Question about Canon PIXMA iP4000R InkJet Printer
Can't print over wireless
I think the wireless card or whatever it is in the printer is broken; can't communicate over wireless (USB is fine); when I tried to (re) set up and detect the printer using the Mac address, it couldn't find it. Am I hosed, or is there a way to diagnose further? Thanks
  • 2 more comments
  • eaksmom Nov 02, 2007
    Thanks. I had done all the configuration using BJ network tool; in the end, it was NOT the printer, but my wireless network. Thanks for the post.
  • l53mar May 28, 2008
    Error 306 reports Communications error between iP4000R and IMac. Have tried the usual reset checks.
    Thanks
    SB
  • bmaillard Jul 20, 2008
    Yup, I'm having the same problem. The printer is able to be seen in the BJ Network Tool when connected with USB. Then I check all the network settings/password/etc and send them to the printer. But when I disconnect the USB, the printer is lost and cannot be seen in the BJ Network Tool.
    I've done a hard reset on my router (an Apple Airport Extreme) and double-checked all the settings. Now I'm completely out of ideas... Please help!
    Thank you!
    -brian-
  • Anonymous Oct 02, 2008
    I have the same problem but have no idea what the tech speak means to fix it... can anyone help in simple english, please!?
Not sure if you tried this but you need to use USB and the BJ network tool to first configure the wireless. Using the working USB connection configure the printer to use wireless but not ethernet, set the SSID and encryption. Then update that to the printer and try pinging it.
Posted on Nov 02, 2007
SOURCE:
I am getting an error message "Communication Not Available" when trying to print wireless from my Dell Studio Laptop to Dell V715W printer. I can still connect via USB and print ok and the...
Check the Printer access code. Check wireless Summary to be certain the IP Address is correct. Look for the Network Name (associated with the wireless device) and reset the parameters. Print out your summary for confirmation.
Jan 31, 2018 | Dell Computers & Internet
Wireless printer communication unavailable via USB
Hi. Hope you got it working fine now on your Windows 7. If not, go to Start Menu > Devices and Printers > right click on the Lexmark print object > Troubleshoot. Make sure the printer is on and is still connected to the computer via the usb cable.
Mar 12, 2010 | Lexmark Wireless X4850 All-In-One Inkjet...
My lexmark 4850 wireless will not communicate with computer
Disable any Firewall/Antivirus you have running and try a new print.
If still an issue, go to Start - All Programs - Accessories - Right-click on Notepad and choose 'Run as Administrator' (if on Vista/W7). Try to print this notepad document. If it prints, it's Windows User Account Control that is blocking the print. This can be disabled in the Control Panel - User Accounts.
If it's wireless, you can try re-installing the printer using USB connection in order to eliminate the wireless network as the issue.
If it's still an issue, you can check your computer manufacturers website for updates for your chipset (USB drivers).
Mar 01, 2010 | Lexmark Wireless X4850 All-In-One Inkjet...
Canon MP 640 not recognized by MP Navigator EX 3.0
Your anti virus software is blocking the Canon software. Restore AV default settings.
Jan 31, 2010 | Canon Office Equipment & Supplies
HP P2015dn wirless connection stopped working
There is not wireless netwrok card is HP LJ P2015dn, However as i can understand you r using External Wireless Router or Wireless network or jet-direct card if u r able to work fine on USB than printer printing mechanism is working fine.
If u connect the printer via wired network connection and it keeps on loosing IP address than it may be problem with onboard network card of the printer.
If printer keeps on loosing IP Address than try upgrading the firmware of the printer.
To check the firmware and IP Address of the printer print a configuration page by pressing and holding down green button for 6 to 7 seconds
May 28, 2009 | HP LaserJet P2015dn Printer
P430i - Ribbon Broken / Out of Ribbon error
ribbon cut again and again after put 2 or 3 cards pls give instruction how to solve the problem.
Mar 03, 2009 | Zebra P330i Thermal Card Printer
Wireless lexmark not communicating
maybe its not compatible with your comp at happened to me
Dec 27, 2008 | Lexmark Multifunction Wireless Printer/...
Wireless Printer communication problem with laptop
Please check IP, use manual IP for laptop and Printer. may AUTO IP cause this issue.
Apr 12, 2017 | Lexmark Office Equipment & Supplies
Dell 948 wireless printer
hi,
u need to have wireless internet connection, first uninstall the printer sw, while reinstalling choose wireless install, follow inst, connect the printer, configure wireless adapter by choosing the correct wireless nw and by entering the security key(WEP, WPA), if wireless adapter not detected then, unplug all cables from back of printer,removed wirless adapter, press power button for 20 secs without any cables connected, connect cables, restart printer, connect the wireless adapter, u will get msg nw card detected, then try reconfiguring by entering the correct keys, in case if u dont know the security key contact ur internet service provider, once correct details are entered it will configure successfully, unplug usb cable from printer and pc, install printer sw, issue resolved, if there is no communication then check the firewall settings, anything relating to printer give full access, restart pc, try printing,
ps: if usb cable is connected to printer the nw card will be disabled.
Nov 03, 2008 | Dell 948 All-In-One InkJet Printer
Canon PIXMA iP4000R InkJet Printer Logo
427 people viewed this question
Clive
Clive
old marine
old marine
Ekse
