Question about Canon ZR800 Mini DV Digital Camcorder
Canon ZR800 MimiDV Camcorder
I just bought the Canon ZR800 MiniDV camcorder but both my laptops only usb 2.0 ports. How do I use a DV Cable to connect my camcorder to my computer using a USB 2.0 port? All the cable that I have found online seem to be 4 pin or 6 pin. I'm a complete moron when it comes to technology and with so many cables and connectors out there, its impossible to find the right one
  • Anonymous Mar 30, 2014
    I am searching for a DV cable to connect camcorder to burner. camcorder (small end) has 6 pin, larger burner end has 4 pin. This appears to be backwards from all the cables I see.
I have the same problem, here's a 'sort of' solution. First check to see if your computer has a slot where you can plug in a PCMCIA card. (This is a thin slot about 2" wide, which probably came with a plastic blank inserted in it, which must be removed before using the connection. This type of connector is very common on laptops, less common on desktop computers. If your computer is a laptop, the PCMCIA slot is probably on one side or edge of the computer.) So, if you have a PCMCIA slot, you can buy a PCMCIA / Firewire card that plugs into the PCMCIA slot and provides you with one or two Firewire connections. Look on Ebay, these can be had for under $20. You would also need a cable with the tiny USB connector on one end (which plugs into the small female connector found uinder the gray plastic cover on the side of the ZR800) and a 6-pin Firewire connector on the other end (which you would plug into the PCMIA / Firewire adaptor card mentioned earlier.) When shopping, you may see IEEE 1394 terminology - this is the same as Firewire.) By the way, the adapter card may come with the necessary cable; see what you get before buying an additional cable separately. You will also need some software - I'm using Windows Movie Maker, which is probably already on your computer. If not, you can download it for free from Microsoft. Plug in the adapter card and turn on your PC. You should get a 'new hardware' message when it boots up. Wait for the boot up to finish, then connect the ZR800 via the cable to the PCMCIS / Firewire card and turn on the camera. You will get another 'new hardware' message as Windows recognizes the ZR800; wait a while until the 'Your new hardware is installed and ready to use' message appears. When the camera is recognized, you may see a window asking what program you want to use to capture video - select Windows Movie Maker. Once it (Movie Maker) starts up, get your camcorder tape ready, click 'Capture from video device' on your PC, then click 'Start Capture'. It will create a file (you pick the name) on your PC from the camera. You can use Movie Maker to edit, re-sequence the scenes, etc. (You can also buy video editing software if you want fancier features than Movie Maker provides.) Now here's the catch - why my initial statement says this is a 'sort of' fix. I hooked up my ZR800 as described here to a one-year-old Gateway model W323-UI1 laptop, and the video captured from the ZR800 contained many ramdonly blinking colored pixels superimposed on the movie and the audio has lots of static. When I hooked it all up to an older Dell Inspiron 8200 laptop, it worked great. Hope this helps, good luck!
Posted on Feb 22, 2008
You cannot connect a DV cable to a USB port. These are two incompatible standards. DV is also called Firewire, iLink or IEEE1394. You PC must have that kind of port for you to transfer your video from the ZR800 and you will need a DV (iLink/Firewire) cable. You cannot use USB cable they will not work. Check www.MyCableMart.com if you want an example. Most new PC come with 1 or 2 iLink/Firewire/1394 port. If you PC does not have an iLink/Firewire/1394 port then you will need to install a iLink/Firewire/1394 card (see http://www.usbfirewire.com/Parts/rr-fw-byt.html) for more information.
Posted on Sep 26, 2007
    Novelist:
    Scholar:
  • 158 Answers
On your canon zr800 minidv camcorder you should have a port for connection to Laptop or tv video the one for laptop is a small end on the usb cable it looks like a small D on one end of the lead this is the 6 pin end this plugs into the camcrder and the other enn plugs into laptop make sure you have installed the drivers that came with camcorder this driver is needed to run camcorder of the laptop first then plug the 4 pin end in
Posted on Aug 14, 2007
SOURCE:
My new computer only has usb - I have firewall cable for this - ZR800 mini digital video that I used with my old computer - what do I do?
