Question about Motorola Mobility RAZR V3c Cellular Phone
Voicel error message on set up (not available)
When i try to program and set up my voice mail i keep getting the following error message... not avilable with a x in a round circle...thanks fred
    Welcome Back:
    Visited the website for 2 consecutive days.
  • 19 Answers
I am assuming you are using an "unlocked" phone, not one from your wireless provider. You will have to call your wireless provider to ask them the email settings to manually set up the phone. If on the other hand it is in fact a phone from your provider, then it may be an account glitch (yes, it happens) and you will have to call them to correct the issue. Hope that helps. Best regards, torgo
Posted on Aug 13, 2007
SOURCE:
How to set up voice mail
Verizon's voice mail service accepts messages for you when you are busy, or just don't want to answer the phone. The basic service will record up to 20 messages, with a three-minute maximum per message. The messages are held for 21 days, after which they are deleted automatically. Voice mail is usually included when you first activate your service, and you can check to see that you have voice mail from the "My Verizon" account area on the Verizon website. Once you have established you have voice mail on your account, you can set it up by programming it.
Sponsored LinkGet 30 days of 3G @ Rs 99ideacellular.com/DataplanGet 300 MB @ Rs. 99 Only. Now Upto 70% Discount on Idea 3G Plans! Step 1Press "*86" and then "Send" from your phone on Verizon's network. "86" are the characters "VM" using the alpha-keys. Then enter your wireless phone number. Press "#" when you hear the greeting. Follow the prompts to set up your password, greeting and mailbox options and then end the call when you're done.
Step 2Press "*86" and then "Send" from your phone. If you're not on the Verizon network, enter your wireless phone number. Press "#" when you hear the greeting. Then enter the password, followed by "#." Listen to the messages and then press "7" to delete and "9" to save.
Step 3Rerecord your greeting by choosing "Personal Options," which is the number "4" key. Options include notification options and other greetings like "Extended Absence." Follow the voice prompts to navigate through the tiered system.
Step 4Verify your voice-mail indicator is working by accessing your voice mail and pressing the number "4" key. Press "1" to toggle the message-waiting indicator on or off. Listen to the announcement that tells you how it's set.
Feb 15, 2013 | tracfone.com
How to connect a vocal processor to a peavey6 mixer
Set the voice input level on the voicelive2 by following this guide from the live 2 manual... Step 4: Set Mic Level This step informs VoiceLive 2 how loud you plan to sing with your particular mic. We'll use VoiceLive 2's automatic MIC GAIN feature to quickly set the optimum level. 1. Press and hold the REVERB footswitch 2. If you need to activate phantom power for your condenser mic, adjust the onscreen PHANTOM parameter which will restart the level test 2. Sing for five seconds with peaks that are as loud as you plan to sing 3. Follow the prompts in the display to finalize mic level setting, cancel or redo the procedure During performance, if you see the CLIP indicator light in the HOME screen, you can return to the automatic
MIC GAIN feature to adjust the input level.
When input level is set on the voice live ;
on the mixer set
the gain control to 12 o'clock position and
individual channel volume level to 7 ....raise the master volume
slider to hear mic input at desired level and without feedback
Jan 15, 2012 | Peavey PV6 Mixer
Lost the manual and need to record a new voice mail message
to leave a voice mail message on the Samsung Prostar;
To enter voice mail, press the Voice Message Key, the pass code will be set in default to 0000. Your mailbox will not function properly until you have put your voice message on. To do this, press option 0, followed by 5 followed by 7. When you have got the message you require press the #. If you regularly change your voice-mail message, you must press 3, delete the original message and reset the message followed by the #.
I have loaded a video explaining VM, at www.abbeytelecom.com there are 64 videos which will help you with any other issues that may arise.
Jan 22, 2011 | Samsung Prostar DCS-24B-LCD Corded Phone
NEED TO SET UP MY VOICE MAIL
Hi,If your account is enabled for voice mail, you can receive voice messages in your Inbox and also in a text message on your mobile phone. Both the message in your Inbox and the text message will include a preview of the voice message in text.
