Question about LG LHY-518 System
Unknown disc error
Unit was working fine, then froze when I turned the power off and back on gives the unknown disc prompt no matter what disc I put in, a factory set movie or video I had already finalized on my LG.
  • 4 more comments
  • FedupGA Nov 12, 2007
    same problem sent to Lg they charged me 69.00 for labor. It has happened again and again they are charging me the 69.00. This unit is just now 1 yr. seems like it only last 6 months. Tried cleaning but doesn't work.
  • Elizabeth M Nov 26, 2007
    I have a similar problem with the disc error. The first message said "making a menu." The disc wouldn't play or eject and the message wouldn't go away after over an hour. The unit wouldn't turn off and I unplugged it, hoping it would reset itself. When I plugged it back in, the disc ejected itself. I tried it again, and it said "unknown disc error." Thanks for the comments. I'll spend the money on another unit, different brand and not bother with trying to have it serviced.
  • gone_ghostly Jan 18, 2008
    My LG froze up and now says Unknow Disc. I have only had it 6 months and it has been ejecting any of my DVDs. Please Help
  • cleffray24 May 25, 2008
    Won't play DVD's anymore. I put a DVD in and it gets stuck in "reading" mode. I can hear the disc turning but it never gets going fast enough to start. I did manage to get a CD to play. It's not very old and hasn't been used hard. Some of the DVD's are brand new and I don't know what to do. I've spent good money for this and went with a brand that I thought would be reliable. I'm disappointed to say the least. HELP ME! I have a two year old and she would love to watch a few videos once in a while.
  • jmhack1965 Jul 19, 2008
    I had my LG LHY-518 DVD Combi Receiver for just over a year when it suddenly stopped recognizing any type of disc I inserted. Not only that...now the remote no longer works and just recently the volume control on the unit sometimes goes crazy...volume goes down when I try to turn it up. What a piece of junk! The LG service center suggested I try to reset the unit, but that did not work. In case this might help someone else, the procedure is: unplug unit and wait until all lights have gone off. Push the power button and hold for 20 seconds. Turn unit back on (and hope for the best)! $69 is just for initial labor and diagnosis of problem. Parts and shipping will be extra!
  • lisatroller Dec 27, 2008
    My DVD player on my LG-LHY-518, will not play movies with 2 sides. I took the unit apart and cleaned it with Duster, but it still reads "unknown disc" ' and spits the disc back out. P.S. I checked the disc and tried again also.
You need to clean the reading head. When doing this you need to be very careful about static electricity. And never run the unit with anything more than the lid off.
First there are 3 screws on each side that take a side cover off.
Second there are 2 more screws that hold the lid on. Once the screws are removed lift the back of the lid first and tilt forward to clear the front switches.
Third; Remove the top of the DVD unit, to do this there are two screws and two tabs that hold the top on the DVD unit.
Fourth; To clean I used a vacum, but you can use canned air. But be very careful. These are very delicate parts.
Do not let the vacum touch any of the electronic parts. Do not do this with the unit plugged in. Before you test the Player put the top of the DVD unit back on. You can leave the main lid off at this point.
Good luck,
Posted on Oct 18, 2008
Been there done that i know what it says
Posted on May 25, 2008
Says Unknow Disc, please check your disc again
Philips Blu Ray Model HTS3541/F7 Unknown Disc error
Check with an other known good disc. If it shows the same for that disc too, its laser pickup unit has the fault, and should be replaced. Contact any experienced service technician. Replacing laser pickup assembly to blu-ray players are a very very skilled work. http://electronicshelponline.blogspot.com/
Jul 16, 2016 | Philips Televison & Video
After warranty time expires (2yearsd) my LG LRY-517 DVD combo recorder/player start to make randomly disc reading errors. During half year things has going worse. Now the situation is that it does not play...
Use lens cleaner disk to run many times. It cleans the lens and also runs cd on the disk which eventually will get rid of moisture on the circuits and restore your dvd recorder on the LG unit.
Mar 11, 2011 | Televison & Video
Will not read any discs and no error
TRY A DISC HEAD CLEANER,,IF NOT GO TO SETTINGS AND ITLL HAVE SOMETHING ABOUT REFORMATING THE PS3,,OR LIKE GOING BACK TO HOW IT WAS WHEN U BOUGHT IT,
May 15, 2009 | Sony Playstation 3 (PS3) Console
Action replay is not working lost all codes
If you stilll have the disc saying ar on it
put yu disc in your computar
Jan 30, 2009 | Nintendo DS Console
Does not print
1. Turn off the printer.
2. Turn it over and remove the battery cover.
3. Looking above the batteries, you will see a square opening into the upper part of the printer. In that opening you will see a white gear. Sometimes it seizes. Take a long, thin object (screw driver, letter opener, etc) and rotate the gear. It does not matter which way you turn it.
4. Because your range of motion is limited in the small opening, turn the gear in the same direction about 10-12 times so it gets a full revolution.
5. Now turn on your printer and try it again.
Apr 28, 2008 | Brady ID PAL Thermal Label Printer
Dvd won't play
sounds like microprcessor board failure the best thing to do is get a new unit
Nov 27, 2007 | Insignia IS-DVD1001 DVD Recorder/VCR
Unknown disc error message
OKAY GUYS TRY USING THIS VERY COMPATIBLE MEDIA
(MEMOREX BRAND DVD-R) THIS WILL SOLVE A LOT OF YOUR PROBLEMS
Aug 27, 2007 | Televison & Video
Dvd "unknown disc" message coming up
Have you tryed to use a lens cleaning disc yet. The laser lens on these players and recorders alike, must have the lens cleaned every oince in awhile. If that does not help, most likly you have a bad laser pickup assembly and you will need to replace the plaer as to have that repaiered, you could buy a new unit. Good Luck
Mar 23, 2007 | Daewoo DV-6T955B DVD Player/VCR
LG LHY-518 System Logo
311 people viewed this question
Top LG Audio Players & Recorders Experts
Marvin
Marvin
jairo sanchez
Mike Duncan
Mike Duncan
Are you a LG Audio Player and Recorder Expert? Answer questions, earn points and help others
