Question about Archos 704 WiFi Digital Media Player
CONNECTING ARCHOS 704WIFI TO THE INTERNET
THE ARCHOS CONNECTS TO MY ROUTER BUT WILLNOT LET ME CONNECT TO ANY WWW SITES
  • Anthony Vessa Nov 24, 2007
    cant browse the internet
    i thought ifi reformated the hard drive it would help but it made it worse
    any ideas on how to reinstall the original software
  • damian23 Apr 20, 2008
    Hi have a Archos 704 but can not Connect to the Internet it keeps saying can not connect what do I do
    Damian
I had this problem. I set up the Archos (5) numerous times and all with the same result. I finally set up the archos as correct as I could. I then turned off the cable modem and the router. I left them for 10 minutes and turned on the cable modem then a couple of minutes after I turned on the router. I let it all settle down for 5 minutes and tried the archos again. Straight in no problem and it has been solid since.
If that doesn't help then sorry I cant help.
Peter (Lincoln UK)
Posted on Dec 27, 2008
I had exactly the same problem and solved it myself yesterday after months of phoning/emailing Archos "customer support" - with my set up anyway it was my WEP password on my BT wireless router was wrong, I changed it on my pc to the one that was on the bottom of my hub, made sure that the exact same password was entered on my Archos and I could not believe my eyes when it worked. You need to make sure of course that all the other settings match too, IP address, Gateway and all that other stuff I dont really understand, (nor want to !) Good luck Ulstergirl
Posted on Sep 25, 2007
SOURCE:
Archos 605 has 2 problems: 1: can't connect to wifi network at home. This is a netgear 614 router (which is quite old) with WEP encryption. Have tried to disable all security still no joy. Have...
the issues with the pda and wifi is most likely based on the 811 standards that each have...did you compare those two for 811 compatibility?
Apr 23, 2008 | Computers & Internet
Hello i have a problem with Archos 5 Internet tablet... our isp give me a ip adress And Vpn connection & i can connect with laptop but in archos i connect to wireless access point but i can't...
Hi, Unfortunatly there is no solution with your current set up, you will need a medium grade router like a draytek 2820, that can establish the vpn from itself rather than from the computer, this way the vpn is established from the router, and when your archos connects to the router it will also have access to the vpn.
Jun 02, 2011 | Computers & Internet
Archos 7 Home Tablet is new. Cannot connect to Internet or wi-fi. Please advise. Woody MacDpnald
Welcome to Fixya. If you want to connect to Wifi you need to know the settings of your router.
Please provide me with the make and model of your router to guide you on how to connect the Archos 7
Thanks
Mar 15, 2011 | Archos 7 Digital Media Player
How to connect wifi network in archos 28 internet tablet
This is normal. To save energy, the ARCHOS always starts up with the WiFi set to off. You must manually use the Fn-F3 keys if you want to activate the WiFi connection.
I cannot connect to the Internet over WiFi, what's wrong? Make sure that your WiFi is activated. This can be turned on and off with the blue function key pressed down and then the F3 key. The blue WiFi indicator just below the touch-pad will light indicating that it has been turned on.
My WiFi router/modem is on and working, but it does not show up in the list of wireless networks. What's wrong? It could be that the WiFi modem/router is hiding its SSID. This is done for security purposes sometimes. You can either change this on the WiFi modem/router (see its instructions) so that it broadcasts its SSID (and then you'll see it in the list on your ARCHOS 10) or you can go into the advanced settings of the Wireless Network Connection screen to the Wireless Networks tab and 'add' a new connection. You will need to know the SSID name and its other connection parameters.
Dec 17, 2010 | Archos 28 Internet Tablet
How conect to internet wireless ? whit a archos 5
you can connect it via wi-fi or via bluetooth..
if you have a router near you archos will get connected with that router through wi-fi and you'll be able to go online.
if you have a 3g and bluetooth enabled phone with you pair that phone with archos via bluetooth so that archos can use phone data plan for browsing the internet.
these are the two ways by which archos will get online
Sep 30, 2010 | Archos Internet Media Tablet MP3 Player
Router willnot connect with the internet
I never use the disks, try the following:-
1. Turn off both the linksys and your modem
2. Turn on your and wait for the usual lights to turn solid
3. Turn on the Linksys and wait 30 secs
4. Press the button on the front to the left. It does not look like a button but flashes while it is finding an ip address
5. now connect with an Ethernet Network Cable and make sure the internet is working
6. Next Setup the Wireless Encryption, if you don't know how to do this, post and I will help
7. Disconnect the cable and Connect Wirelessly
If you have limited connectivity then next try this: http://www.howtofixanything.co.uk/howto-269.html
Jan 14, 2009 | Linksys Wireless-G WRT54G Router
Archos
Have you tried username 'admin' and password 'password'?
These are for the actual router.
If it's the wep/wpa wireless encryption password, then you need to go into the router's domain page, it'll be something like 192.168.0.1 (or 192.168.1.1 or 192.168.2.1 or 192.168.0.2) and enter admin and password, and then, usually under the Firewall menu, it'll say Reset Factory Settings. You can reset it and your wireless network should now be unsecured and you'll be able to connect to the internet wirelessly with any device.
Hope this helps
Chris (ziraffa)
PS You can also go back into that page and set new passwords for encryption and also for passwording the actual router too.
Write them down this time! :)
Dec 28, 2008 | Archos 704 WiFi Digital Media Player
Cannot get my Archos 605 connected to the internet
make sure you are entering the wpa key generaly this is found on the back of your router and its only about 15 digits long on mine.
Nov 04, 2008 | Archos 605 WiFi Digital Media Player
Archos 704 WiFi Digital Media Player Logo
213 people viewed this question
Top Archos Audio Players & Recorders Experts
Marvin
Marvin
 Grubhead
Grubhead
 Mike M
Mike M
Are you an Archos Audio Player and Recorder Expert? Answer questions, earn points and help others
