Question about Sony Xplod XM-554ZR Car Audio Amplifier
Amplifier I just hooked my amplifier up in my car and i wanted to test it to see if it would work so i plug my sub in and it worked then i went on in putting the my other speaker on but it wont work and now everything doesn't work the power light is on no flicker or anything i have no clue on what to do
Reset your sistem
Posted on Aug 15, 2007
Amp power light is on, but sub not making sound ?
If you have power, and the amp has previously worked.
Check your audio input and make sure you do not have any filters on like a sub woofer crossover, that you do not want.
If that still doesn't work try hooking up a different speaker for testing purposes.
I hope this helps
Nov 15, 2016 | Car Audio & Video
Sub cutting out
Check the 12v wire running from the battery to the amplifier. Also the sony explode is a garbage subwoofer compared to the Alpine.. sony (they say 1200w max but its more like 100w to power the thing) Amp could be going. Is the amplifier hot when running. If there is a burnt smell comming from the amp, its the amplifier
Mar 27, 2009 | Alpine Type-R SWR-1222D Car Subwoofer
KAC-9102d no sound, Amp powers on but no sound to the subs.
If the sub isn't working, you won't get a pop. All you need is a small speaker. Don't need a sub, you just want to test the sound. I recently blew 2 subs, no smoke, no smell, no sign of being blown. Absolutely nothing from the subs.... In the past my sub locked up. You can take your sub out of the box and hook the + and - to the battery to see if you can get the sub to pop there. I believe a small box will push a sub into a deep excursion to the center of the cone. I have 2 lanzar VW12D's that just quit. I hooked a 6 x 9 up to my amp and low and behold I had sound! Try that and see what you get...
Feb 07, 2009 | Kenwood KAC-9102D Car Audio Amplifier
Subs dont beat like they should
you've spent alot of money on **** by the sounds of it!!. you should only ever run multiple subs the same brand, power and resistance you can just connect any old subs to a system you need to wire them depending on the load that the amp needs to see. first thing is to try the amp/s on a individual sub to check your amps still work once done check the subs 1 by 1.
Jan 20, 2009 | Jl Audio 500/1 Car Audio Amplifier
Sub not working any more
mine does the same DONT BUY SONY XPLOYED THEY EXPLOYED!!!!!!!!!!!!!!!!!
Jun 23, 2008 | Sony Xplod XM-1652Z Car Audio Amplifier
Thunder 5604
okay u will have to troubleshoo the amp.....dose the amp light up?...when u have the radio on? also check your sub wires.going to the amp....make sure the rca'sare hooked up to the radio rear out puts are the radio sub out puts...and then test your amp gain adjustment...let me know if that work's
Jun 23, 2008 | MTX Thunder5601 300W x 1 Car Amp Mono...
Weak output from sub..
The woofer was not demagnetized.
If one signal cable is damaged, it could reduce the signal getting to the amplifier and could reduce the output.
Plug one RCA plug in at a time to confirm that both are working properly. If one is lower or not working, the cable may be defective.
If both work properly, double-check the settings on the head unit (sub-out, bass, crossover frequency...)
Oct 28, 2007 | Alpine MRP-M350 Car Audio Amplifier
No sound but powers light is green
You need to determine first if sound is getting to the amplifier. Then once you are sure of that you need to run a test to see if the audio is being sent to the first pre amp in the actual amplifier. Once this is done you can determine if the samplifier is actually the problem. If it is you will need a schematic to troubleshoot the device.
Sep 07, 2007 | Jl Audio 500/1 Car Audio Amplifier
Sony Xplod XM-554ZR Car Audio Amplifier Logo
Top Sony Car Audio & Video Experts
xxxxxx xxx
Larry Stiles
Larry Stiles
Are you a Sony Car Audio and Video Expert? Answer questions, earn points and help others
