Question about Mitsubishi Mr. Slim MXZ30TN Air Conditioner
Airflow We have a new ducted PEH-MYB reverse cycleairconditioner. We set the temperature at 20 degress for heating. Once it reaches it it then blows out cold air. We have had someone come 4 times already to fix various problems. It is not nice to sit near a duct and feel cold air. I thought the air flow was meant to stop, then start uo again when the temperature dropped just like our gas heaters? Am I wrong?
  • 1,420 Answers
Go to www.mrslim.com. Look under the tab for library. Ib there you will find the troubleshooting guide for this model. Make sure the remote is set for cool and make sure the fan setting is not on automatic.
Posted on Aug 30, 2007
SOURCE:
Bonaire gas ducted heating not reaching set room temperature anymore...
has the system air filters been serviced lately
is the system circulation fab been cleaned to allow full air circulation of the system
call in a technician to check for vermin infestation preventing the system from working properly
Jun 20, 2016 | Heating & Cooling
Why is my heating system short cycling?
What is your Temperature Rise across the furnace? Match this with the name plate. This tells you a lot. Is the t-rise higher or lower? If its higher, you could have restricted airflow or exhaust issues. If its lower, could be gas pressure or duct work problems, pulling in colder air somewhere. More info is needed to help. I am assuming the furnace is operating continuously when you say it will not heat over 66 degrees?
Feb 16, 2015 | Heating & Cooling
Is it normal for my furnace to have burner cycle once or twice
That sounds normal. When the bonnet reaches a preset temperature the burner turns off then when it cools down a bit the burner turns back on. Clean filters etc will help to keep the burner on longer in a cycle.
Aug 24, 2014 | Heating & Cooling
Fasdfas
Does the furnace stays off?.
Furnace are ment to cycle on and off because of limits .If you set to 70 furnace would cycle several times before reaching that temperature.
Just make sure your filters are clean and you got proper return air flow because lack of air flow will cause furnace to shut off sooner than normal
Jun 08, 2017 | Heating & Cooling
I have a 94 grand am gt, i just put a new thermostat in and it blows out warm air for about 20 sec's then goes to cold. any help??
Sounds like the control flap in the duct system that changes the airflow from heating to cooling has failed. It's not staying in place for heat to flow but returning to the cooling position.
Dec 30, 2010 | 1994 Pontiac Grand Am
Our dryer will run and blow air but will not heat up anymore.
the limit thermostats are tripped. unplug your dryer before you do anything. there is an access panel on the back of the dryer over the heating element. some of them are resettable, they will have a red button in the middle. press them one at a time. if you hear one click, that means you found it. put the cover back on, plug it in, and check it. some of the limit switches are not resettable. they are like fuses that blow one time and have to be replaced. you will have to check them with a volt meter. they usually blow because the dryer ducting in your wall is clogged, and there is not enough airflow to take the heat away from the heating elements. the thermal limits blow to keep the dryer from catching on fire due to the high temperatures. If you dont resolve the airflow issue, it will blow the new thermal limits also. take it with you to the appliance store, along with your model number to make sure you get the proper replacement.
Nov 20, 2010 | Whirlpool LER4634J Electric Dryer
Compressorruns fora short time
the thermostat controlling your unit likely has a window type of programming for digital or mechanical adjustment for older style thermostat that sets a minimum off temp and a maximum on temp, there may be an adjustment to set the range it operates at, otherwise you may have a defective thermostat controller unit and it needs replacing also insure that the temperature sensing element is clean and free of dust build-up and your filter is clean
Apr 28, 2010 | Dometic Rooftop RV Air Conditioner
Getting F4 error
I dislike new electronically contolled ovens so much. Electronics are never meant to be near temperatures reaching more then 200 degress.
F3 or F4 Open or shorted oven temperature sensor Replace oven temperature sensor
Aug 01, 2009 | Kenmore 30464 / 30465 / 30469 Gas Single...
Mitsubishi Mr. Slim MXZ30TN Air Conditioner Logo
146 people viewed this question
Top Mitsubishi Heating & Cooling Experts
vince
D. E. Hev
Stuart Slabber
Level 1 Expert
Are you a Mitsubishi Heating and Cooling Expert? Answer questions, earn points and help others
