posted by cambridge on Aug 13, 2007
i took my amp to a party to be used to play the turntables through and sombody else wired up all the connections and obviously did a bodged job of it. Anyway it lasted about and hour then the music cut out,I felt the amp and i couldnt even pick it up because it was so hot. Now it will not turn on or work. I just want to know if it can be fixed or serviced or if i have to scrap it and get a new one.
1 Other User Has The Same Problem
Comment by Guest, posted on Nov 20, 2007
This amp kept cutting out at our party and was extremely hot we are taking it back and changing it for the denon 1500AE
Best Solution
posted on Aug 13, 2007
Yup, looks like someone who does not understand the quality of a Cambridge amp connected it wrongly, or with mismatched components.
Since you state that the Amp was very hot,It suggests that the Speakers hooked to the Amp were of a Higher Rating than what the Amp could Handle. That it worked for about an hour is credit to your machine.
In all likely hood. 1. The Power supply fuses are blown, and 2. The Audio Aoutput Transistors also.
can be fixed, but very expensive job, and only in the hands of the right Technician.
Was this solution helpful? Show your Appreciation by rating it:
Suggest a new solution for this problem
Post a New problem for Cambridge Audio Azur 640A Amplifier
Email this problem
Email this problem
Can you Help with these Amplifiers and Preamps problems?
arcam alpha 7 amplifier goes...
Vry recently when playing both... Answer This...
BEHRINGER 602a MIXER..HOW CAN I...
a crate guitar vamp head with... Answer This...
Repair Service
Find Amplifier and Pre. Repairman Near You:
