Question about HP Compaq Evo n610c Notebook
Display brightness I was messing with the keyboard and made the display dark but nothing i do makes it brighter again,Any help plz
    President:
  • 317 Answers
You should have an "Fn" key. It's between CTRL and Windows key on the lower left corner of the keyboard. Hold down the Fn key while pressing the UP arrow key.
Posted on Aug 13, 2007
SOURCE:
Display not bright enough on Bose AWR1-1W clock radio
Yes...within a range. The display will automatically lighten and darken depending on the amount of light in the room. During the day or when there are bright lights in the room, the display will go to full brightness. When the lights go off or the room is otherwise darkened, the display will shift down to a lower brightness. You can make the "lower brightness" a bit brighter by holding down the CLOCK SET button and pressing the 'volume up' button.
Dec 26, 2013 | Bose Wave Am Fm Radio Awr1-1w Not Working...
I can't change my Brightness
you might need a new battery
click start control panel display desktop you can select a different desktop from the drop down list
or a browse button where you can select different pictures this may vary depending on your operating system
also you can change the settings for more or less pixels or from the drop down list pick the appropriate level of color range or troubleshoot also select advanced then general dpi normal size,larger size or custom settings
always click APPLY after making any changes
hope this helps
Jul 07, 2012 | Samsung R517 R523 R528 R530 P580 R540 R538...
Brighter display on the left side of monitor than the other side
Sounds like the lcd screen might be going bad. There are no display settings that can modify parts of the screen. It's all or nothing as far as settings go. Have you tried hooking up an external monitor to see if it displays correctly? If it shows correctly on an external monitor the problem is definitely with the lcd screen. If they both show the same image of brightness on the left side, then your video card in the laptop might be going bad.
Apr 18, 2012 | Computers & Internet
MY IPHONE HAS A PLOBEM MY SCREEN IS VERY DARK EVEN I ENCREASE THE BRIGHTNESS IT STILL VERY DARK ???
Your display is going out sorry.If the back light is not making it brighter the screen is failing.
Apr 07, 2012 | Apple iPhone 3GS Black (16 GB)
How do i increase the back light. IT has gone dimmer while setting clock
Press the snooze button 4 times. The display toggles between lo/high brightness. ;-).
Mar 31, 2012 | Sony ICFC218 Clock Radio
Ipod touch 1st generation display very dark
You probably reduced the brightness one time, but you just forgot about it. To make the display brighter, do this:
>on your iPod touch screen, go to Settings.
>once the Settings window is open, you'll see Brightness from the list, tap on it.
>now, you drag the button to make the display darker or brighter. drag it to the left to make it darker, to the right to make it brighter. You'll notice the display darkens / brightens simultaneously as you drag the button.
For more iPod touch / iPhone tips, click here. Feel free to comment on my tips if you have other questions.
Mar 05, 2010 | Apple iPod touch
Dark screen if unhooked from battery
You can use the function keys to increase the brightness. Also if you go to Start, Control Panel, Power Options you can change the settings to give you more monitor time.
Apr 15, 2009 | HP Compaq Presario R4000 Notebook
My acer aspire 5630 laptop has a very dull/dark viewing screen it is fully charged and on high performance, help plz. Cheers G.
check on the keyboard, lots of the keys have an extra function, normally written in blue.
Look for the two that show brightness... it the same symbol on TVs that sets brightness...
now look for the "FN" key.
press and hold the "FN" key and then press the brightness + key... this should make the display brighter...
Dec 09, 2008 | Computers & Internet
Monitor too dark....
inverter board bad. this runs your lcd lamp(s) but is not in the screen.
Oct 02, 2008 | ViewSonic VA702b 17" LCD Monitor
Screen displaying a thin white very bright horizontal line.... plz help
problem in vertical section.
1. Solder the vertical ic
2. vertical ic supply capacitor problen.
3. dry points in neck board.
Aug 08, 2008 | LG Studioworks 45 14" CRT Monitor
HP Compaq Evo n610c Notebook Logo
87 people viewed this question
Top HP Computers & Internet Experts
Ekse
Thomas F. Schneider
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
