Coffee and Espresso Makers
Problem for Coffee and Espresso Makers
Generic problem for all Coffee and Espresso Makers
Water leakes over the top of my rap...
By brooketello on Mar 17, 2009
without the rapporto filter on it seems as though the water is coming out correctly, but when I put it on with the coffee in it it just spews out of the top never coming through the little holes that it is supossed to come out of. I have a Starbucks Barista Type SIN 006
Clarification Request
Posted by z34aga on Mar 28, 2009
Any possibility that the water in tank once freeze??
Solution #1
posted on Mar 31, 2009
Not Rated)
stockdog
Rank: Apprentice
Rating: 0%, 0 votes
I forgot to mention in my earlier post, to also check the brew head gasket, use your tool to clean the grounds out of the gasket, it can cause the filter to not seat properly.
Remove the filter, and insert the gasket cleaner tool.
Twist the tool (the cup looking thing with the phillips head attachment on it) with the notches up into the gasket, twist back and forth until you get as much grounds out as possible. Then clean the gasket with a warm wet cloth until no residue shows on your cloth. Do this cleaning every couple weeks if you use the machine a lot.
Also be sure to run a brew cycle thru an empty filter after the last use for the day. This really keeps evrything clean in your filter and shower screen.
Comments:
Mar 31, 2009
- Sorry , my earlier post did not show up.
Too much coffee in the filter, (use 1/8 in from the top), too fine a grind (use course like grains of salt) , or a clogged filter (clean all the screens and check the filter to see if holes are clogged.)
This site has much great info: www.partsguru.com, and call Starbucks service, they are great!! And will talk you thru many repairs right on the phone.
Was this helpful?
Yes
No
Popular Solutions for Coffee and Espresso Makers
Questions and Unsolved Problems for Coffee and Espresso Makers
Answer
which style of the bodum french press' is best, the chombard, brazil, or kenya?
Answer
Where in North-Central London can I purchase a replacement gasket for a 1-2 cup vigano stovetop... (More)
Answer
we just received this coffee maker but without instructions. there is a plastic long piece with two... (More)
Answer
I have a electrical smoke coming from the back of the machine when it is heating
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Top Coffee and... Experts
Top Small Appliance Repairmen
in , CA
(316) 283-4211
(316) 283-8664
Chat Now
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
