Question about Hitachi 43FDX01B TV
Cobwebs in between screan and protector
I have a few cobebs in between my flat screen and the protector I cant find a way to remove the protector to clean please help
  • 398 Answers
Try this: The bottom cover of the TV, with the speaker grills, pulls out. It is usually held in plave with little rubber or velcro holders. Grab the left and right sides and tug outward and it should pop off. With the cover off you will see the screws under the protector, holding it in place. Remove those screws and the protector should slide upward and then outward.
Posted on Aug 14, 2007
How do we remove the screen protector to remove cobwebs?
I'm not sure you can, Warranty is out of date I asume, try hair dryer get the screen nice and warm use plastic tools see if you can get it lose, if not I'd try a hi power sucking vacuum in one of the vents, but be very careful
Jul 07, 2015 | Televison & Video
Cobwebs inside screen
you need to take the top back off the tv. and mind the glass at the top of the rear part top it is very fragile, most of the projection tv have a side cover on each side so you can clean the rear of the screen, as you not said what type screen you have i cannot tell you further.
Feb 25, 2014 | RCA Televison & Video
Scratched plastic screen protector
I have a rear projection TV that I thought had a scratch as well. Upon closer examination and several attempts to clean, I discovered that there was a spider web behind the screan in front of the color projectors. I carefully removed the screen and gently cleaned the spider web from the screen. Presto no more scratches.
Hope this is a viable solution for you as well.
Jul 02, 2011 | Mitsubishi WS-65809 65" Rear Projection...
Cobweb behind the screen.
You can try and use a air compressor or canned air and blow inbetween screen and protective cover and see if that removes the cobweb. Give that a try and let me know if that works for you.
Good luck... HDTV GURU JAY
Mar 14, 2011 | Televison & Video
My Grandson wrote on the screan of my Magnovox screan;how can i remove the crayon marks?
I suggest using a magic eraser if it is an lcd because you dont want to apply to much force or the screen will crack. just do it lightly crayon marks will dissapear
Sep 07, 2010 | Televison & Video
It will take some effort to pull it off. start on the bottom pulling straight out from the box. Then work your way up then at the top wiyh the screen out away from the bottom lift slightly and it will come off. Hope this Helps You.
Mar 28, 2009 | Hitachi 50UX57B 50" Rear Projection...
Computer screen
  • Right click on your desktop (any blanck place). Then select Properties. On properties dialog click on Settings. there you will find Screen Resolutions with a sliding Bar. You can set it as per your need. Try different position and Apply.if you got one better then click on Yes.
Thanks & Good Luck
Iqbal
May 18, 2008 | Computers & Internet
Cobwebbs between the screen and the screen protector
Hi pykeman,
I have successfully used a feather duster taped to a vacuum cleaner extension tube with duct tape. Remove the back panel of your projection television, then remove the the rectangular panel near the top over the chassis where the cabinet exposes the inside screen area. You will see the red, green, and blue CRT lenses. Insert the feather duster through this rectangular opening and sweep your cob webs away from the screen. Works for me every time.
Regards,
MyTvGuy
Jan 19, 2008 | Philips 46PP9302 46" Rear Projection...
Hitachi 43FDX01B TV Logo
61 people viewed this question
Top Hitachi Televison & Video Experts
Jaime Hernandez
Steve Allison
Steve Allison
Are you a Hitachi Televison and Video Expert? Answer questions, earn points and help others
