DuroMax RV Grade 4400 Watt 7.0 Hp Gas Generator w/ Wheel Kit - XP4400 Logo
Anonymous Posted on May 14, 2013
Duro max xp4400 generatol is not producing electricity
My generator is not sending current, I notice that the lever of the breaker does not click anymore. somebody tried to fix it and cut some wires to avoid the breaker but didn't work.
Chris Weiser
Level 3:
Master:
  • Master 563 Answers
  • Posted on May 14, 2013
Chris Weiser
Master
Level 3:
Master:
Answers
563
Questions
0
Helped
162558
Points
1650
Check power going to the breaker. Check the brush conditions and the trace condition.
2answers
Generator will run but will not produce elec power
You need to run some tests. We have made videos to show you how to test the generator.
https://www.generatorguru.com/help-me-fix-my-generator-repair-advice/
If you need any assistance, let us know. We are always happy to help. :)
1helpful
What is the valve clearance on a duro max XP10000e generator?
0.015 inches intake and exhaust, if not running right 0.020 inches for exhaust.
We also we sell parts if you need them :)
Need help with diagnosing generator not producing power
may be a bad breaker or a shorted wiring problem. not generating any power, I would ck. the brushes inside the generator.
Wolf 5000kva generator
Locate where the choke lever is for your generator (under the petrol tank), you ought to notice a star headed shaped screw connected to the governor shaft (if you bend and look closely further beyond the choke lever; still under the petrol tank) which is linked to the carburettor housing/assembly. You need to increase/turn clockwise (using a star screwdriver) on this screw.
Your generator engine sound will change/high a bit because the engine speed will increase.
Reconnect your 1800w chop saw (load) and see if your generator can "effortlessly" accommodate it without shutting down otherwise, increae the turns on this adjustment screw attached to the governor shaft till your generator operates/stabilizes with the load (1800w) connected
2answers
Generator runs fine- does not produce any power- checked breakers all ok
The voltage regulator for the generator is not work, replace it. Why, if there no dc voltage to excite the stator it won't any output. GB...stewbison
9helpful
2answers
Generator stopped producing electricity
if the generator has been sitting for a while you might have to excite the magnets to start producing power. plug in a reversible drill and with the generator running turn the drill in the reverse direction by hand while holding the trigger in the forward position.
1helpful
2answers
Generator produces no power
Glad to hear it was easy :-)
Here is a link to my trouble shoot solution so that this will get marked as solved.
2answers
Generator will not produce electric power
Check the air cleaner to make sure that it isn't clogged with oil. If you find any significant amount of oil you may also need to clean the carb. Also check the spark plugs for fouling. Once you're convinced that the engine has no service related issues, check the governed throttle setting. To do this find the spring that pulls on the governor arm and look for either a tab to bend up or a threaded rod to tighten at the end of the spring not connected to the governor arm.
Regards,
Carl
Top DuroMax Electrical Supplies Experts
john h
ADMIN Andrew
ADMIN Andrew
Are you a DuroMax Electrical Supply Expert? Answer questions, earn points and help others
