Question about Whirlpool Duet GHW9150P Front Load Washer
Whirlpool wont start
Hi Recently bought a second hand frontloader Whirlpool 5.5kg. The machine will fill up with water for about a minute then stop again. The cycle wont start, and all I can do is set it to drain and it works. I turned it off for 5 minutes for it to reset itself, and when you open the door the machine has partially filled with water. The lock is working fine, and I cant seem to find any knobs or levers anywhere that might be of use. Hope someone can help!
    Novelist:
    Champion:
  • 244 Answers
Try blowing down your pressure switch pipe you will have undo the lid and it will be situated down on the left as you look so it will be on your right hand side it will be round,black and have a clear pipe coming out of the bottom take hold of the pipe do a big blow which should reset your pressure switch replace pipe try a programme if it does not work then you will have to replace it
Posted on Aug 14, 2007
SOURCE:
How to drain water from 5,5kg twin tub
Most machines have an inspection port at the bottom where you can access the drain pump and filter. Bale out as much as you can from the drum by hand, if you can open the door. Open the inspection cover and slowly loosen the pump/filter until the water dribbles out into a shallow tray.
Jan 07, 2018 | Washing Machines
My washing machine wont agitate and the fill light wont come off
whirlpool has manuals and service books for its machines which have a trouble shooting section, try to get one of these. if you have a sears service center nearby you can usually order these service manuals from them pretty cheap
Sep 22, 2015 | Whirlpool Washing Machines
Hey I want to know how to fix my whirlpool frontloader showing error f8 when I turn it on a couple of seconds like no water going through the tube and f8 comes up help please.
Hi Takai
Don't know the Machine or the Code but...
To start a washing machine cycle... the water should start filling the machine.
So...Is the Tap turned on? Can you hear the Water hose Solenoid Click In (to open the water valve)? Is water flowing?
If not... here is where you would start tracing the problem.
(Very similar to your Lawn Sprinkler Solenoid... the only difference is 24v AC vs 110 or 240V AC)
Most washing machine problems occur because of the many mechanically actuated switches and solenoid valves. The Electronics is usually good. When a switch doesn't respond it is picked up by the electronic controller & displayed as an error code on the front.
(CAUTION.... 110 to 240VAC is lethal especially around water)
So.... if you don't have the ability to remove the cover & check for faults you will probably want to call the qualified washing machine repair guy.
Cheers
TJ
Feb 19, 2015 | Whirlpool Washing Machines
Washing machine stopping and starting when filling
Sounds like maybe a bad water inlet valve? timer may have isses as well? have u tried running it in hot water only and cold water only cycle? see if one line is bad in ur inlet valve?
Dec 16, 2014 | Washing Machines
My whirlpool frontload washer does not have enough water to wash or rinse properly
1. do you have limescale in your source water, if yes you need to clean your machine with a special product that can be found in the market.
2. pressure sensor is broken
3. inlet filter is dirty you can unscrew the inlet pipe and look for a small filter and clean it.
Mar 24, 2014 | Whirlpool Duet 4.0 cu. ft. Front Load...
Westinghouse SB907 - Water draining out right after filling up
The drain hose has to have a loop in it. In other words as the drain hose exits the dishwasher, it must go up at least 18 inches before it goes down into the drain. If not, the water will siphon out of the machine.
Apr 17, 2009 | Whirlpool Gold 24 in. Built-In Dishwasher...
Washer does nothing
ok we need to check a couple of things...take the fill hose off ,,,now put unit in a cycle and make it call for water...is the inlet vavle humming or vibrating....will your there look in vavle and see if your inlet vavle screens are clogged...does the unit have water in it,,if so it wont fill with water in it...keep me posted onthejob
Feb 01, 2009 | Frigidaire ATF6000ES Front Load Washer
Water pours from detergent basin-Whirlpool Duet Sport
first remove dispenser pull out and make sure its not clogged inside,w/ hand fill around ,, on any frontload machine i perfer liquid soap,, are you using HE detergent
Jan 03, 2009 | Whirlpool Duet Sport 6.7 Cu. Ft. Gas Dryer
WASHER WON`T FILL FULLY WITHOUT RE OPENING TOPLID SEVERAL TIMES?
water valve should be a single unit consisting of a hot and cold solinoid assembly. This whole valve assembly should be replaced.
Jul 20, 2008 | Washing Machines
Whirlpool Duet GHW9150P Front Load Washer Logo
147 people viewed this question
Sal De
Marvin
Marvin
Gerry Harvey
Gerry Harvey
