Question about Dacor Epicure ERD30 Dual Fuel (Electric and Gas) Kitchen Range
Electric Heating Element Not Heating stove
One day I was cooking in the stove and all of a sudden I saw a blue pop in the stove our of the corner of my eye. Since then the electric heating element in the stove doesn't heat up. Any help is appreciated. We have a ERD30 Dual Fuel Stove. Steps I have taken... Check the circuit breaker. Turned the oven off for an extended period of time and then turned it on. No luck with either. Tonight I might open it up and see if there is a fuse or something. Thanks again for your help.
  • 1 more comment
  • dedriann2002 Aug 13, 2007
    I really appreciate your help. There is no evidence of a "burned-out" spot on the element in the oven. If you have time and can explain the wire procedure, I would appreciate it greatly. Thanks again for your help.
  • bbsb Sep 23, 2008
    Just found this posting, I had just posted that my ERD30 baking element has a broken section. Can you provide the steps to repair (I'm a EE).
  • Anonymous Mar 19, 2014
    Oven heating element will not turn odd
    An expert whose answer gotĀ voted for 100 times.
    Novelist:
  • 135 Answers
It's not a fuse, but a wire or heating element has burned up. Please TURN OFF the circuit breaker until you repair the problem, or at least until you know what the problem is! You say "in" the stove, so I'm assuming that you mean in the oven. Whichever element it is, whether it's in the oven or on the stovetop, just needs to be removed and checked for continuity with an ohmmeter. Quite frankly, if it IS an element, then you should see a burned-out spot somewhere on it that's pretty obvious. Then you just need to replace the element. If it's a wire, then you will need to repair the wire so that it safely makes contact with the element again. That process is a little more involved than just replacing an element, but let us know what you find. I can describe a wire-repair procedure if need be. ;)
Posted on Aug 13, 2007
  • Kevin Omel
    Kevin Omel Aug 13, 2007
    To repair a burned-out wire requires you to pull the range completely out of it's counter-space, then remove the back panels and physically snip, strip, crimp and repair any wire damage that may have occurred.
    Trust me, if all you've done is to "look" at the element to see if it's okay - then that isn't enough, because moving on to wire repair is a LOT of work. So you want to be sure it's not the element.
    You need to check that element with an ohmmeter first to see if it's properly carrying electrical current. If it IS an okay element... then you probably have to repair a burned up wire. Which, as I said, takes a lot of effort.
    Nevertheless, first find out for sure if your element is good or bad. If you go to an appliance parts store, they should be happy to check it for you and tell you if it's good or bad.
    If it's bad, they can sell you a new one. But write down the model & serial number of your range before you go! They almost always have to have those numbers...
SOURCE:
Electric Stove Burner won't shut off after element malfunction
(no model number received)
My best advise would be to cut the power at the
MAIN CIRCUIT BREAKER panel... and leave
the RANGE powered down until a new
ELEMENT and TEMPERATURE SWITCH are
installed... (very dangerous).
I am guessing... but I suspect the SWITCH got
SERIOUSLY DAMAGED when the element
did it's melt-down (live power my be present)
WITHOUT a model number that is
TOTAL SPECULATION...
Hardware stores commonly carry GENERIC
(UNSATISFACTORY ... in my opinion) SWITCHES.
I would got to a SERIOUS parts house and order
both the element and the SWITCH...
If you have your OWNERS MANUAL... Look
up the REAL PART NUMBERS on eBay
(for serious savings)...
ELSE
Try one of these part houses to find your parts
Search Over 2 1 Million Appliance Parts
PartSelect Appliance Parts and Repair Help
Appliance Parts Lawn Mower Parts Heating Cooling Parts 365 day returns
Hope this helps
Carnac the Magnificent
Dec 19, 2017 | Kitchen Ranges
Loud pop and light behind stove. Stove top works, oven does not.
Good Morning Stephanie - Typically you may locate the model and serial number in the storage drawer, on the right side. Based on the symptoms you are describing, you may either have a communication error from the main control board or a faulty bake and/or broiler element. If resetting the unit did not solved the issue, at this point I would personally contact a professional to accurately diagnose the range to determine the root cause to reduce the risk of unnecessary parts.
May 26, 2013 | Frigidaire FEF316 Electric Kitchen Range
Top heating element does not work but it still cooked our turkey in the cooking bag just fine. the stove is only a little over a year old.
If your electric oven is taking too long to heat or just not heating up right,then check out this tip that will give more detail about your problem.
Oven Problems Electric Oven is Heating Slowly or Poorly
heatman101
Nov 26, 2010 | Frigidaire FEF366 Electric Kitchen Range
The oven was on and I was baking. Heard a 'pop' then the oven went off. I flipped the stove breaker on my electrical board back on and it took the whole power to my house out. Flipped the stove breaker...
element has blown, pop is it breaking, that heating element will need replacing, failing this and elements all working water may have gotten to the electrics this would cause the pop and shut down all electric as well.
Jan 02, 2018 | Heartland 3525SS Dual Fuel (Electric and...
I'm having trouble with the lower heating element not heating on my GE Electric Range. Its probably 10 + years old. The broiler element heats. Will I be able to replace the element or circuit board? ...
Most of the time it the heating element.
(recheck your model number)
Here is a good source for replacement part
http://www.partstore.com/Content/CategoryPages/Kitchen-Cooktops.aspx
Or directly to GE
https://www.geapplianceparts.com/GEApplianceParts/Dispatcher?REQUEST=LANDINGPAGE&AppliancePart=Cooking%20Products
Dec 24, 2009 | General Electric Stove/Oven/Range Chrome...
The element on top of the stove stays on
Replace the switch for the bad element. It is stuck internally in the ON position.
Jul 30, 2009 | Frigidaire FEF352 Electric Kitchen Range
Kenmore 790.9641240, while using stove top power burner (front left) a loud pop was heard and I thought I saw a blue flash (like an arc) above the pan, the next day received a slight electrical tingle...
Tom (Tchange): I also had arc/pop/short of SSB like g_royer. This was preceded over a few days by the Element ON indicator always ON (with all surface select switches OFF). I found the arc marks and burns on the SSB and replaced it. Element ON indicator went OUT, but like you, element no longer heats. I just checked continuity for each of the relays on the Lockout Board. In spite of the error designation on the Wiring Diagram (swapping P3 with P6), I found an OPEN relay for that element. Now to order the Lockout Board, just like g_royer.
Jun 25, 2009 | Kenmore 96422 / 96424 / 96429 Electric...
A small piece of kitchen stove element broke off and exploded.
Hi, There is no sure reason. This just happens. The element had a weak spot on it and finally gave way. Change the element and you should be fine. I hope this helps. Anything else I can assist you with, plesae let me know.
Thanks
Vic
May 14, 2009 | Maytag MES5752BAW / MES5752BAB Electric...
I think my heating element for the Dacor 6 burner range went
Hi there.
You have faulty oven element. and nothing more serious than that.
Simply disconnect and remove the faulty element, and fit a new one.
Problem solved!!!.
Plz rate my solution.Thanks.
Dec 22, 2008 | Dacor ECS127 Epicure Stainless Steel...
Dacor Epicure ERD30 Dual Fuel (Electric and Gas) Kitchen Range Logo
498 people viewed this question
Top Dacor Kitchen Ranges Experts
Steve Allison
Steve Allison
Jaime Hernandez
Axel Gringmuth
Are you a Dacor Kitchen Range Expert? Answer questions, earn points and help others
