Home | Ariston Technologies | LL64WNA Built-in Dishwasher | Ariston LS 620 A Dis...
Ariston Technologies LL64WNA Built-in Dishwasher
Problem for Ariston Technologies LL64WNA Built-in Dishwasher
Ariston LS 620 A Dishwasher
By woodsy08 on Aug 13, 2007
When i turn on the dishwasher the pump starts empties the excess water, but then carries on. No water enters the dishwasher at all. I have checked the pipes etc and i think the first soleniod valve my be damaged. Could i be right? On the valve is 240vac on both sides but no water after the valve.
Best Solution
posted on Aug 13, 2007
Very Helpful)
dovi
Rank: Guru
Rating: 88%, 2492 votes
Since, the pump doesn't stop working, it sound like a water level switch issue.
The switch level is usually a diaphragm device with a small clear tube attached between the switch and the bottom of the washer's outer tub. I am not familiar with this specific machine, but if you will open the rear panel you will find it easily. Clear tube first from any obstruction, In case it doesn't help, disconnect the wires from the unit (you should disconnect first machine's power cable !!!!!) and measure with a multi-meter on its tugs for continuity and disconnection while you are inhale and blow to its tube.
In case it doesn't react, you should replace it.
Good luck !
Comments:
Aug 13, 2007
- In case you have 240V on valve's tsgs -
Check first the filters on the inlet water line (both sides).
If it will not solve you problem,
you can easily open the valve and clean it (from scale or other dirt). Be aware you should disconnect the power cable from machine before doing it !!!!
Check as well for valve's coil resistance. In case you have no resistance measurement - you should replace it for a new one.
Good luck
Was this helpful?
Yes
No
Solution #2
posted on Jul 24, 2009
Somewhat Helpful)
nic_sweden
Rank: Apprentice
Rating: 75%, 1 votes
I can´t find a manual for my ARISTON ls 620t.....
Was this helpful?
Yes
No
Popular Solutions for Ariston Technologies LL64WNA
Questions and Unsolved Problems for Ariston Technologies LL64WNA
Do you recommend Ariston Technologies LL64WNA Built-in Dishwasher?
Answer
Answer
ariston lsi 61 dishwasher kept stopping half way through wash cycle.but now unable to select any... (More)
Answer
I have the above dishwasher and it stops half way through the cycle and refuses to drain. The salt... (More)
Answer
We live in Perth Australia and have this dishwasher in our rental house. It does not have a manual... (More)
Answer
The last time it broke down i replaced the element when it carried on for another two years.I have... (More)
Answer
We bought a new machine for our little gite in France to rent out. It has never been used and only... (More)
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Browse popular Problems
More Common Problems
Most Common Problems for:
For Ariston Technologies LL64WNA...:
Top Dishwasher Experts
Rank: Guru Guru
Solutions: 1582
Experience: I run a Full-time Appliance Service Co.with HVAC/Auto Air Conditioning and Small Engine Service.
Ask Me
Find more Dishwasher Experts
Top Dishwasher Repair
(423) 303-3783
Dishwasher parts delivered overnight nationwide....
 Appliance Parts Pros.com
(800) 470-7119
All the parts that you need for your Dishwasher...
appliancehelp.com
Chat Now
X
Continue
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