How do I set up voice mail?
1. Go to https://outlook.com to sign in to your mailbox, go to Options > Voice Mail tab, and then click Set Up Now.
2. When you set up your voice mail:
* You'll register your mobile phone number.
* Text messaging is set up. You can choose to be notified in a text message that you have voice mail or have missed a call.
* Call forwarding is set up so that your mobile provider forwards calls you receive to your voice mail. So if you don't answer your phone, your phone is busy, or you're unreachable or unavailable, the caller will be sent to your voice mail. After your personal greeting is played, the caller can leave a voice message for you.
* You can test whether your voice mail has been set up correctly by dialing your mobile phone number from your mobile phone. This verifies that call forwarding is correctly set up with your mobile provider.
How do I change my voice mail after I've set it up?
After you've finished setting up voice mail, you may want to:
* Change the mobile provider's voice mail number so you can use the key your provider has reserved for accessing voice mail to access your voice mail. For details about how to do this, see Changing the Number You Call to Access Your Voice Mail.
* Create a contact on your mobile phone. For details about how to do this, see Create a Contact for Voice Mail.
* Assign a speed dial key to the contact you create for Outlook Web App voice mail. For details about how to do this, see Set Up Speed Dialing for Voice Mail.
What else do I need to know?
* The voice mail service is available only to certain customers in certain regions. If you can use voice mail, you'll see a welcome message in your Inbox telling you how to set up voice mail for your account.
Thanks for using fixya...
Jan 20, 2011 | Cell Phones
I am trying to reset the incoming voice message.
To reset your incoming Voice Mail;
To enter voice-mail, press your VM Key, the pass code will be set as default to 0000, press option 0, followed by 5 followed by 7. When you have got the message you require press the #. If you are changing your voice-mail message, you must press 3, delete the original message and reset the message followed by the #. Please watch the video attached if you go to www.abbeytelecom.com there are over 60 covering lots of topics relating to the samsung dcs
Dec 19, 2009 | Samsung Prostar 824 Keyset Telephone
I AM TRYING TO SET UP MY VOICE MAIL, BUT EACH TIME I PRESS THE MESSAGES BUTTON, ALL I GET IS A RECORDING WHICH TELLS ME TO CONTACT THE OPERATOR. SO THEN IT TELLS ME THAT THE OPERATOR IS NOT AVAILABLE.
That is because you need to setup the voice mail in Cisco Unity and also setup the phone in the call manager. Unless you have voice-mail setup it states.....Cisco Unity Messaging system....is the beginning of the message.
Aug 07, 2009 | Cisco 7940 IP Phone
Voice Mail - "Camp On"
Your phone needs to be programmed. Look in the manual and set the buttons to do what you want. Be prepared to get confused.
Feb 10, 2009 | Toshiba DKT-2020 Corded Phone
Wrong Voice Mail number programmed into Speed Dial "1" Key
You can not remove it; But you can change it
Follow the steps :-
>Menu
 >Messaging
   >Voice Messages
     >Voice Mailbox NO.(CHange it)
Sep 06, 2008 | Nokia 3110 Cellular Phone
Merlin Legend (Lucent) phone--changing vm list of extension
I do not fully understand you message but it sounds like you want to get into administrator programming of your voice mail.
I don't deal with voice mail programming. My only suggestion is to try and determine exactly which voice mail model you have and find the "administrator" or "programming" manual for the voice mail.
All manuals are available free at www.avaya.com
Apr 25, 2008 | Lucent PARTNER18 Corded Phone
Motorola Mobility RAZR V3c Cellular Phone Logo
47 people viewed this question
Top Motorola Mobility Cell Phones Experts
D. E. Hev
vince
Lawrence Oravetz
Are you a Motorola Mobility Cell Phone Expert? Answer questions, earn points and help others
