone charging even with the red light flashing and it will be fine. Give it a few hours connected to the charger.
Mar 14, 2008 | Cell Phones
Dead phone but keypad flashes
replace the LCD + flexcable on the phone.
Aug 02, 2007 | Motorola Mobility RAZR V3
i-mate K-jam Smartphone Logo
81 people viewed this question
Top i-mate Computers & Internet Experts
Ekse
Thomas F. Schneider
Are you an i-mate Computer and Internet Expert? Answer questions, earn points and help others