Most Windows PCs have USB ports, but no Firewire port. As your PC did not come with this interface, you need to fit an add-on Firewire interface card in one of the bus slots. This will come with a driver for the card. I am assuming a desktop PC, you don't say what kind of computer it is. If it is a laptop, you won't be able to fit a card. You can get Firewire interface cards from Amazon or eBay quite cheaply.
Nov 23, 2010 | Canon ZR800 Mini DV Digital Camcorder
How to transfer sony dcr-hc26 videos to pc using usb cable thanks
The Sony HDR-HC26 is a miniDV tape based camcorder. No surprises if you can't get USB streaming working.
ALL miniDV tape based camcorders transfer DV-format video by conneting the DV port of the HD camcorder to the Firewire port of your computer. USB won't work. The "DV" in miniDV = Digital Video. It is as digital as the digital video from flash memory or hard disc drive or DVD based camcorders - only better because it is not compressed as much as the others.
Memory cards are not the only way to store digital video - and while not as good as miniDV tape, memory cards are not as bad as DVD based consumer camcorders...
Firewire IEEE1394, DV and i.LINK are all the same thing.
If your computer does not have a firewire port, hopefully it has an available expansion slot (PCI for desktops; PCMCIA or ExpressCard for laptops), so you can add one.
Oct 17, 2010 | Sony DCR-HC26 Mini DV Digital Camcorder
Where is the memory card located on the camera
there is no memory card slot, this camcorder uses miniDV tape.
Feb 12, 2010 | Canon ZR800 Mini DV Digital Camcorder
Macbook not recognizing camcorder
I had this problem when first plugging in my Canon zr80 to my Mac. What I did first was (if you have it) open up the program Imovie in you're applications menu. Then plug the firewire cable into both the camera and computer. Turn the camcorder on and set it to play(VCR). Once this happens you should see a "DV in" on the camcorders screen, followed by a blue window on you're computer. The rest should be easy.
Jul 01, 2009 | Canon ZR800 Mini DV Digital Camcorder
Canon ZR800 - transfering video to DVD recorder
Just want to make sure you are talking about a four-pin firewire cable (small and flat) as opposed to a 4-pin s-video cable (round).
If you are talking about the latter, there is no control signal in an s-video cable so there is no "recognition" possible. Make sure that you have your DVD recorder set to S-video in and then hit play on the camcorder. You will need audio cables too if you want sound transferred. You should see video after you have manually pressed "play" on the camcorder.
Dec 29, 2008 | Canon ZR800 Mini DV Digital Camcorder
Canon ZR800 won't connect
Your saying 4 pin USB firewire. Which one is it?
It should be 4 pin firewire.
What is the error message that you are getting?
Jun 09, 2008 | Canon ZR800 Mini DV Digital Camcorder
Canon ZR800
Use a firewire cable. Your camera has a 4pin on it (DV port). Your HP laptop may have a 4 pin DV port in the back of it as well.
What model laptop is it?
May 29, 2008 | Canon ZR800 Mini DV Digital Camcorder
Transfer my minidv camcorder film onto DVD
i assume your using firewire-not usb right? use windows movie maker in xp or vista -should transfer ok if machine is pretty current-if very underpowered with little ram memory expect problems
May 19, 2008 | Canon ZR800 Mini DV Digital Camcorder
Dumping video
purchase a firewire cable to go from dv port of cam to computer-4-4pin for laptops 4-6 pin for mac and towers if comp has no firewire port-use pinnacle dazzle to convert a/v output to usb 2.o
May 17, 2008 | Canon ZR100 Mini DV Digital Camcorder
How can I view the movie
No, they do not fit in a VCR. First, you need to have a TV that has the three input ports on either front or back of the TV. If you do, then you will need to take the cable that comes with the camcorder, plug one end into the A/V port on the side of the camcorder plug the yellow, red and white cables into your TV. Lastly, use your TV remote to select Input or something like that.
May 14, 2008 | Canon ZR800 Mini DV Digital Camcorder
Canon ZR800 Mini DV Digital Camcorder Logo
1,452 people viewed this question
Top Canon Video Cameras Experts
Pieter Vleeshouwers
Pieter Vleeshouwers
Marvin
Marvin
Steve Mason
Are you a Canon Video Camera Expert? Answer questions, earn points and help others
