ALL I DID WAS CHANGE FRONT MOTOR MONT N STARTER
Try going back to the part store and have them to do a diagnostic readout done....
I don't think your transmission is actually jumping out of gear, But I do believe that your transmission is either low on flued or has a stopped up filter. It could possibly be that the pump is going out in your transmission or even a bad solenoid....
The problem is definately in your transmission...
Try getting back to that part store to get a troubled code read out on their diagnostic computer... Email me the codes at [email protected] and I'll tell you what the code is and how to fix the problem.
I hope this helps...
Testimonial: "but my check engine light isnt on so they cant check it"
SOURCE: i need a diagram of 1999 ford contour serpentine belt
Top one is for a 2.0, with AC, bottom one is the 2.5 with AC.
SOURCE: serpentine belt diagram for my Ford V6 4.2L 97'
Lower left is the tensioner and above should the idler. Sometimes there is a diagram on the fan shroud or near the radiator. Without a picture I hope this makes sense.
Starting with the ac going over the top of its pulley and down to the power steering, to and under the crank shaft, going in and up and around left over the water pump to the tensioner (going under) and to the alternator over the top and then under the idler.
SOURCE: replace a serpentine belt on a 97 ford taurus
use a 15mm box wrench on the nut retaining the tensioner pulley to pry the tensioner 'arm' against the spring to release belt. note belt routing on decal under hood,or make a sketch,to aid in replacement.
on OHV engine rotate clockwise
on OHC rotate counter clockwise
be sure belt is completely seated on pulleys
SOURCE: 02 Ford Expedition need diagram change serpentine belt
log itno autozone.com
they have free tech solutions and diagrams...........
My sincere apologies for the delayed response.
I am personally going back to answer your unanswered questions.
I do not know if you still need this information, but I am going ahead and answering it anyway. You may want to Print the Diagrams for future use.
CLICK on the following LINK. It has the Belt Diagrams you will need.
If you would: Before Clicking: Let me know if this helped you, or if you have any additional information or questions. Feel Free to contact me at FixYa.com!
Again my apologies...
http://www.2carpros.com/car_repair_information/year/1997/make/ford/model/econoline/1997_ford_econoline_drive_belt_routing_diagram.htm
