Question about ViewSonic E70 17" CRT Monitor
No blue gun, all of a sudden
Hi Fixers, The blue gun on my E70 suddenly stopped working. Otherwise the monitor is perfect. Can anyone offer me a clue as to where to start looking for the problem? I'm a bit of a newbie, but yeah yeah, I'll be VERY careful of not getting shocked - I'd just like to know if its worth trying to fix it myself or if it really has to go into a workshop? Thanks, Gavin
  • Gavin2 Aug 17, 2007
    Hi Guest, my monitor is showing perfect picture in the Red/Green spectrum - pin sharp, high res, zillions of colours - all EXCEPT for Blue and combinations of blue. I've disconnected the power, checked the picture cable, had the back cover off, poked at all the internals [with a very long wooden chopstick - I'm not taking any chances;-] but still no solution. The only blue I ever see is when I shut down the computer, then the screen flashes a small intense blue spot in the centre before it goes dark.
    OK, so if there's no blue gun (Garfunkel01), then maybe it's some other circuitry or component that's faulty. I just wondered if it might be a simple fix...
    Should maybe raid the piggy bank and buy one o' them LCD things instead!
100,000? At that rating the monitor would be giving off x-rays and gamma rays. Its more like 25,000 volt, plus its easy to discharge the tube, don't discourage him... Gavin2, is your monitor still not working?
Posted on Aug 16, 2007
  • 56 Answers
Cant be a blue gun, there is only one gun in these monitors. Check your cable, wiggle the cable at both the comptuer and montior ends, if this monitor has a changable cable and wiggling it works, replace the cable. otherwise you'll have to take it somewhere or get it replaced.
Posted on Aug 15, 2007
  • Ashley Sinclair
    Ashley Sinclair Aug 15, 2007
    it's worth having someone professional look at it if you need to open it up.
    There are extremely high voltages involved with CRT monitors and tv's. I would not reccomend opening it unless you know what not to touch.
    (100,000V+)
    be careful
SOURCE:
Sony 43"/projection (older) suddenly after 18 years has a snowy and less than perfect picture. It will "pop slightly" and the picture will come back to perfect. Any clue?
Your picture tubes are failing. There are no parts available for this TV and your money is better spent on a new flat panel. That is the grid guns starting to short out.
Apr 05, 2016 | Sony Televison & Video
Can't start up. suddenly stopped working.
hi, please check the setting first of the monitor, their is a setting their that it will when it set up time is to turn off or stand by..
Mar 19, 2010 | LG FLATRON L206WTQ-BF Monitor
My monitor colour has changed to yellowish
The first thing to try is to make sure the video connections both at the monitor and the PC are secure. A number of color image problems are just a loose connection. Make sure you remove the connectors and then reseat them when you do this.
Jul 28, 2009 | Samtron 76df 17" CRT Monitor
My Sony Moniter suddenly turned to a bright yellow
If the display looks normal other than being yellow, it's missing blue.
This may be because of a bad cable. Sometimes the wires inside break from flexing. Try wiggling the cable (as mikeslab suggested) at the end where it connects to the computer. Also check the plug for bent pins.
It's more likely the monitor has lost blue due to solder connections to the blue output transistor or transistor failure, or that the picture tube itself has gone bad and the blue gun has quit. Tube failure is pretty rare. I've seen many cases of bad connections and transistors, though.
If the cable and plug aren't the cause, you can have a service shop check the monitor and give a repair estimate. But if this is a 17- or 19-inch monitor, you might just want to replace it. New LCD's are $150 or less. To repair yours would be around half that cost already, possibly more depending on labor and parts costs.
Apr 24, 2009 | Sony Computers & Internet
Black and white only
Well - it's fixed - but no thanks to anything I did.  It's just all of a sudden working fine again.  I tried three different dvd's the other night, and all were black and white.  But last night the same dvd's were back to colour.  Who knows?
But thanks for asking.
Dec 27, 2008 | Sony SLV-D300P DVD Player/VCR
Viewsonic E71f suddenly a change in colour as if a layer formed
there must be a loose contact between tracks of base on crt or may be dry solder remove it problem may be solved
Nov 21, 2008 | ViewSonic E70 17" CRT Monitor
LG L194WT Monitor suddenly stop working
it is probably indicative of a switched mode powersupply trying to start then seeing a short and then trying to start again...this will cycle continuously until fault is rectified..any component that can drain the powersupply is the culprit...you need some way of detaching the powersupply from the load (monitor) to see if the power supply its self is the cause and also check if there is a loop back (a pulse) for continuous running.
qube
Jun 06, 2008 | LG Flatron 563LE 15.1" LCD Monitor
ViewSonic E70 VCDTS21569-3P. NO POWER
hi,
Try to check capacitor on the B+ line leakage.
Mar 29, 2008 | ViewSonic E70 17" CRT Monitor
Monitor Colour
for whatever reason you have lost your blue gun. it could be a matter of an adjustment or a defective component in the blue video driver. take it to have it serviced.
Jun 20, 2006 | ViewSonic VG700b 17" LCD Monitor
ViewSonic E70 17" CRT Monitor Logo
129 people viewed this question
Top ViewSonic Computers & Internet Experts
Steve Allison
Steve Allison
Ekse
Are you a ViewSonic Computer and Internet Expert? Answer questions, earn points and help others
