FixYa.com
Tags:
Casio XG-3 Personal MiniDisc Player
Casio XG-3 problem
By Putty - usenet poster
My girlfriend has a Casio XG-3 MD player, and it has a problem. Even
when putting a brand new battery in the unit, it displays a "battery
low" indicator when the unit is turned on.
Has anyone else seen a similar problem? Any luck returning the unit or
having it repaired, etc.?
thanks!!!
/steven.
This Problem has been added to the Share Your Expertise Page under "My Work Queue".
Solution #1
posted on Aug 08, 2005
Not Rated (0)
Chandler
Chandler - usenet poster
Rank:Apprentice Apprentice
Rating: 0%, 0 votes
On 2001-07-17 see. @for.email(StevenTravers) said:
   >My girlfriend has a Casio XG-3 MD player, and it has a problem. Even
   >when putting a brand new battery in the unit, it displays a "battery
   >low" indicator when the unit is turned on.
   >Has anyone else seen a similar problem? Any luck returning the unit
   >or having it repaired, etc.?
Yes, I have seen this kind of problem before in gear which has had a battery
left in it, shall we say, "A bit too long"  Try taking the battery out and
CAREFULLY cleaning away any corrosion on the contacts, especially the negative
contact (Spring if any) and see if this helps  Note CAREFULLY
John F Davis, WA8YXM, In Delightful Detroit, a @detroit.freenet.org
"Nothing adds excitement like something that is none of your business"
If Noah had been wise he would swatted one of those flies
Net-Tamer V 1.12.0 - Registered
Was this solution helpful? Show your Appreciation by rating it:
Can you Help with these Personal Audio Mini Disc Player problems?
Starting up and Charging
I have an Audiophase... Answer This...
mini disc player technics...
hi there i noticed your... Answer This...
Sony 3 cd Player.After a power...
This Hi Fi is approx. 4 years... Answer This...
COMUNICACI?N ENTRE MODEM Y...
Cambie el modem. Ahora tengo un... Answer This...
c.d. fm radio player.
everything is working well,i... Answer This...
Repair Service
Find Personal Audio Min. Repairman Near You:
FixYa does not evaluate or guarantee the accuracy of any information provided through its proposed solutions, posts, or Expert Assistance Sessions. By entering this site you declare you read and agreed to its Terms. You may NOT copy or distribute the content that appears on this site without written permission from FixYa Inc.
© 2005-2008, FixYa, Inc. or its affiliates
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
