Question about Kenmore 20.3 cu. ft. / 575 liter Upright Freezer 23024
Kenmore Freezer Model 23041
Freezer will not stay cold. Last week interior temp came up but went back down on its own (no foods had been added to the freezer at the time to cause the temp increase). This morning, everything is thawed/melted. No other obvious symptoms. Freezer is running, air is circulating, seals are good, just won't maintain temp. Any and all suggestions welcome. Freezer has been very reliable to this point.
I have an upright freezer which temp was unstable. The coils were frosted up, and the circulating fan was unable to pull air across the cooling fins.I defrosted the unit, cleaned it up, and turned it back on. Worked fine until it frosted up again. The unit was a no frost model. I had to have it serviced, and one of the defrost sensors was bad. No problems since this was fixed.
Posted on Aug 13, 2007
SOURCE:
Ice on back wall of freezer, food not staying completely frozen
Do you have the complete model number from the tag on the freezer, it should be either on the bottom rail visible with the door open or on the side wall near the front. I am trying to look this up to see if it is an automatic defrost model, if so you may need to do more than just unthaw and adjust
Thanks
Apr 25, 2010 | Kenmore 16.7 cu. ft. / 473 liter Upright...
Temp Alarm going off and not very cold inside.
I think you should see if the circulation fan is working inside. Sometimes they need a little push and some WD 40 let me know. I might have another idea. The Raz Shack
Apr 20, 2010 | Kenmore 20.3 cu. ft. / 575 liter Upright...
New freezer not cooling - temp @ 25 degrees and food is defrosted
It is probably the control board and since it's new it's still under warranty so a certified Frigidaire repair man will fix it without charge. There should be a telephone number with the paperwork you received when you bought it.
Aug 29, 2009 | Frigidaire 20.3 Cu. Ft. Frost-Free Upright...
Running non stop!
Sadly these old freezers use way too much electricity. You will be better off junking this one and purchasing a good used or brand new one.
Apr 02, 2009 | Kenmore 22.7 cu. ft. / 643 liter Chest...
Frigidaire upright freezer Model #FFU17C3AW1 Not keeping cold
Yes that is the correct part number.
If a new cold control does not correct the problem. Replace the compressor start relay.
Mar 12, 2009 | Frigidaire 14.1 cu. ft. Upright Freezer...
Freezer Not Freezing Food
there is a circulation fan and also a vent. Either the fan is blowing, or there is a cloged vent.
Feb 11, 2009 | Kenmore 14.1 cu. ft. / 399 liter Upright...
My deep freeze outside will not stay cold.
a freezer is just a heat pump . from inside the freezer to the garage . the first law of thermodynamics says heat travels from a hotter to a colder surface . it could just be the cold how much are we talking?
Dec 14, 2008 | Kenmore Freezers
Not cold enough?
is this a chest freezer or upright frost free fridge freezer . nead more info
Oct 19, 2008 | Freezers
Kenmore Upright Freezer Model 253.9239780 Temp alarm, Temp rising slowly
you have a refrigeration issue partner let her go 16 yrs. is good service you can replace it for 3 to 5 hundred the repair will be that IF you can find someone with the r-12. don't go for a top it off and go deal the food you lose is to expensive for that to be economical.
Mar 22, 2008 | Kenmore 20.3 cu. ft. / 575 liter Upright...
Freezer runs constantly
not necessarily, is it maintaining temp? all food staying frozen? especially ice creams if stored in there. most newer freezers displace the heat generated while cooling the food through copper lines running through sides of unit, helps to cut down on air temp differences between the inside (0 degrees) and outside temp to prevent moisture and possible condensation causing premature rusting of unit
Mar 02, 2008 | Kenmore 14.1 cu. ft. / 399 liter Upright...
Kenmore 20.3 cu. ft. / 575 liter Upright Freezer 23024 Logo
299 people viewed this question
Top Kenmore Freezers Experts
John Tripp
John Tripp
Felizardo Erilla
Felizardo Erilla
PNiss
Are you a Kenmore Freezer Expert? Answer questions, earn points and help others
