Question about Black & Decker SV1000-4 SteamBuster Vacuum
No instructions is the main problem but the only buttons are on the handle. Spray,steam,vac,heat.There are no other buttons. How do I spray the water out? I push the switch to spray and nothing happens?
  • 1 more comment
  • scrawnybrain Jul 08, 2008
    I haven't used mine in 2 years and the pump is clicking, but no steam or spray. How do I prime the pump?
    Thanks
  • ric9 Sep 14, 2008
    idle for a long time, pump not working, how do you take it apart ??
    No manual
  • fearmotor Oct 06, 2008
    same problem. it clicks when i switch it to spray or steam. spray clicks faster than steam. the vacuum works, but whats the point if you cant spray at same time. who made this stupid thing?
    President:
  • 1,114 Answers
You can download the manual from the link below: http://www.dewaltservicenet.com/ServiceNet/Logon.asp You will need to register but it's free. As you know there's not much to the spray function but you should hear a pump running when you push the switch. You may need to clean the dirt bowl & filter for better results this is described in the manual. Please update the question & let us know if the information given was useful to you - Good Luck!
Posted on Aug 13, 2007
Your pump probably needs to be cleaned after sitting so long unused the piston can get stuck.
Open it up and disassemble the pump clean the piston and make sure it moves well in the cylinder reassemble and it should now work.
Posted on Jul 23, 2008
  • iamthepman Feb 11, 2011
    turn the unit water tank up. switch unit to steam. when you hear the unit clicking slap the bottom of the unit around the middle , several hard slaps should get the unit going
Black & Decker Steam Buster SV1000. Can't get to steam (or spray). Never used before but have had for several years. Nothing clogged. 50 water/50 vinegar in water reservoir. Vacuum works fine. Pump...
The impellar or your water pump is on its very last broken fin, time for a mew machine or the long hunt to find a replacement impellar
Nov 06, 2014 | Vacuums
Everything is working as it should, but it doesn't steam
Minerals in the water may have solidified and clogged it. The vinegar is an acid which can help to dissolve and flush and rinse out the minerals.
Sep 01, 2017 | Black & Decker SV1000-4 SteamBuster Vacuum
Black & decker steam buster
Step 1 - fill the rear tank with water. Clip the tank onto the back of the unit.
Step 2 - plug the unit into the wall.
Step 3 - move the switch to "steam". You should hear the unit 'ticking' at the rate of about 120 clicks a minute (2 clicks a second). The clicking should be "kind of" loud until the water makes its way into the pump.
The clicking will get quieter as the water moves through the pump and into the heater. The book says that you should start getting steam in a couple of seconds. My experience is that you don't get a good head of steam up until the unit has been going for about 20 seconds.
Another recommendation: don't use "Spray" until the steam is really rolling out of the unit. It just overpowers the heater and slows your steam production.
Step 4 - Steam the spot you want steamed. If you want to soak the spot, use "Spray". Most of the really good cleaning power of the unit is through the steam, so use that more than spray.
Step 5 - Switch to Vacuum and **** up the moisture from the steaming.
Repeat Steps 4 and 5 until you're happy with the cleaning.
Step 6 - Empty the front tank, rinse it out. Empty the rear tank; you probably won't get all of the water out, but that's not a problem. If you use tap water, put in a couple of teaspoons of vinegar and let the unit run until you've sucked the last of the water/vinegar solution out of the tank. If you use distilled water in the rear tank, you might be able to skip this step.
Step 6 is intended to reduce the amount of lime scale that will build up in the pump over time. You should probably avoid stronger chemicals, since they are going to sit in the pump until you use the unit next, and the first few seconds of steam on the next use will have whatever chemicals you are using.
Aug 31, 2007 | Black & Decker SV1000-4 SteamBuster Vacuum
Black & Decker SV1000-4 SteamBuster Vacuum Logo
1,435 people viewed this question
Top Black & Decker Vacuums Experts
GG TECHNOLOGIES
Are you a Black & Decker Vacuum Expert? Answer questions, earn points and help others
