Question about NEC MT1075 Multimedia Projector
Changing the lamp
How do I change a lamp on an NEC projector MT 1075?
How do you reset the lamp hours after changing the bulb on a Nec-MT-1075.
Posted on Sep 05, 2008
There is a small cover plate, about 3"X6", that 'just' snaps off. You might have to use a small screw driver to pry it open. The bulb can then be pulled out. Align the new bulb and press it down into the socket. Be careful not to touch the bulb with your hands; use gloves or a lint free cloth.
Posted on Feb 25, 2008
2 Suggested Answers
SOURCE:
informatica
  • 1114 Answers
SOURCE: Resetting Lamp Hours Procedure On Nec-MT-1075
Hi - You can download the manual by clicking the link underlined in blue below:
Nec-MT-1075
See page E-55:
As in the note replacing the lamp automatically clears the lamp hours.
Please take a moment to rate this solution & let us know if the information given was useful to you - Good Luck!
Informatica
Nec mt-1065 lamp hours reset
Hello, unfortunately the NEC MT1060 - MT1070 series projectors have EEPROM chips built into the lamp housing which counts the hours that the lamp has been used for so the only way to reset the hours is to change the lamp for a new one, i have not yet found a way to reset the chips even by reprogramming them, i'm afraid the only solution is to replace the lamp with an official NEC unit, but this was obviously their intention.
Oct 25, 2010 | NEC MultiSync MT1065 Multimedia Projector
MT 1050 Lights, goes out then Status light error
I have the same issue with mine. Did you ever find a solution? Thanks!
Sep 17, 2009 | NEC MultiSync MT1050 Multimedia Projector
My projector nec mt 1075 asks me to clean filter. How do i do it?
All you need to do is use a vacuum hose to vacuum the dust that collects on the filter. The filter cover is on the side of the projector with horizontal slits. You can vacuum through the slits, or remove the cover and carefully vacuum the filter itself. Then go into the menu and reset the filter timer. Find this reset button in the "setup" menu item. Then your clean filter reminder won't show until another 100 hours of usage.
Jun 15, 2009 | NEC MT1075 Multimedia Projector
Lamp and user's manual for a NEC Multisynch MT Projector
The manual can be downloaded here: http://safemanuals.com/user-guide-instructions-owner-manual/NEC/MT600
The part number for the replacement lamp is MTLAMP600/800 and it may be ordered from www.partstore.com
Mar 02, 2009 | NEC (SPPL1063) Projector Lamp for MT600,...
Nec-MT-1075
See page E-55:
Informatica
Sep 05, 2008 | NEC MT1075 Multimedia Projector
Preylahong NEC MT830+need help to reset new lamp
After replacing lamp in MT-830(NEC) press and hold "on" button for 10 seconds to reset lamp hours. If projector has beyond 2100 hours press the "off" button for 10 second.
May 01, 2008 | Office Equipment & Supplies
Nec mt 1000
go to menu- go to setting -go to colour move slider to right hand direction befor you change the lamp -take care that some vga cabel(((cabel between pc and projector make this fault).then you have to change this cabel and try.
Mar 09, 2008 | NEC MultiSync MT830 Multimedia Projector
MT 1055
As the lamp ages it will get dimmer this is a 1500 hour lamp look in the menu under information and it will give you the lamp time.
Jan 06, 2008 | NEC MT850, MT1050, MT1055, MT1056...
NEC vt460 Projector have a ghost problem on the screen
Hello
Pls Service the LCD Panels of the Projector, Also check the Fly-Eye lens, just next to Lamp unit. This will solve your problem. if it's not then the only solution is Replacement of LCD Panels, But Must check or replace the external RGB Cable first befor doing all this exercise.
Dec 16, 2007 | NEC VT460 Multimedia Projector
NEC MT1075 Multimedia Projector Logo
309 people viewed this question
Top NEC Office Equipment & Supplies Experts
Jaime Hernandez
Adorjani Laszlo
Are you a NEC Office Equipment and Supply Expert? Answer questions, earn points and help others
