Question about Epson Aculaser C1100 Printer
Wrong colour everytime i print a colour document anything that should be red comes out bright yellow.
  • sarah-lou Aug 21, 2007
    have done all the usual, replacing consumables etc, still not working
  • Anonymous Mar 20, 2014
    HP 750 printed documents only have yellow
  • Epson Master
  • 705 Answers
This could one of a few fairly major problems. The easiest way to track down the fault is start by replacing the consumables - make sure you install them in the correct positions - it is possible on the C1100 to put them in the wrong places!! Change the toners first. Most importantly the magenta and yellow. Print several pages. Use MS Paint or similar to create a page with all four component colours on (cyan, magenta, yellow and black)in large blocks (see image below) and print them full page. Now look at the print and see if any one colour is missing or has reduced density. If you have a spare PCU you should but that in next. Let me know what the print outs look like and we will progress to the next step.
Posted on Aug 14, 2007
  • Inky Fingers
    Inky Fingers Aug 14, 2007
    Print a full page version similar to this image using MS Paint or similar.
  • Inky Fingers
    Inky Fingers Aug 21, 2007
    How did the colour blocks look when printed. If you have done the usual checks then it sounds like you need a DEV unit replaced or the main board has gone.
    If the machine is in warranty, get Epson out to it. If not then I'm affraid the cheapest option is to bin it and get a replacement printer. A main board or dev unit fitted onsite by an Epson engineer will likely cost more than two thirds the price of a new printer. You could try to get a dev unit from a supplier in your locality and fit it yourself. This would save a bundle
    You would need a service manual http://www.TheServiceManualShop.com) and about 45 minutes time plus 15 minutes to clean your hands after!
    Let me know if you want more instructions
SOURCE:
How can I get my printer to print in color rather than brown? more info
Hi Harold
I have a feeling that this is a problem that you will only be able to resolve by changing the colour cartridge for a new one and then doing multiple head cleaning operations.
It sounds as if the three tanks in the colour cartridge have become severely contaminated with ink from the others, thus giving this overall brown colour on the page, whichever colour the computer tells the printer to print.
To check this you may be able to use something like a Word document and using the font properties, change the colour of the font on the screen for a number of different lines (eg one line - bright yellow, another - bright red, a third - bright blue, a fourth - black) print this out and see what colours you get.
Hope this is helpful, if so would you please register that with Fixya
Cheers
Dec 21, 2014 | Canon MP280 All-In-One InkJet Printer
My Canon Pro9000 MarkII prints photos with a red tint
You probably haven't calibrated your monitor to show the correct colours, so in whatever photo programme you're using, you're setting the red tones too high. Test this by first not calibrating your monitor, but turning down all the red tone until it looks washed out. Print this and see if it's better. If so, set your monitor to a cooler colour temperature. If the result is no better, check your print dialogue settings to make sure you are using an appropriate colour profile. And, for example, if you're using Photoshop, tick 'let Photoshop manage colours' in the advanced profile settings box. Hope this helps. I doubt there's anything wrong with the printer.
Dec 29, 2012 | Canon Pixma Pro 9000 MARK II InkJet Photo...
Yellow not printing properly.
Go to the maintenance section of your printer on your desktop and clean the cartridges
Start - printers or Start - control panel - printers
Also check the level of your ink while you're there
May 08, 2010 | HP Deskjet D2360 InkJet Printer
Too much red
I'm assuming that the colour cartridge is a three in one. Blue, Yellow and Magenta.
When printing a colour document, the printer automatically balances colour mixtures from the three primary colours listed above. Should a print out be too red, its probably because its run out of yellow and/blue.
The best way to check is to print out a test page, you should get a block for each of the colours and black. If one's missing, there's your answer.
Apr 29, 2010 | Dell 922 All-In-One InkJet Printer
Wont print photos the right colour
There should be something like a printer properties menu. Find it and adjust the colour controls to manual and reduce the magenta settings etc. Also make certain you have the right type of paper selected on your printer, to the one you are using.
Feb 12, 2010 | Canon PIXMA MP510 All-In-One InkJet...
The Bizhub C351 is printing the colours wrong the red and yellow comes out pink and a yellow smudge line prints on the top of every page how do i fix it?
print off halftone for each colour
utility/counter,metercount,stop.0.0.stop.0.1test mode.halftone.cmyk start.this will print off each colur, the "failed" one will be easy to see
Jun 17, 2009 | Konica Minolta bizhub 350 All-In-One Laser...
I have refilled my Ink Colour catridge, and now when I print documents the yellow colour can not be printed / come out..please help me
The yellow print head is clogged or you are out of yellow ink. You can try to get it flowing with a warm wet paper towel by rubbing and and pressing it into the towel.
Jun 08, 2009 | Canon PIXMA iP1800 InkJet Photo Printer
Copy problems
try to adjust color saturation :
Press Menu/Set, 3, 4.
2 Press ▲ or ▼ to select Red, Green or Blue.
Press Menu/Set.
3 Press ▲ to increase the colour saturation.
—OR—
Press ▼ to decrease the colour saturation.
Press Menu/Set.
4 Return to Step 2 to select the next colour.
—OR—
Press Stop/Exit.
Jun 26, 2008 | Brother MFC 210C All-In-One InkJet Printer
C900 Colur print problems
Print a self made test page in word, a bar of bright yellow, bright cyan, bright magenta (almost pink) and black.
You might find one is completly missing, if so its a faulty toner or maybe the pull strip did not rip out correclty.
Jun 23, 2008 | Epson AcuLaser C900 Printer
Epson Aculaser C1100 Printer Logo
211 people viewed this question
Top Epson Office Equipment & Supplies Experts
Inky Fingers
Inky Fingers
Clive
Clive
Alun Cox
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
