Blood Pressure Monitors
Problem for Blood Pressure Monitors
Generic problem for all Blood Pressure Monitors
I have a wristech modelzsbp-002.Half way...
By geogon8 on Mar 17, 2009
I have a wristech modelzsbp-002.Half way through it stops and read Err 05.no where in the manual does it have this and what the problem is.Can you help.
Same Problem
May 21, 2009
-   I have WrisTech model ZSBP-002 that when I press the start button it comes up error 3. What can be done to fix this problem?
Ron Jenkins
-   gjenkins48
May 05, 2009
-   Same prob. err 3 -   Guest
May 04, 2009
-   Does anyone have answer to the Question?
I have a wristech modelzsbp-002.Half way through it stops and read Err 03..Can you help -   mariadelaluz
Apr 15, 2009
-   same problem err 03 -   Guest
Apr 12, 2009
-   i have err-03 whats that ?-   Guest
Best Solution
posted on May 24, 2009
Helpful)
nfe2005
Rank: Apprentice
Rating: 93%, 7 votes
I'm not really sure what error i had with this type of blood monitor but i found that the problem was with the two little knobs behind, that were stick out too much . If you put your finger behind the blood monitor , in the area that comes in contact with the wrist, you should feel two little knobs under the textile material. If they stick out too much try to gently push them in. Hope this is work....
Was this helpful?
Yes
No
5 people thought this was helpful
Solution #2
posted on Aug 16, 2009
Somewhat Helpful)
silly01
Rank: Master
Rating: 75%, 4 votes
With wrist BP monitors errors frequently occur because the senors in the cuff are not positioned correctly. The manual should indicate the corresct placement of the cuff. Arrows on the cuff also help with correct placement. The arm/wrist shoud be kept still while the machine is measuring and the arm/wrist should remain in a flat level surface with the elbow bent at a 90 deg angle and not hanging down. Over the counter auto BP machines are reliable when the instruction of correct placement of the cuff are followed.
Hope this helps.
Was this helpful?
Yes
No
Popular Solutions for Blood Pressure Monitors
Questions and Unsolved Problems for Blood Pressure Monitors
Answer
Wrist blood pressure device, with memory reading for two people.....which brand is best... (More)
Answer
Looking for a watch like blood pressure monitor I have to wear all day long.
Answer
the memory full is displaying how do I empty
Answer
Have lost the instructions for Omron IW1 wrist blood pressure monitor
6 Other Users Have The Same Problem - Continued
Comment by pnolan5050, posted on Apr 03, 2009
half way through i get err 3 model zsbp-002
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Browse popular Problems
More Common Problems
Most Common Problems for:
For Blood Pressure Monitors:
Top Blood Pressure Mon... Experts
Rank: Guru Guru
Solutions: 3902
Experience: 30 yrs exp home bldg, plumbing, wiring, framing, design & spring water usage. Problem solving.
Ask Me
Find more Blood Pressure Mon... Experts
Chat Now
X
Continue
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
