Question about Sungale DVD-2026 DVD Player
Scrambly TV I use the yellow/white/red cables to hook my DVD player up to my TV. It did fine with the first three movies we've watched on it and now all of a sudden when you turn the DVD on to watch a movie, it just scrambles. I cannot figure out why it's doing this. I tried using a CD cleaner on the DVD but it still doesn't work. I've tried switching to different channels on the TV and that doesn't work. I'm at my wits end! Help! Thanks.
  • amsx04 Aug 16, 2007
    I cannot make anything out clearly enough to read the DVD menu. I also don't have the manual as I bought this DVD player in a garage sale with a guarntee that it had never been used. This is also no button on the back of the player.
    I also tried it with the movie. It still did not work.
  • 56 Answers
Take a quick peek in the manual and find out where to disable the progressive scan features. may be a button on the back, or you may have to go through the on screen menu to find it. take the disc out and see if you can view what's on screen. or since you said you had a couple of movies that did work properly, put one of those in, start the movie, go into the dvd player setup menu and disable the progressive scan settings
Posted on Aug 16, 2007
  • Ashley Sinclair
    Ashley Sinclair Aug 17, 2007
    another thought, if you are running it through a VCR before the tv, dont do that. There is copyright protection on dvd players that prevent taping of movies.
    plug it directly into the tv, and try it again.
    otherwise, try a different, or friends tv temporarily, see if it's the player, or the tv.
    keep us informed
No signal fromdvd player video 1 (av)
yellow is video and red and white are audio you a get by with one audio. i think you are missing your video cable you can get by with two cables just use the white cable as a yellow and plug it into the yellow dvd plug and tv yellow plug and the red will stay hooked up for sound ( you wont have stereo but it should work)
Aug 05, 2012 | Audio Players & Recorders
Dvd is playing movies in black and white
Hi
use red/white/Yellow cables to connect to a loose hard diskon which I keep films, TV-serials and talking books. The colour is fine.
But I connect the DVD to the TV with a scart cable.
Hope you get your colour
Kolbrun
Feb 26, 2012 | Apex Digital ADV3800 DVD Player/VCR
How do I hook it up to a TV so that we can watch a movie on the TV instead of the small screen
On the side there is a video out socket ( sometimes marked AV out and yellow in color ). You will have to get an interconnecting cable to link it to your TV. The back of the TV will have corresponding yellow/red/white sockets. The yellow is for video and the red/white is for left/right audio. Your player comes with this cable along with the AC adapter . bobhifi_56.jpg
Aug 16, 2011 | Mintek MDP-1770 7 in. Portable DVD Player...
My dvd player only plays movies in black and white. When I watch tv, it's in color so I know its not the tv.
I suspect you may have connected a COMPOSITE cable (red/white/yellow RCA type) to the COMPONENT video input sockets on the back of the TV.
COMPONENT requires 3 RCA type video cables - the plugs and sockets are usually colour-coded red, green, and blue. COMPOSITE only uses one RCA type video cable - the plugs and sockets are usually colour-coded yellow.
If you connect the yellow video cable to one of the three component inputs you will get a black and white picture although you will still have audio if the red and white cables are correctly connected.
If you are using a COMPOSITE cable (red/white/yellow RCA type), please check your connections. Make sure you have not connected to any sockets - either on the TV or the back of the DVD player - under the heading of "COMPONENT" - or individually marked "Pr", "Cr", "Pb", "Cb" or "Y".
If you have verified that you are using the correct sockets on the TV and it still doesn't work or if you are using any other type of cable, please let me know which cable you are using and the model number of the TV and the DVD player. I will then be able to assist you further.
Regards,
BElectric
Jan 14, 2011 | Insignia DVD Player with MP3 Playback/JPEG...
Hook up
Hi:
This type of hook up is only for television viewing, to view the DVD you might consider purchasing some componet cables, they are color coded so hooking up is a snap, on the back of the DVD player you will see three RCA type connections Red/Green/Blue. componet cables are also these colors, connect one end of the cables to it coorsponding color on the back of your DVD and the other in the same color connectors labeled componet 1 input on the back of your television. You will also need a red and white RCA connector also for the audio as this is sound, a total of 5 connections will complete the hook up. Or you can go the simple route and use RCA type cables that come as yellow/red/white but for the best picture use componet cables this will allow you to watch your movies in HD.
Apr 27, 2010 | Sylvania Dual Deck DVD/VCR
Hooked dvd player up to my olevia tv and don't know what channel to set tv on to watch video. checked all the channels - can't find movie. do i need to change a setting?
U setup ur DVD player in what format?Set it up with a one cable call HDMI?Or u use a RCA cable YELLOW.RED,WHITE to hook it up.The movie play,u push the button on ur remote said INPUT go down INPUT said 1,2,3 so on.If hook it up right the movie,should play in one of this INPUT said 1,2,3 so on.
Apr 02, 2010 | Olevia LT27HVX 27 in. LCD Television
There is no colour on the movie
Make sure you have the cables hook up right. If you are running component mode it takes three for video blue red and white ends. If you are running composite it takes red, white, and yellow.
Nov 20, 2009 | Toshiba HD-A20
Hook up tv/dvd
All you need is A/V cable. These are yellow, white, and red. If you have an old model TV that doesn't have these, you can get an RF modulator from any electronics store, which will enable you to connect the DVD/VCR combo.
Sep 16, 2009 | Insignia Digital-to-Analog Converter for...
Tv works great, dvd is new , cant figure out the right hook up , dvd has 3 cables white yellow red
Red = right sound channel, white = left sound channel and yellow = video (picture) channel. if you have the connections matching these on the tv, then there should be an AV channel on the remote/tv control panel. Select this channel to view, if more than one AV channel on the tv, there will be a number next to the sockets you plugged into. Select the AV number and away you go.
If your tv doesn't have the correct sockets you can buy a converter to use the ariel socket on the tv.
May 28, 2009 | Televison & Video
Hooking up my DVD/VHS player to TV & Convertor box
I would just hook up the dvd/vhs player with the red,white,yellow rca cables that should of come with your unit and just go to the input on the tv to watch your dvd/vhs player. This will give you a better picture and sound while allowing you not to have to watch dvd/vhs on a channel which helps make the dvd/vhs player independent. Also if possible I would hook the converter box up with the red,white, yellow rca cables to the tv as well if your tv has more than one set of red,white,yellow plugs since it is a better connection that coax and you probably watch more tv than vhs/dvd anyway. So bottom line try to hook up both boxes red,white,yellow and watch each box on different inputs instead of like channel 3 or 4. Also to record of converter box you can run coax from converter box to dvd/vhs combo and make sure your dvd/vhs player is on tuner input or channel 3.
I’m happy to help further over the phone at https://www.6ya.com/expert/brandon_60dfebff379d64bd
Nov 16, 2008 | Insignia Digital-to-Analog Converter for...
Sungale DVD-2026 DVD Player Logo
99 people viewed this question
Top Sungale Televison & Video Experts
janman
Argospete
Argospete
Are you a Sungale Televison and Video Expert? Answer questions, earn points and help others
