Question about Electrolux ER7926B Bottom Freezer Refrigerator
Fridge not working
Fridge not cooling, Freezer working ok, LCD light on. If I defrost the freezer, fridge works. Stops working on a weekly basis. Bought a new thermostat but no fitting instructions and I am unable to locate the thermostat in order to replace it.
  • 1 more comment
  • chang7 Mar 15, 2008
    i have same problem pluged out fridge over night it worked ok for a few weeks then same problem again i bought thermostat located the one on fridge but cant find out how to get coile out
  • Anonymous Dec 08, 2008
    I have the same problem freezer working fridge not .but a loud buzzing sound also.Trace
  • Anonymous Mar 13, 2014
    Fridge runs cool i changed the thermostat still same is there a way to set temp? has code CE on both fridge side as well as freezer also shows Hi temp in Red letters the freezer seems fine there is no light in fridge ? what could be the problem ??
    Sergeant:
    Habit-Forming:
  • 82 Answers
Fridge is not working then don't worry we will be here to help you.Just dial Dialfix.in number. Refrigerator Repair Services in Hyderabad DialFix
Posted on Feb 19, 2016
Fridge not working,regulator is under repair.can u suggest the services in hyderabad.
Posted on Feb 18, 2008
SOURCE:
Freezer stays cold but fridge has been warm. I turn the thermostat to off for a day and then everything is ok for a week. Sounds like the fan is frozen solid when fridge doesn't work( no sound) Th
If there is no cooling at all on the fridge section but the freezer works then it is confirmed that the compressor and gas pressure is OK. Now shut off the fridge and leave it powered off while you clean and check the evaporator for frost. If frost is seen it is a good indication as the compressor is working with sufficient gas within.
Now after about 6 hours plug in the fridge to start. Observe cooling to happen in about one hour and ice to from under three hours.
Earlier make sure that the thermostat was set to normal mode for freezer and fridge.
However if ice forms in the freezer then observe the fridge for about 24 hours for cooling to continue and the fridge to cut off . If not the auto defrost timer, or the thermostat must be checked. Frost formation without defrosting could block the air flow and so shut the air passage to the fridge. Also the blower fan must work and if this is not working then the fan can be faulty. Also a fault on the control unit is a suspect to non functioning of any one of these components.
If defrost timer works but frost keeps forming check while the compressor shuts if the heaters are working, check continuity of the heaters.
So try this test using a multi-meter on the defrost timer and the thermostat and make your observations so that we come to the solution.
Please check the link below for tips to remove the panels/parts: http://www.espares.co.uk/advice/fridges-and-freezers/a/2
Jan 11, 2013 | Refrigerators
The freezer gets really cold but the vent that runs from the freezer to the fridge freezes up and the coils also. when i clean the coils and the freezer vent it works great for 2 weeks then it starts to...
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
Check out these tips...they can help you figure out whats going wrong with your refrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator Defrost Timer Problem
Water Running in refrigerator from Freezer
heatman101
Sep 03, 2010 | Maytag MSD2656G Side by Side Refrigerator
Double door fridge stops cooling, autodefrost not working
It wud need a new defrost heater, the fridge gets its air from the freezer , if the defrost heater does not work , ice builds up in the airduct , equals to no cooling in fridge
Feb 01, 2010 | Whirlpool 21.0 cu. ft. Top Freezer...
Fridge freezer side by side running constantly but not cooling.
Make it a habit to defrost it every week. You see, when ice forms around the evaporator tubes (which runs around the walls of fridge and freezer), heat exchange reduces (that means heat is no longer absorbed from the things inside the refrigerator) and cooling stops. See whether freezer walls or fridge walls are damaged. Do not use knives or any other sharp tools to remove ice. Do not forcefully remove items that are difficult to take out from the freezer. Defrost and remove them.
Aug 12, 2009 | Freezers
Fridge is warm, freezer works.
Sounds like a defrost problem. Check to see if there is any frost buildup in the back wall of the freezer. If so, it is not defrosting as it should.
  • possible causes:
  1. bad defrost timer
  2. bad defrost heater (in freezer)
  3. bad thermo switch in freezer
If you don’t know what these are then unplug the machine and let the ice melt in the freezer overnight with the door open. Then try it the next day, if is cooling fine then you need to have a service person replace one of the above items.
Jul 16, 2008 | Kenmore 18.3 cu. ft. Top Freezer...
Fridge is hot while freezer works fine
Defrost for 24hrs with doors open, turn back on it will then work ok. Regards Advisor
Aug 18, 2007 | Kenmore 73502 / 73504 / 73509 Bottom...
Electrolux ER7926B Bottom Freezer Refrigerator Logo
831 people viewed this question
Top Electrolux Refrigerators Experts
Marvin
Marvin
Sal De
Jose Pino
Are you an Electrolux Refrigerator Expert? Answer questions, earn points and help others
