Question about Koss C220 System
Audio output Can I hook up my Koss Theatre system so that I can improve the audio quality on my computer voice output, say, using audacity or any other audio app?
  • 56 Answers
You should be able to connect any pc to any home stereo device. you will need a special cable to connect them though. usually a local radio shack or circuit city type store will be able to help you. You will need a " Stereo Headphone to Stereo RCA " cable. ask someone at the store for one of these, explain what you are trying to do, and they will likely be able to help you as well. after you get this cable you can simply plug your computer into the back of the Speaker amplifier (usually called aux or line1) where there will be a red and white plug. set your amplifier to the Aux input and listen away.
Posted on Aug 15, 2007
SOURCE:
On the microphone setup page, it keeps on asking me to say 1, 2, 3, 4, 5, and I made sure my audio settings were correct in my control panel. i don't know why it's not working!
Check to make sure that you have connected the microphone to a microphone port. Headphone ports are identical to microphone ports physically, however they will not accept audio input. If you have verified that the microphone is connected to a microphone jack and the device still does not work, you may be using an old or low quality microphone which is not good enough to detect your voice. You might need to buy a higher quality microphone. If this is not the case, your microphone may be broken. You can check this by using a recording program like audacity (http://audacity.sourceforge.net/download/) to do a test recording and make sure that the microphone is actually recording. If none of the above seem to be the issue, then make sure you are speaking loudly and clearly. Voice recognition software is not always good at picking up your voice and you may need to enunciate your speech more, especially if English is not your first language or you have an accent. Good luck!
Jun 01, 2011 | Computers & Internet
Hi neither of my computers is recognizing my voice recorder. My laptop has xp and I have used it before, but now its not working. I thought it may have been a prob with my new desk top since I have windows...
Your best bet is to play the recordings through the headphone connector to a pc audio line-in connector and capture the audio using something like Audacity. Then output them using audacity to mp3 to play on your mp3 player.
These units are notorious for their failing USB feature.
Mar 11, 2011 | RCA VR5220 Digital Voice Recorder
When I plug in my rca vr5220-a to the usb port on my mac it no longer recognizes the drive.
Your best bet is to play the recordings through the headphone connector to a pc audio line-in connector and capture the audio using something like Audacity. Then output them using audacity to mp3 to play on your mp3 player. I suspect that a similar program is available for mac also.
These VR5220 units are notorious for their failing USB feature.
Mar 10, 2011 | RCA VR5220 Digital Voice Recorder
I have a RCA VR5320R digital voice recorder. My voice recordings are stored on the recorder, under folder "A," but when I attach the recorder to my computer, eventhough the device shows up under...
Mar 09, 2011 | RCA VR5220 Digital Voice Recorder
It says wait while trying to view recordings through voice manager, but it's never done waiting. Also the f drive states the device is not ready
Mar 05, 2011 | RCA VR5220 Digital Voice Recorder
Re: Casio WK-210. Audacity, Jet Audio and Ctrl Pnl allow me to choose a USB PnP "record from" option, however, no sound is being recorded from the Casio to the PC. What am I doing wrong. Many...
Pat, the USB output on the Casio WK-210 is only capable of sending and receiving MIDI information. It's not sending any digital or analog audio. Audacity is primarily for sound file editing.
In order to use the keyboard to record onto your computer you can connect an audio cable from the 1/8" stereo mini-jack to an input on your computer. Then you can record into Audacity.
Or you can acquire MIDI recording software (ie. Logic, Cubase) and then using the USB output on the keyboard, you can control and record multiple MIDI instruments in those programs.
Feb 23, 2011 | Casio WK-210 PACKAGE 76 Keys Electronic...
I have a Sony ICD-BX800 IC Recorder. I have purchased and hooked up the Audio Cable to transfer the recordings to my computer (I need to email them to someone.) However, I did a test recording, and the...
Sony IC RECORDER ICD BX-800 (!without USB connection!)
What you need:
- newests audio drivers in Windows 7 (updated audio-drivers)
- audio cable 3,5 M (male) both ends M-M (male-male)
- freeware application Audacity for Windows (with LAME)
Howto step by step:
- one end of audio cable connect to dictaphon's headset (earphones) jack in recorder Sony IC RECORDER ICD BX-800
- other end of audio cable connect to PC/notebook microphone (or LINE IN)
- nothing special setup (adjust) regarding Audio in Windows 7, the device for record Audio keep Microphone (default)
- in Audacity set very little volume "Input Volume Slider" and "Output Volume Slider" (for example both 0,1)
- in Audacity like Input Device set "Input (Audio device High Definition Audio)": !Don't set in Audacity like Input Device "Microphone"!
- Audio Host: MME
- Output Device set "Speakers (Audio device)"
- Input Channels set "2 (Stereo) Input"
- Sampling (Hz) set 44100
Dec 26, 2010 | Audio Players & Recorders
TV Hookup
The TV is NOT a source of high quality sound.
For the best serious audio I would recommend drawing the audio-only digital feed from the Cable Box via its highest quality audio output. Then turn the TV's volume down. Also run the vanilla RCA stereo audio pair from the cable box to the TV in case you just want to check the weather.
Mar 05, 2010 | Koss C220 System
Hook up
I assume you want your audio to go to the Koss.
The audio connectors are pretty much standard; red & white. They should be the same on both units.
The red=right channel and white=left.
The proper output from the TV is probably marked 'Line out' and 'Line in' on the Koss.
These are normally an auxiliary input and may be marked either 'Line' or 'Aux' on your input selector.
You may have gotten some of these cables with your Koss and if not, they are available wherever TV/stereo stuff is sold.
Aug 03, 2008 | Koss KS2503 System
Sound Quality
I also have a Samsung 46 inch HDTV and have the same problem. I reported it to Samsung. They sent out a repair man who replaced the entire audio system... I did not help at all. Sound quality still very bad. Hard to understand audio voice on most movies. Is there a solution short of installing an additional home theatre system?
Apr 06, 2008 | Televison & Video
Koss C220 System Logo
329 people viewed this question
Top Koss Audio Players & Recorders Experts
Steve Allison
Steve Allison
Steven Wander
Steven Wander
Ekse
Are you a Koss Audio Player and Recorder Expert? Answer questions, earn points and help others
