Question about Arris Touchstone 450a (CM450) Modem
Re-starting a ARRIS modem after a loss of power
After the modem lost power, it refuses to re-connect to Timer Warner Cable's network. The little power light is on, but none of the others are. I have tried (a)disconnecting and re-connecting all the cables and (b) resetting the button on the back, but no joy. TWC will come out to "fix" it, but in the meantime I'm without internet and telephone for 5 days.
  • 39 Answers
You can try doing a "Hard reset" on the modem but it looks like you've tried most combinations. To do the hard reset: - unplug the coax cable from the back of the modem - Push and hold the "reset" button in for 15 seconds - Allow the modem 30 seconds to reinitialize and then plug the coax cable back in. Within 10minutes you should have activity back. If not, the modem needs to be replaced. I know you may have tried something similar to this but I'm hoping this may help.
Posted on Aug 13, 2007
SOURCE:
Bought the same identical modem that time warner provides & had them register it.enabled wireless & rebooted modem. wireless disables when you connect time warner says everything is good on their end
The configuration between the modem and your computer requires digital switching via code settings. Check you manual for the proper communication settings.
Mar 30, 2015 | Arris Computers & Internet
Problems modem
please do the following:
First, click the Start Menu, and select Run. Next, type ''cmd'' into the box and click the ''OK'' button. Finally, at the prompt, type ''ipconfig'' and information about your IP Address will be displayed.
If doesnot get the IP, reset the Modem ,disconnect the power cord by 40 seconds, and then with small pencil erase click the small button , for add reset. and try again. If the problem is fixed good. If not please open network connection, select the network troubleshooting and fix it.
God bless you
Jul 28, 2013 | EnGenius (ESR9850) Router
Can't connect to internet through router wired or wirelessly Belkin N750 F9K1103 after ISP dropped out for one hour
Unplug the ISP modem completely, power, and cable. There might be a recycle (a quick push) on the modem as well. Some modems have a battery backup and will stay lit, if not connect the power, reboot and then connect the cable. The modem may take a while to fully reload after reconnecting. Then do the same with the router. Only do a quick push. Holding it in will clear custom settings on the router.
You should have green on both the modem and the router now. If not you have this to inform the ISP of your troubleshooting. GL
Jan 30, 2013 | Computers & Internet
There is no internet connection to the laptop. The arris modem gives internet acess to the PC computer, though. The manual for the Airlink 101 router says to connect the router and MODEM to each other by a...
What you're missing is that ALL the PCs will be connecting THROUGH the router to the Modem. Unplug the PC network Cable from the modem, then plug a network cable from the router's INTERNET port into the modem (where you removed the PC's network cable). Now, plug the PC's network cable into one of the ports on the router (usually 4 or more, marked 1,2,3,4. Think of a Router as a "splitter". It connects to the Modem, then several devices connect to the Router, some of them by wire and some by Wi-Fi. So your desktop PC is connected by wire to the router and your laptop PC is probably connected by Wi-Fi (wire is an option, as well). The Router sorts out all those signals and communicates with the Modem. Sound reasonable?
May 02, 2017 | Arris Comcast Touchstone Telephony VOIP...
We have an Arris wireless modem. We have lost the adapter that goes with it. My husband purchased a Belkin Wireless adapter, but it would not work. We went back to the same store and they do not carry...
If you meant you lost the power cable, then you should contact Arris to buy it.
If you mean you lost your router that was hooked with the Arris modem, the you can buy any router for house like D-Link, Linksys... and get it configured to work properly with the Arriss modem where you buying at.
Feb 28, 2011 | Computers & Internet
We have just signed up for cable TV/high speed internet/cable telephone. The modem provided is an "Arris" version 1.5. The cable tech said I could connect my Belkin G router so that more than one computer...
Plug the ethernet net cord into the arris ethernet port. plug the other end into the router where it says "internet"
Plug a ethernet cable from one of the router ports to the computer.
First start up the arris modem, then power up the router, then start the computer.
Oct 22, 2009 | Belkin 802.11g Wireless Desktop Network...
I have a Arris Modem from time warner cable, no i
do you have dsl filter where the phone line comes out of the wall and goes into the Router.
https://en.wikipedia.org/wiki/DSL_filter
Mar 26, 2017 | 2wire (1000-000057-000) Modem
Trying to connect my ps3 to the internet but need wireless route
That won't work because your old sbc wireless router 2wire gateway is also a modem. You need a plain router for Time Warner. Try Linksys router.
Sep 08, 2009 | 2wire (1000-100052-000) 802.11g/b Wireless...
I cant get out to the internet when I connect the netgear router.
Be sure that your cable company has enabled your internet. Power down the cable modem, power down any routers and computers. Start cable modem first, after internet connectivity is indicated, power up the router (if you have one) and then power upi the pc
Dec 27, 2008 | Arris Touchstone 450a (CM450) Modem
CHEC
do a hard reset on your router, and try again. After the hard reset plug your modem into the router but disconnect the power and reconnect the power after 10seconds. Other than that, Dlink tech support should be able to help you solve the problem.
Dec 29, 2007 | D-Link AirPlus DI-524 Wireless Router
Arris Touchstone 450a (CM450) Modem Logo
5,893 people viewed this question
Top Arris Computers & Internet Experts
Ekse
Greg Ulan
Ann Moroz
Ann Moroz
Are you an Arris Computer and Internet Expert? Answer questions, earn points and help others
