The fan was already installed when we purchased the house, so I do not have the model number. It is a hunter fan, five blade and the remote part # is 85095-01. The remote works the fan portion perfectly but will not turn off or dim the lights. Any ideas? We already checked out the battery and it is still good....
I have old Hunter Model #25604 and need an internal wiring digram need to know were the black power...
(More)
I have old Hunter Model #25604 and need an internal wiring digram need to know were the black power wire goes.
the fan lights do not ever turn off, the remote dims them a bit but they are always on . Remote part...
(More)
the fan lights do not ever turn off, the remote dims them a bit but they are always on . Remote part no. 85095-01 FCC ID: IN2TX13
the remote control has stopped working with the light & fan. we replaced the battery with a...
(More)
the remote control has stopped working with the light & fan. we replaced the battery with a new one. The red battery lights up when push the function buttons, but no response from the fan. The fan has power to it because the light is stuck in the on position
have a hunter fan w/light kit that works by remote/light switch. The light works but the fan does...
(More)
have a hunter fan w/light kit that works by remote/light switch. The light works but the fan does not, as if there is a wiring or motor problem. It is a 3 speed fan, with no pull chain. Any suggestions?
I removed Hunter fan switch to replace it, decided to go into switch and reinstall chain. Need wire...
(More)
I removed Hunter fan switch to replace it, decided to go into switch and reinstall chain. Need wire scheme to put back together. Apparently not all colors matched and didnt see until reassembly. Where does brown wire from black box go. Without it connected, only have one speed: very slow.
